There’s a mystique around ribbon microphones due to their being expensive studio-grade items, which has led more than one experimenter down the rabbit hole of making one. [Catherine van West] has posted her experiments in the field, and it makes for an interesting read.
The recipe for a ribbon microphone is very simple indeed — suspend a corrugated ribbon of foil in a magnetic field, and take the voltage across the ribbon. But that simplicity hides some significant issues, as the foil is much thinner than the stuff you might roast your turkey under. Such lightweight foil is extremely fragile, and the signwriters leaf used here proved to be difficult to get right.
Then when the microphone is built there’s still the exceptionally low impedance and small voltage across the ribbon to contend with. The choice here is a transformer rather than a FET preamp, which surprised us.
The result is by all accounts a decent sounding microphone, though with some hum pickup due to difficulty with shielding. Should you give one a try? Maybe not, but that hasn’t stopped others from giving it a go.
