Pluto’s Not A Planet, But It Is A Spectrum Analyzer
The RTL-SDR dongles get most of the love from people interested in software-defined radio, but the Pluto is also a great option, too. [FromConceptToCircuit] shares code to turn one of these radios into a spectrum analyzer that sweeps up to 6 GHz and down to 100 MHz. You can see a video of how it works below.
While it may seem that 100 MHz is a bit limiting, there’s plenty of activity in that range, including WiFi, Bluetooth, radio systems, both commercial and amateur, and even cell phones.
Continue reading “Pluto’s Not A Planet, But It Is A Spectrum Analyzer”
Linamp, The IRL Winamp
Anyone who first experienced music on computers using Winamp probably shares a memory of seeing that classic UI for the first time. Everything about it was a step ahead of the clunky, chunky interfaces we were used to, and even though it was supposed to be unobtrusive, it was hard to tear your eyes off that silky-smooth spectrum analyzer bouncing out your favorite MP3s.
Recapturing a little of the Winamp magic is the goal of Linamp, an physical version of the classic media player. It reproduces the Winamp UI on a touchscreen LCD with a wide aspect ratio that almost perfectly matches the original layout. Behind the display is a Raspberry Pi 4 with a 32 GB SD card, with all the important connections brought out to a board on the back of the case. The case itself is a treat, as it borrows design elements from another bit of retro gear, the mini-rack audio systems that graced many a bookshelf in the 1980s — and powered many high school parties too, if memory serves.
To recreate the case, [Rodmg] designed a sheet metal case and had it custom-made from anodized aluminum by PCBWay. He also printed a bezel for the display that looks very similar to the Winamp window border, complete with control icons. Where the build really shines, though, is with the work [Rodmg] put into the software. He matched the original Winamp UI very closely, both in terms of layout and performance. The pains he went to to get the spectrum analyzer working, including a deep dive into FFT, are impressive.
The results speak for themselves on this one, and hats off to [Rodmg] for the effort and the ride on the nostalgia train. We don’t know if the recent announcement of Winamp’s impending open-sourcing will have much impact on this project, but it might result in a flood of new Winamp builds.
Spectrum Analyzer Buyer’s Guide
Having a scope in a home lab used to be a real luxury, but these days, its fairly common for the home gamer to have a sophisticated storage scope (or two) hanging around. Dedicated spectrum analyzers are a bit less common, but they have also dropped in price while growing in capabilities. Want to buy your very own spectrum analyzer? [Kiss Analog] has a buyer’s guide for what to consider.
If you’ve already got a scope, it may have a Fast Fourier Transform (FFT) function, and he talks about how it could be used in place of a spectrum analyzer or vice versa. But it really depends on what you’re planning on using it for. If you’re doing compliance testing for emissions, an analyzer is invaluable. If you like building transmitters or even just oscillators for other purposes, viewing the output on a spectrum analyzer can show you how well or poorly your design is performing. Any application where you need to visualize large swaths of the RF spectrum is a candidate for a spectrum analyzer.
Towards the end of the video, you’ll get to see some actual uses on a Uni-T UTS3021B. While those are at the higher end of the hobby price spectrum (no pun intended), it has many features that would have required an instrument ten times that price in years gone by.
There are also some very inexpensive options out there. While it is true, to a degree, that you get what you pay for, it is also true that even these cheap options would be amazing to an engineer from the 1990s. Yes, of course. You could do it with a 555.
Continue reading “Spectrum Analyzer Buyer’s Guide”
Putting The Magic Smoke Back Into A Dodgy Spectrum Analyzer
The trouble with fixing electronics is that most devices are just black boxes — literally. Tear it down, look inside, but it usually doesn’t matter — all you see are black epoxy blobs, taunting you with the fact that one or more of them are dead with no external indication of the culprit.
Sometimes, though, you get lucky, as [FeedbackLoop] did with this Rigol spectrum analyzer fix. The instrument powered up and sort of worked, but the noise floor was unacceptably high. Even before opening it up, there was clearly a problem; in general, spectrum analyzers shouldn’t rattle. Upon teardown, it was clear that someone had been inside before and got reassembly wrong, with a loose fastener and some obviously shorted components to show for it. But while the scorched remains of components made a great place to start diagnosis, it doesn’t mean the fix was going to be easy.
Figuring out the values of the nuked components required a little detective work. The blast zone seemed to once hold a couple of resistors, a capacitor, a set of PIN diodes, and a couple of tiny inductors. Also nearby were a pair of chips, sadly with the markings lasered off. With some online snooping and a little bit of common sense, [FeedbackLoop] was able to come up with plausible values for most of these — even the chips, which turned out to be HMC221 RF switches.
Cleaning up the board was a bit of a chore — the shorted components left quite a crater in the board, which was filled with CA glue, and a bunch of missing pads. This called for some SMD soldering heroics, which sadly didn’t fix the noise problem. Replacing the two RF switches and the PIN diodes seemed to fix the problem, albeit at the cost of some loss. Sometimes, good enough is good enough.
This isn’t the first time [FeedbackLoop] has gotten lucky with choice test equipment in need of repairs — this memory module transplant on a scopemeter comes to mind.
