Making A Bladeless Tesla Turbine Generator In LEGO
The Tesla turbine is a bladeless centripetal-flow turbine invented by Nikola Tesla in 1913, using the boundary-layer effect rather than having a stream of gases or a fluid impinge on blades. Recently [Jamie’s Brick Jams] constructed one using LEGO to demonstrate just how well these turbines work compared to their bladed brethren.
Since it uses the boundary-layer effect, the key is to have as much surface area as possible. This means having many smaller discs stacked side by side with some spacing between them.
Interestingly, the air that is directed against the turbine will travel inwards, towards the axle of the discs and thus requiring some way to vent the air. In the video a number of design prototypes are tested to see how they perform before settling on a design suitable for a functional generator.
The first discs are printed in PLA with an FDM printer, which are put on a shaft with 1 mm spacers. What becomes clear during testing is that these turbines can reach ridiculous speeds, but torque is really quite weak until you hit very high RPMs, well beyond 10,000 RPM. This is a bit of an issue if you want to drive any load with it, especially on start-up, but managed to propel a walker robot as a quick torque test.
Continue reading “Making A Bladeless Tesla Turbine Generator In LEGO”
Tesla Turbine Boat Uses Lily Impeller
Typically in the RC community, radio control boats rely on small nitro engines or electric motors to get around. Fitted with traditional propellers, they’re capable of great speed and performance. Of course, there’s more than one way to skin a cat, as [Integza] shows with his latest build.
As far as the boat side of things is concerned, it’s a basic 3D printed single hull design. The innovation comes in the drivetrain, instead. The boat uses compressed air for propulsion, stored in a battery of four soda bottles, pressurized to 6 bar. The compressed air is used to drive a Tesla turbine of [Integza]’s design, which is 3D printed on a resin printer. Rather then driving a propeller, the Tesla turbine instead turns a Lily impeller, which pulls the boat through the water rather than pushing it along. The impeller uses a nature-inspired design, hence the name, and was also 3D printed, making producing its complex geometry a cinch. The guts of a toy radio control car are then used to control the boat.
Understandably, performance is less than stellar. The limited reserves of compressed air can’t propel the boat long, and the combination of the high RPM Tesla turbine and Lily impeller don’t provide a lot of thrust. However, the boat does move under its own power, demonstrating these oddball technologies while doing so.
[Integza] has been working with these technologies for a while; we featured an earlier Tesla turbine build back in 2018. Video after the break.
Continue reading “Tesla Turbine Boat Uses Lily Impeller”
PLA Foils Homemade Tachometer
[Integza] built a Tesla turbine and wanted to know how fast it was spinning. However, he didn’t have a tachometer, and didn’t want to buy one. After a false start of trying to analyze the audio to measure the speed, he decided to use a tried-and-true method. Let the wheel break an infrared (IR) optointerruptor and count the spokes of the wheel as they go by. If you know the spacing between the spokes, you can compute the speed. There was only one problem: it didn’t work.
Turns out, PLA is at least somewhat transparent to IR. Knowing that it was a simple matter to fix some tape to the wheel that would block IR and that made things work much better. If you missed the video where he built the turbine, you might want to watch it first.
Continue reading “PLA Foils Homemade Tachometer”
Micro Tesla Turbine Is An Engineering Tour De Force
A corollary to Godwin’s Law ought to be that any Hackaday post that mentions Nikola Tesla will have a long and colorful comment thread. We hope this one does too, but with any luck it’ll concentrate on the engineering behind this tiny custom-built Telsa turbine.
For those not familiar with Mr. Tesla’s favorite invention, the turbine is a super-efficient design that has no blades, relying instead on smooth, closely spaced discs that get dragged along by the friction of a moving fluid. [johnnyq90]’s micro version of the turbine is a very accomplished feat of machining. Although at first the build appears a bit janky, as it progresses we see some real craftsmanship – if you ever doubt that soda can aluminum can be turned, watch the video below. The precision 25mm rotor goes into a CNC machined aluminum housing; the way the turned cover snaps onto the housing is oddly satisfying. It looks like the only off-the-shelf parts are the rotor bearings; everything else is scratch-made. The second video ends with a test spool-up that sounds pretty good. We can’t wait for part 3 to find out how fast this turbine can turn.
Size matters, and in this case, small is pretty darn impressive. For a larger treatment of a Tesla turbine, see this one made of old hard drive platters.
Continue reading “Micro Tesla Turbine Is An Engineering Tour De Force”
Engine Hacks – Tesla Turbines
Engine Hacks Theme banner
You probably weren’t expecting a project based on [Nikola Tesla’s] work to show up during the Engine Hacks theme. Most people know of him because of his pioneering work with high voltage equipment. Never the less, [Tesla] designed a device that later became known as the Tesla Turbine. Tesla turbines are made out of a series of thin disks attached to a central rotor. Air or steam is injected into the closed turbine housing at the outer edge of the disks. It swirls around through the turbine blades and eventually exits near the rotor. This type of turbine can achieve very high rotational speeds but doesn’t have a lot of torque, which limits their usefulness. Check out this instructable that shows you how to build your own Tesla turbine out of hard drive platters.
We have featured a Tesla turbine in the past on Hackaday. In this previous post, [Rick] shows us how to carve a pumpkin with a skill saw blade that is powered by one of these turbines.
Steampunk Vibrator
steampunk_vibrator
[Ani Niow] built this steam powered vibrator. It has a milled stainless steel shell with a brass motor structure. The motor is a Tesla turbine made from a stack of Dremel diamond cutoff wheels. This drives an off-center weight to create the vibration. She tested it using a pressure cooker as the steam source. It worked, but became so hot it had to be held using welding gloves. It works just as well with compressed air though. You can see the device at the Femina Potens Art Gallery in San Francisco or later this month at Maker Faire.
[via Laughing Squid]
UPDATE: [Ani] responds in the comments.
Tesla Turbines For Fun And Profit
[youtube=http://ca.youtube.com/watch?v=aoRh8T_VX-Y]
[Rick] has been building Tesla turbines in various ways and posting his projects to youtube. For those who are unfamiliar, a tesla turbine is a fanless turbine that uses a smooth central disk spun by friction from a gas or fluid. Since the turbine itself has no protrusions, it is extremely stable. There are lots of other benefits, which can be explored on the Wikipedia page. [Rick], as you can see from the video above has found several uses for them, from Halloween props, to generators for lights, to an automated shake flashlight shaker, you can even watch him rev one up to destruction. Though most of these are at relatively low speeds, he has shown that he can make one from CD spindles that is stable enough to reach 10,000 RPM. [Rick] admits that all they really do is spin fast and make cool noises, but they do that pretty well.
Update: Moments after this was published, we found an instructable by [Rick] on how to build a blender using a tesla turbine.
