Making A Laptop With A Mechanical Keyboard
A laptop is one of the greatest tools at the disposal of a hacker. They come in all manner of shapes and sizes with all manner of features. But perhaps the greatest limit held by all laptops is their chiclet keyboard. While certainly serviceable, a proper mechanical keyboard will always reign supreme, which is why [flurples] built a laptop around a mechanical keyboard.
Such a keyboard could not fit inside any normal laptop, so a custom machined case was in order. The starting point was a standard Framework Laptop 13. Its open source documentation certainly helped the project, but numerous parts such as the audio board and fingerprint sensor are not documented making for a long and tedious process. But the resulting machined aluminum case looks at least as good as a stock Framework chassis, all be it, quite a bit thicker.
Continue reading “Making A Laptop With A Mechanical Keyboard”
A New Mechanical Keyboard For An Old Computer
As computers age, a dedicated few work towards keeping some of the more interesting ones running. This is often a losing battle of sorts, as the relentless march of time comes for us all, human and machine alike. So as fewer and fewer of these machines remain new methods are needed to keep them running as best they can. [CallousCoder] demonstrates a way of building up a new keyboard for a Commodore 64 which both preserves the original look and feel of the retro computer but also adds some modern touches.
One of the main design differences between many computers of the 80s and modern computers is that the keyboard was often built in to the case of the computer itself. For this project, that means a custom 3D printed plate that can attach to the points where the original keyboard would have been mounted inside the case of the Commodore. [CallousCoder] is using a print from [Wolfgang] to get this done, and with the plate printed and a PCB for the keys it was time to start soldering. The keyboard uses modern switches and assembles like most modern keyboards do, with the exception of the unique layout for some of the C64 keys including a latching shift key, is fairly recognizable for anyone who has put together a mechanical keyboard before.
[CallousCoder] is using the original keycaps from a Commodore 64, so there is an additional step of adding a small adapter between the new switches and the old keycaps. But with that done and some amount of configuring, he has a modern keyboard that looks like the original. If you’re more a fan of the original hardware, though, you can always take an original C64 keyboard and convert it to USB to use it on your modern machines instead.
Continue reading “A New Mechanical Keyboard For An Old Computer”
An Elegant Writer For A More Civilized Age
One of the most exciting trends we’ve seen over the last few years is the rise of truly personal computers — that is, bespoke computing devices that are built by individuals to fit their specific needs or wants. The more outlandish of these builds, often inspired by science fiction and sporting non-traditional layouts, tend to be lumped together under the term “cyberdecks”, but there are certainly builds where that description doesn’t quite stick, including the Cyber Writer from [Darbin Orvar].
With a 10-inch screen, you might think it was intended to be a portable, but its laser-cut Baltic birch plywood construction says otherwise. Its overall design reminds us of early computer terminals, and the 60% mechanical keyboard should help reinforce that feeling that you’re working on a substantial piece of gear from yesteryear.
There’s plenty of room inside for additional hardware.
The Cyber Writer is powered by the Raspberry Pi Zero W 2, which might seem a bit underpowered, but [Darbin] has paired it with a custom minimalist word processor. There’s not a lot of detail about the software, but the page for the project says it features integrated file management and easy email export of documents.
The software isn’t yet available to the public, but it sounds like [Darbin] is at least considering it. Granted, there’s already distraction-free writing software out there, but we’re pretty firm believers that there’s no such thing as too many choices.
If you’re looking for something a bit more portable, the impressive Foliodeck might be more your speed.
Continue reading “An Elegant Writer For A More Civilized Age”
A New Case And Keyboard For The Timex Sinclair 1000
The Timex Sinclair 1000 was a sleek and compact machine, and the US counterpart to the more well-known Spectrum ZX-81. Timex may not have come to dominate the computer market, but the machine still has its fans today, with [skidlz] being one of them. That inspired them to craft a new case and keyboard for their beloved machine, putting a slimline twist on the old classic.
The new case finds some economies of size by eliminating the bulky RF modulator in favor of hacking in a cleaner composite out feed. In turn, this enabled the elimination of the channel switch that freed up more room. [skidlz] then designed a simple case using 2D laser-cut parts and dovetail joints, using superglue to assemble the individual pieces into a cohesive whole.
