A man is shown behind a table, on which a glass apparatus like a distillation apparatus is set, with outlets leading into a large container in the center of the table, and from there to a pump.
Pulling A High Vacuum With Boiling Mercury
If you need to create a high vacuum, there are basically two options: turbomolecular pumps and diffusion pumps. Turbomolecular pumps require rotors spinning at many thousands of rotations per minute and must be carefully balanced to avoid a violent self-disassembly, but diffusion pumps aren’t without danger either, particularly if, like [Advanced Tinkering], you use mercury as your working fluid. Between the high vacuum, boiling mercury, and the previous two being contained in fragile glassware, this is a project that takes steady nerves to attempt – and could considerably unsteady those nerves if something were to go wrong.
Continue reading “Pulling A High Vacuum With Boiling Mercury”
Oil-Based Sprengel Pump Really Sucks
Have you heard of the Sprengel pump? It’s how they drew hard vacuum back before mechanical pumps were perfected — the first light bulbs had their vacuums drawn with Sprengel pumps, for example. It worked by using droplets of a particular liquid to catch air particles, and push them out a narrow tube, thereby slowly evacuating a chamber. The catch is that that liquid used to be mercury, which isn’t something many of us have on hand in kilogram quantities anymore. [Gabriel Wolffe] had the brainwave that one might substitute modern vacuum pump oil for mercury, and built a pump to test that idea.
Even better, unlike the last (mercury-based) Sprengel pump we saw, [Gabriel] set up his build so that no glassblowing is required. Yes, yes, scientific glassblowing used to be an essential skill taught in every technical college in the world. Nowadays, we’re glad to have a design that lets us solder brass fittings together. Technically you still have to cut an eyedropper, but that’s as complex as the glasswork gets. Being able to circulate oil with a plastic tube and peristaltic pump is great, too.
If you try it, you need to spring for vacuum pump oil. This type of pump is limited in the vacuum it can draw by the vapor pressure of the fluid in use, and just any oil won’t do. Most have vapor pressures far in excess of anything useful. In the old days, only mercury would cut it, but modern chemistry has come up with very stable oils that will do nearly as well.
How well? [Gabriel] isn’t sure; he bottomed out his gauge at 30 inches of Mercury (102 kPa). It may not be any lower than that, but it’s fair to say the pump draws a healthy vacuum without any unhealthy liquid metals. Enough to brew up some tubes, perhaps.
Continue reading “Oil-Based Sprengel Pump Really Sucks”
A home-made vacuum pickup tool
Hackaday Prize 2022: Salvaged Pumps And Hoses Make A Neat Vacuum Pickup Tool
Anyone who’s ever assembled a PCB full of tiny SMD parts will have found that tweezers are not always the best tool when it comes to accurate positioning. Thin, flat components like microcontrollers can be awkward to pick up securely, while small resistors and capacitors have a tendency of snapping out of your tweezers’ grip and flying off into the sunset (or your carpet). Vacuum pickup tools can be a great help, but the most convenient models, with an electric air pump and a foot switch, can be a bit expensive. [sjm4306] shows that it doesn’t have to be that way: he built his “VacPen” mostly from reused components.
At the heart of the project is a little vacuum pump with a pen-like device hooked up to it through a flexible hose. The tip of the pen holds a pickup nozzle that came from a cheap manual pick and place tool. Both the pump and pen were salvaged from some gas analysis instrument that [sjm4306] tore apart a long time ago; the pen is especially convenient since it comes with a built-in brush-like filter that can trap any debris or tiny parts that might be accidentally swallowed.
The VacPen controller is housed inside a neat 3D printed enclosure that holds a custom PCB with an ATtiny microcontroller. The pump can be operated either through a foot switch, or by pressing on the touch-sensitive pad on top of the enclosure. [sjm4306] made this by soldering a wire to a copper penny and sticking it on the inside of the lid: simple, effective and cheap.
As you can see in the video embedded below, the VacPen is perfectly capable of picking up any kind of SMD component, and just as importantly, immediately releasing it at the desired moment. If you’re new to SMD technology, we can recommend this tutorial by [Bil Herd] that covers vacuum tweezers as well. If you’re more into automating vacuum pickup tools, this cool robot might be of your interest.
Continue reading “Hackaday Prize 2022: Salvaged Pumps And Hoses Make A Neat Vacuum Pickup Tool”
An Oil Diffusion Vacuum Pump From Thrift Store Junk
It seems like creating a vacuum should be a pretty easy job, but it turns out that sucking all the air out of something is harder than it seems. A cheap vacuum pump will get you part of the way there, but to really pull a hard vacuum, you need an oil diffusion pump that costs multiple tens of thousands of dollars.
