A small 3D-printed printing press with a print that says THE QUICK BROWN FOX JUMPED OVER THE LAZY BROWN DOG.
Mini 3D-Printed Press Is Sure To Make An Impression
Making stamps out of potatoes that have been cut in half is always a fun activity with the kids. But if you’ve got a 3D printer, you could really step up your printing game by building a mini relief printing press.
To create the gear bed/rack, [Kevr102] used a Fusion 360 add-in called GF Gear Generator. At first this was the most finicky part of the process, but then it was time to design the roller gears. However, [Kevr102] got through it with some clever thinking and a little bit of good, old-fashioned eyeballing.
Per [Kevr102], this press is aimed at the younger generation of printers in that the roller mechanism is spring-loaded to avoid pinched fingers. [Kevr102] 3D-printed some of the printing tablets, which is a cool idea. Unfortunately it doesn’t work that well for some styles of text, but most things came out looking great. You could always use a regular linocut linoleum tile, too.
This isn’t the first 3D-printed printing press to grace these pages. Here’s one that works like a giant rubber stamp.
Print-in-Place Helping Hand Grabs A Hold Of Your PCB
We probably don’t have to promote the benefits of a third hand or PCB holders in general, such is their obvious utility. While you can arrange some boxes and pile up tools on your bench to get a similar result, a good grip and flexibility to move the PCB around during soldering or performing any other work on it makes life just so much easier. Thanks to 3D printing there have been plenty of inspiring designs that go beyond the usual clumsy-yet-cheap croc clip version of it, and [SunShine] adds one on to the list with his spring-loaded print-in-place PCB gripper, demonstrated in this video and available on Thingiverse.
The gripping part’s design is based on a spring-loaded box [SunShine] created a little while back — which you can read more about in his Instructable. The holder itself comes in two varieties: one that brings its own stand, and one that has a GoPro mount. The first one is really more to show off the design, and while the gripping part is fully functional, it might not perform too well with heavier boards and easily tip over. Sure, a bigger bottom or mounting it to something more sturdy will fix that, but so will the GoPro-mount version, which also adds the whole flexibility aspect.
If you do prefer something standing more sturdily on your desk though, have a look at the concrete-mounted solder squid from earlier this year. And if you’re interested in more of [SunShine]’s work, check out his 3D-printed brush collection.
Continue reading “Print-in-Place Helping Hand Grabs A Hold Of Your PCB” →
Spring-Loaded Bed For K40 Laser Acts As An Auto-Focus
Laser engraving and cutting has something in common with focusing the sun’s rays with a magnifying glass: good focus is critical to results. If materials of varying thicknesses are used, focus needs to be re-set every time the material changes, and manual focusing quickly becomes a chore. [Scorch Works] has a clever solution to avoid constant re-focusing that doesn’t involve sensors or motors of any sort. The result is a self-adjusting bed that compensates for material height changes, ensuring that the top surface of the material is always a fixed distance from the laser’s head.
The way [Scorch Works] has done this is to make two spring-loaded clamps from angle aluminum and a few pieces of hardware. When a sheet of material is placed into the machine, the edges get tucked underneath the aluminum “lips” while being pushed upward from beneath. By fixing the height of the top layer of angle aluminum, any sheet stock always ends up the same distance from the laser head regardless of the material’s thickness.
[Scorch Works] shows the assembly in action in the video embedded below, along with a few different ways to accommodate different materials and special cases, so be sure to check it out.
Continue reading “Spring-Loaded Bed For K40 Laser Acts As An Auto-Focus” →