Meanwhile, the keyboard swap is obvious to anyone that ever used one of these things. The original was particularly unpleasant. In order to upgrade, [skidlz] decided to look to the compact Redragon K603 as an inspiration, giving the new build a longer travel and a nicer mechanical feel under one’s fingers.
The final result look great, and files are on Github for the curious. We’ve seen great work from [skidlz] before, too, in the form of this microcassette storage project. Meanwhile, if you’ve been cooking up your own retrocomputing projects, don’t hesitate to let us know!
A black OLED screen with a happy face displayed upon it is situated at the top of a squarish calculator with a 5x6 grid of white calculator keys. It floats above a graphing calculator, Nintendo Switch, aigo numpad, and an Arduino Mega on a white table. A handful of differently-colored kalih choc switches are in various places around the table.
Mechanical Switch Sci-Calc Is Also A Macropad
Smartphones have replaced a desktop calculator for most folks these days, but sometimes that tactility is just what you need to get the mathematical juices flowing. Why not spruce up the scientific calculator of yore with the wonders of modern microcontrollers?
While you won’t be able to use Sci-Calc on a standardized test, this classy calculator will let you do some pretty cool things while clacking on its mechanical choc switches. Is it a calculator? Obviously. Is it an Arduboy-compatible device that can play simple games like your TI-84? Yes. Is it also a macropad and ESP32 dev board? Why not? If that isn’t enough, it’s also takes both standard and RPN inputs.
[Shao Duan] has really made this device clean and the menu system that rewrites main.bin based on the program selection is very clever. Escape writes main.bin back into the ROM from the SD card so you can select another application. A few classic games have already been ported, and the process looks fairly straightforward for any of your own favorites.
If you’re hankering for more mathy inputs, checkout the Mathboard or the MCM/70 from 1974.
Continue reading “Mechanical Switch Sci-Calc Is Also A Macropad”
Reverse Time Back To The Days Of RPN
While Texas Instruments maintains dominance in the calculator market (especially graphing calculators), there was a time when this wasn’t the case. HP famously built the first portable scientific calculator, the HP-35, although its reverse-Polish notation (RPN) might be a bit of a head-scratcher to those of us who came up in the TI world of the last three or four decades. Part of the reason TI is so dominant now is because they were the first to popularize infix notation, making the math on the calculator look much more like the math written on the page, especially when compared to the RPN used by HP calculators. But if you want to step into a time machine and see what that world was like without having to find a working HP-35, take a look at [Jeroen]’s DIY RPN calculator.
Since the calculator is going to be RPN-based, it needs to have a classic feel. For that, mechanical keyboard keys are used for the calculator buttons with a custom case to hold it all together. It uses two rows of seven-segment displays to show the current operation and the results. Programming the Arduino Nano to work as an RPN calculator involved a few tricks, though. [Jeroen] wanted a backspace button, but this disrupts the way that the Arduino handles the input and shows it on the display but it turns out there’s an Arudino library which solves some of these common problems with RPN builds like this.
One of the main reasons that RPN exists at all is that it is much easier for the processor in the calculator to understand the operations, even if it makes it a little bit harder for the human. This is because early calculators made much more overt use of a stack for performing operations in a similar way to Assembly language. Rather than learning Assembly, an RPN build like this can be a great introduction to this concept. If you want to get into the weeds of Assembly programming this is a great place to go to get started.
A Lenovo Yoga with a mechanical keyboard, held up by its creator.
Mechanical Keyboard + Laptop = Clacktop
What do you do when your laptop keyboard breaks for the second time? Well, most people might use an external keyboard until they couldn’t take it anymore and bought a new machine. But [Marcin Plaza] isn’t most people.
It took more than twelve hours of CAD, but [Marcin] redesigned the case to be at least twice as thick as the Lenovo Yoga that inspired this project in order to accommodate a slimmed-down mechanical keyboard. Further weight-loss surgery was required in order to make the keyboard fit, but the end result is kind of a marvel of engineering. It’s marriage of sleek modernity and early laptop chonky-ness, and we love it.
Lacking a complete metal fab shop of one’s own, [Marcin] elected to have a board house fab it out of titanium and was quite surprised by the result. We really like the clear acrylic bottom, into which [Marcin] drilled many holes for airflow. Be sure to check out the build and demo video after the break.
Did you initially wonder whether the new case was printed? That’s totally a thing, too.
Continue reading “Mechanical Keyboard + Laptop = Clacktop”
