Hackaday Links: Sunday, July 14th, 2013
hackaday-links-chain
Wanting to repair his much-used NES controllers [Michael Moffitt] sourced a replacement for the rubber button pads. They didn’t work all that well but he fixed that by using angle clippers on the part that contacts the PCB traces.
Here’s a neat Claw Game project show-and-tell video. [Thanks David]
We already know that [Bunnie] is building a laptop. Here’s an update on the project.
Hackaday alum [Caleb Kraft] continues his helpful hacking by adding an alternative to clicking an Xbox 360 stick.
[Blackbird] added a camera to the entry door of his house. He didn’t want to forget to shut it off (wasting power) so he built an automatic shutoff.
We’re not really sure what this computational photography project is all about. It takes pictures with the subject illuminated in different colors then combines individual color channels with a MATLAB script.
Finally, [Dave Jones] tears down a Nintendo 64 console on a recent EEVblog  episode.
Shifting Gears On Your Pig Roasting Spit
bicycle-gear-pig-roaster
[Tim] and [Jon] have a hankering for some pork product of their own making. Your average residential kitchen is ill-equipped to handle an entire pig, so they got down to business building this pig spit out of old bicycle parts.
The main components in the project are two stands built out of square tube which go on either side of the cooking fire (coal bed?). They include bearings to support a horizontal bar on which a pig carcass is somehow mounted. The whole point of a spit is to turn it while cooking, and that’s where the gear system comes in. The front crank from a bicycle was welded onto the spit, with one pedal still in place. This way if the motorized system breaks down they can still turn the thing by hand.
The crank connects to the cogs with one chain, while the other chain connects the cogs to a windshield wiper motor. When connected to the specified 12V it turns around 6 rpm; close but a bit too fast. After some trial and error they found a 5V supply turns it at the optimal 2 rpm.
We wonder if you can put a whole pig in a meat smoker?
Continue reading “Shifting Gears On Your Pig Roasting Spit” →
Flying With A Little Help From Friends
flying-with-a-little-help-from-my-friends
A single cell of this distributed flight system can spin its propeller but it comes at the cost of the chassis flying out of control. To realize any type of stable flight it must seek a partnership with other cells. The more astute reader will be wondering how it can autonomously pair if incapable of controlled solo flight? The designers of the project thought of that, and gave each frame a way to propel itself on the ground.
Along the bottom rails of each cage there are several small knobby wheels. These seem to function similar to omniwheels since they are not aligned in parallel to each other. Pairing is accomplished mechanically by magnets, also helping to align the pogo-pins which connect the cells electronically.
Flight tests are shown in the video below. The array can be oriented in symmetrical or asymmetrical patterns and still work just fine. If they have 3D camera feedback they can hold position and navigate quite accurately. But this can also be piloted by remote control in the absence of such a feedback system.
Continue reading “Flying With A Little Help From Friends” →
Simple Looking Antique Internet Radio Has A Lot Under The Hood
rpi-internet-radioAt first glance you might not even notice that this 1934 radio has been altered. But close study of the tuning dial will tip you off that changes have been made. It still scrolls through stations just like the original. But it’s not a wheel with some numbers on it. The rotary motion is an effect produced by an LCD screen.
This is the second time we’ve seen one of [Florian Amrhein’s] Internet radio projects. The first used guts from a Laptop paired with an Arduino to pull everything together. This time he’s chosen to wield a Raspberry Pi board. It feeds a USB sound card for a bit better quality. A small amplifier board us used to power one large speaker behind the original grill of the radio.
Check out the demo video to see that radio dial in action. It’s delightful that he went to the trouble to emulate a rotating disc to keep with the theme of the project.
Continue reading “Simple Looking Antique Internet Radio Has A Lot Under The Hood” →
DIY Airbag, Explosions Included
AnAirbagSavedMyLife
Your car’s airbag is one of the major engineering accomplishments of the auto industry. In an accident, a whole host of processes must take place in sequence to keep your face from slamming into the steering wheel, and  everything must happen in just a fraction of a second. [Steve] over at Make thought it would be a cool idea to discover what actually goes in to saving a life with an airbag and decided to build his own.
The electronics of the build consisted of an accelerometer and an Arduino. A lot of research, development, and experimentation has gone into the algorithms that trigger airbags, but [Steve] decided to keep things simple: when a sudden acceleration is detected, set off a small charge of black powder.
The airbag itself is ripstop nylon reinforced with canvas, contained in a small wooded box fitted with hinged doors. All these components are put on wheeled aluminum test rig, manned with a honeydew melon crash test dummy, and pulled into a short wall at a few miles per hour.
Despite [Steve] not putting hundreds of thousands of man hours into the development of his airbag – unlike the ones you’ll find in your steering column – his device actually worked pretty well. While not a complete success, he did manage to come up with something that both looks and acts like the familiar device that has saved countless lives.
A Love Note In 14 Segments
14
[Terry] wanted to come up with a little electronics project for his kids, and also came up with something to keep the wife happy. It’s an adorable 14-segment love letter, pieced together with some leftover LED displays and a bit of solder.
There isn’t a microcontroller anywhere to be seen in this project – all the illuminated segments are tied to a switch, and aside from a few resistors there isn’t much to this circuit. The simplicity means it’s a great way for [Terry] to get his kids involved in electronics.
If you’re wondering why [Terry] didn’t throw multiple Arduinos, shift registers, or LED drivers into the build, consider this: sometimes segment displays can be static. The time circuit prop from Back to the Future (but not this modern recreation) was wired up in a similar manner, as only a few specific dates needed to be displayed. Either way, we’re thinking good on [Terry] for introducing his kids to a soldering iron and doing something special for his lady friend.
Resistance Decade Box Using DIP Switches
resistance-decade-box
Here’s a simple piece of equipment which you’ll be proud to display on your electronics bench. It’s a resistance decade box. The concept has been around forever — it offers the ability to tune a wide range of resistance values just by adjusting the controls. We especially like the clean look of this one, and think the use of DIP switches is a nice touch.
Check out the toggle switch at the top. It lets you disconnect the resistance values from the output in order to test them with your meter. It may not seem like much, but fudging your switch settings could end up smoking your target project. The value of that feature isn’t lost on us.
The DIP switches are mounted to some Radio Shack breakout boards which work perfectly for hosting the resistors as well. This keeps the inside of the enclosure nice and tidy. The final touch is the printed face plate applied to the cover of the box.
Like we’ve said, this one is nice but our favorite is still this one that uses thumbwheel switches to dial in a value.
