At least some in the audience will at some time in the distant past have loaded or saved a program on cassette, with an 8-bit home computer. The machine would encode binary as a series of tones which could be recorded to the tape and then later retrieved. If you consider the last sentence you’ll quickly realize that it’s not too far away from what a modem does, so can a modem record to cassette and decode it back afterwards? [Jesse T] set out to give it a try, and as it turns out, yes you can.
The modem talks and listens to the cassette recorder via circuitry that provides some signal conditioning and amplification, as well as making a dial tone such that the modem thinks it’s talking to a real phone line. An Arduino steps in as dial tone creator.
Of course, this is hardly a viable solution to 21st century data storage need, but that’s hardly the point as it’s a cool hack. We like it, and oddly we’ve seen a similar technique used with a retrocomputer in the past.