Or, you need a bunch of thrift store junk, a TIG welder, and a can of WD-40. At least that’s what [Lucas] put into his homebrew oil diffusion pump. The idea of such a contraption is to vaporize oil in a chamber such that the oil droplets entrain any remaining gas molecules toward an exhaust port. His low-budget realization of this principle involved a lot of thrift store stainless steel cookware, welded together with varying degrees of success, with liberal applications of epoxy to seal up any leaks. And an electric smores cooker for the heating element, which was a nice touch. The low-budget approach extended even to the oil for the pump; rather than shelling out for expensive specialty oil, [Lucas] distilled some from a WD-40 silicone spray lubricant.
The video below details all the travails [Lucas] encountered along the way, plus the testing process. The results were at least encouraging — the diffusion pump was pulling vacuum far in excess of what the roughing pump was capable of. He clearly still has some work to do, but getting as far as he did with the scrap heap of parts he cobbled together is pretty impressive.
[Lucas]’ goal with all this? A fusion reactor. No, not that kind. This kind. Continue reading “An Oil Diffusion Vacuum Pump From Thrift Store Junk”
This Air Compressor Sucks
Vacuum is something most people learn about as children, when they’re first tasked with chores around the home. The humble vacuum cleaner is a useful home appliance and a great way to lose an eye as an inquisitive child. When it comes to common workshop tasks though, they can be a bit of a let down. When you need to pull some serious vacuum, you might wanna turn to something a little more serious – like this converted air compressor.
The build starts with a cheap off-the-shelf tyre inflator. These can be had for under $20 from the right places. They’re prone to overheating if used at too high a duty cycle, but with care they can last just long enough to be useful. The hack consists of fitting a hose barb connection over the intake of the pump, to allow air to be sucked out of whatever you’re trying to pull vacuum on. This is achieved with some hardware store parts and a healthy dose of JB-Weld. It’s then a simple matter of removing the valve adapter on the tyre inflator’s outlet so it can flow freely.
You might also consider adding a check valve, but overall this remains a cheap and easy way to get an electric vacuum pump for your workshop up and running. If that’s not quite your jam, you can always go down the handpump route instead.
This Bike Pump Now Sucks
Pulling a vacuum is something every proud maker must do once in a while. Whether you’re degassing epoxy or vacuum forming parts, you’ll need a reliable pump to get the job done. [drcrash] has just the guide to help – on how to convert a regular handpump to vacuum duty. (Video embedded after the break.)
[drcrash] recommends starting with a Slime brand 2060-A pump or similar. It’s a basic hand pump, with no pressure gauges or other frills to get in the way. It’s also got a strong steel shaft that can hold up to repeated use. You’ll also need some tubing and a check valve to get the job done.
The basic concept is to reconfigure the pump to suck air out of things rather than blowing it into them. By removing the original check valve and installing one in the opposite direction, and reversing the pump’s piston, it’s possible to pull good vacuum without breaking a sweat. [drcrash] reports that it’s possible to go up to 11 psi below atmospheric with this setup, which is plenty for a wide range of applications. If you need to go further, you can try building your own turbomolecular pump instead.
Continue reading “This Bike Pump Now Sucks”
Junk Bin Spin Coater Uses Modded Case Fan
We’ve all been there: you need a specific tool or gadget to complete a project, but it’s not the kind of thing you necessarily want to fork over normal retail price for. It could be something you’re only going to use once or twice, or maybe you’re not even sure the idea is going to work and don’t want to invest too much money into it. You cast a skeptical towards the ever-growing pile of salvaged parts and wonder…
Inspiration and a dig through the junk bin is precisely how [Nixie] built this very impressive spin coater for use in his ongoing homemade semiconductor project. If you’ve never had first hand experience with a spin coater, don’t worry, not many people have. Put simply, it’s a machine that allows the user to deposit a thin layer of material on a disc by way of centrifugal force. Just place a few drops in the center of the disc, then spin it up fast enough and let physics do the rest.
[Nixie] only needs to spin up a fairly tiny disc, and realized the hub of a 40x40mm brushless case fan was just about the perfect size. A quick pass through the lathe stripped the hub of its blades and faced off the front. Once he found a tube that was the exact same diameter of the fan’s axle, he realized he could even use a small vacuum pump to hold his disc in place. A proper seal is provided by 10 and 16 mm OD o-rings, installed into concentric grooves he machined into the face of the hub.
With a way to draw a vacuum through the hub of the spinner he just needed the pump. As luck would have it, he didn’t have to wait for one to make the journey from China, as he had one of those kicking around his junk bin from a previous project. The only thing he ended up having to buy was the cheap PWM fan controller which he mounted along with the modified fan to a piece of black acrylic; producing a fairly professional looking little piece of lab equipment. Check out the video after the break for a brief demonstration of it in action.
This isn’t the first specialized piece of gear [Nixie] has produced in his quest for DIY chips. We’ve previously covered his DIY tube oven as well as his vacuum chamber complete with magnetically controlled manipulator arm.
Continue reading “Junk Bin Spin Coater Uses Modded Case Fan”