Continue reading “Putting The Magic Smoke Back Into A Dodgy Spectrum Analyzer”
An aluminium case with a small PCB and two nine-volt batteries inside
A Low-Noise Amplifier To Quantify Resistor Noise
Noise is all around us, and while acoustic noise is easy to spot using our ears, electronic noise is far harder to quantify even with the right instruments. A spectrum analyzer is the most convenient tool for noise measurements, but also adds noise of its own to whatever signal you’re looking at. [Limpkin] has been working on measuring very small noise signals using a spectrum analyzer, and shared his results in a comprehensive blog post.
The target he set himself was to measure the noise produced by a 50 Ohm resistor, which is the impedance most commonly seen on the inputs and outputs of RF systems. The formula for Johnson-Nyquist noise power tells us that the expected noise voltage in a one-hertz bandwidth is just 0.9 nanovolts – tiny by any standard, and an order of magnitude smaller than the noise floor of a typical spectrum analyzer. [Limpkin] therefore designed an amplifier and signal buffer to crank up the noise signal by a factor of 100, using ultra-low noise op amps running off a pair of nine-volt batteries.
There was a problem with this circuit, however: any stray DC voltage present at its input would also be amplified to levels that could damage the analyzer’s sensitive input port. To prevent this, [Limpkin] decided to add a clipper circuit to his amplifier. This consists of a pair of comparators that continuously monitor the amplifier’s output voltage and disconnect it through a silicon switch if it goes beyond 200 millivolts. [Limpkin] packaged his circuit in a beautifully-machined case and ran various tests to ensure the clipper worked reliably even in the presence of fast input transients.
With the clipper in place, it was safe to run the planned noise measurements. The end result? About 0.89 nV, just as predicted by theory. Measuring nanovolt-level signals usually requires extremely accurate equipment and lots of tricks to minimize noise. Sometimes though, noise is just what you need to make a radio transmitter. Thanks for the tip, [alfonso32]!
A bench setup with a spectrum analyzer and a PCB under test
Clever Test Rig Clarifies Capacitor Rules-of-Thumb
If you’ve done any amount of electronic design work, you’ll be familiar with the need for decoupling capacitors. Sometimes a chip’s datasheet will tell you exactly what kind of caps to place where, but quite often you’ll have to rely on experience and rules of thumb. For example, you might have heard that you should put 100 µF across the power supply pins and 100 nF close to each chip. But how close is “close”? And can that bigger cap really sit anywhere? [James Wilson] has been doing research to get some firm answers to those questions, and wrote down his findings in a fascinating blog post.
A PCB used to measure the effect of capacitor placement
The test board has two-layer and four-layer sections. The inter-layer capacitance greatly affects the PDN’s performance in each case.
[James] designed a set of circuit boards that enabled him to place different types of capacitors at various distances along a set of PCB traces. By measuring the impedance of such a power distribution network (PDN) across frequency, he could then calculate its performance under different circumstances.
The ideal tool for those measurements would have been a vector network analyzer (VNA), but because [James] didn’t have such an instrument, he made a slightly simpler setup using a spectrum analyzer with a tracking generator. This can only measure the impedance’s magnitude, without any phase information, but that should be good enough for basic PDN characterization.
The results of [James]’s tests are pretty interesting, if not too surprising. For example, those 100 nF capacitors really ought to be placed within 10 mm of your chip if it’s operating at 100 MHz, but you can get away with even 10 cm if no signals go much above 1 MHz. A bulk 100 µF cap can be placed at 10 cm without much penalty in either case. Combining several capacitors of increasing size to get a low impedance across frequency is a good idea in principle, but you need to design the network carefully to avoid resonances between the various components. This is where a not-too-low equivalent series resistance (ESR) is actually a good thing, because it helps to dampen those resonances.
Overall, [James]’s blog post is a good primer on the topic, and gives a bit of much-needed context to those rules of thumb. If you want to dive deeper into the details of PDN design or the inductance of PCB traces, our own [Bil Herd] has made some excellent videos on those topics.
Inspect The RF Realm With Augmented Reality
Intellectually, we all know that we exist in a complex soup of RF energy. Cellular, WiFi, TV, public service radio, radar, ISM-band transmissions from everything from thermometers to garage door openers — it’s all around us. It would be great to see these transmissions, but alas, most of us don’t come from the factory with the correct equipment.
Luckily, aftermarket accessories like RadioFieldAR by [Manahiyo] make it possible to visualize RF signals. As the name suggests, this is an augmented reality system that lets you inspect the RF world around you. The core of the system is a tinySA, a pocket-sized spectrum analyzer that acts as a broadband receiver. A special antenna is connected to the tinySA; unfortunately, there are no specifics on the antenna other than it needs to have a label with an image of the Earth attached to it, for antenna tracking purposes. The tinySA is connected to an Android phone — one that supports Google’s ARCore — by a USB OTG cable, and a special app on the phone runs the show.
By slowly moving the antenna around in the field of view of the phone’s camera, a heat map of signal strength at a particular frequency is slowly built up. The video below shows it in action, and the results are pretty cool. If you don’t have a tinySA, fear not — [Manahiyo] has a version of the app that supports a plain old RTL-SDR dongle too. That should make it easy for just about anyone to try this out.
And if you’re feeling deja vu about this, you’re probably remembering the [Manahiyo]’s VR spectrum analyzer, upon which this project is based.
Continue reading “Inspect The RF Realm With Augmented Reality”
