FloppoScope Is A Disk Image Analyzer
If you’re a big retro tech fan, you might still have a floppy drive on hand, or even some sort of high-end disk imaging solution. If you’re a little less committed, you may still have plenty of disk images on your hard drive for various reasons. Either way, you might find [0ldStaph]’s latest project to be useful for examining any disk images you have on hand.
FloppoScope is a browser-based tool for analyzing floppy disk images. Despite being browser-based, everything runs locally, so you’re not actually risking any sensitive data by using the tool—though we can’t imagine you’ve got too much Top Secret intel stored as floppy disk images, anyway.
The tool will draw you a nicely color-coded map of the disk layout and shows all the pertinent data for the filesystem of the image. It will even let you preview common file types if you need. The tool can also convert images between various formats, and spit out reports on things like bad sectors or corrupted files that have been detected. FloppoScope can handle everything from PC and Apple format disks, to Amiga, Atari DOS, and BBC Micro stuff. Oddities like various Sharp MZ machines and the NeXTSTEP format are included too. It works with both image and flux files, as well, so whichever way you captured your disks, it should work here.
We’ve looked at the importance of imaging remaining floppy disks quite recently. If you’ve got unpreserved disks sitting in your bedroom, shed, or study, consider getting on that as a matter of priority at this point!
Digital Signage In The Browser With Just A Click
There are many ways to display text on a computer screen, but most require at least some manual effort from the user. It’s annoying enough even if you’re dealing with one machine, but it gets even more of a hassle when you’re trying to display something on multiple devices of varying size and capability. That’s where BIGWORDS.PAGE by [SpeakingOfBrad] comes in.
It’s essentially a simple web page you can control via a carefully crafted URL, letting you create all sorts of text displays you can “distribute” to browsers on other devices with a simple link. So, for example, if you wanted to let everyone see what your favorite website is, you need only point the browser on your phone or laptop to https://bigwords.page/#Hackaday. As the image at the top of this post shows, you can also change the font and text colors by adding a few more values.
Continue reading “Digital Signage In The Browser With Just A Click” →
Hackaday Links Column Banner
Hackaday Links: August 16, 2026
We’re no strangers to unusual hardware failures around these parts, but even so, a swarm of jellyfish clogging up the works is a new one to us. That’s exactly what happened to the cooling system at the Gravelines nuclear power plant in France earlier this week, resulting in three reactors having to be shut down. This isn’t even an isolated incident, as POLITICO points out that the same thing actually happened last year around this same time.
So why are jellyfish staging an annual protest against nuclear power? A warming of the North Sea has extended breeding seasons and produced larger populations of the plankton that the jellyfish feed on. This is great for the gelatinous sea creatures, but not exactly ideal if you’re trying to pump the water they live in through a complex cooling system. The French installed filter screens and monitoring systems after this happened in 2025, but clearly they’re going to need to keep working on the problem.
From a new problem to a very old one, a BBC investigation has revealed that the UK’s National Health Service (NHS) Blood and Transplant department was inadvertently leaking private patient data by sending it in the clear over the pager network. Sniffing pager messages was fairly trivial decades ago, and is even easier these days thanks to the proliferation of cheap software-defined radios and open source decoding software. Given the fragility of the underlying communication network they use, the NHS announced they were going to stop using pagers by 2021, but clearly not everyone got the memo.
Continue reading “Hackaday Links: August 16, 2026” →
Dress Up Your YubiKey With This Web-Based Tool
The combination of hardware required to make use of this project is specific enough that we imagine only a relatively limited number of readers will actually be able to try it out. But if you do happen to own a YubiKey and either a laser engraver capable of marking it or a fancy UV printer, [madeinoz67] has put together an awesome tool for adding some visual flair to your two-factor authentication device.
Running it is as simple as opening a web page, because that’s exactly how it’s implemented. You can either host it yourself or just launch it right from the GitHub repository. After opening the HTML file, you’re presented with a fairly intuitive user interface that lets you draw on top of a 2D outline of the YubiKey itself so you can get a better idea of what the final product will look like.
You can pick from an array of vector icons, upload your own images, and add custom text. There’s a pull-down at the top that lets you pick which specific YubiKey you want to work with, and there are different views depending on whether you plan on blasting your handiwork onto the device with a laser, doing a full-color UV print, or cutting it out of vinyl with something like a Cricut.
Even if you don’t have a YubiKey that’s begging for some custom artwork, we think there’s a lot to learn from this project. Obviously there are some very valid reasons to be concerned about how much of our modern software can only be accessed through a browser. If you’re going to use web technologies to create a piece of software, the least you could do is make it offline and self-contained like [madeinoz67] has.
Now if you’ll excuse us, we’ve got to go warm up the UV printer.
Hackaday Links: April 26, 2026
It’s been three weeks since the Artemis II crew returned to Earth, and while the mission might be over for Reid Wiseman, Victor Glover, Christina Hammock Koch, and Jeremy Hansen, the work is only just beginning for engineers back at NASA. In a blog post earlier this week, the space agency went over the preliminary post-mission assessments of the spacecraft and its ground support equipment, and detailed some of the work that’s currently taking place as preparations begin for Artemis III.
During Artemis I, higher than expected damage was noted on both the Orion’s heat shield and the Space Launch System (SLS) launch pad. But according to NASA, the changes implemented after that first mission seem to have prevented similar issues this time around. The post also explains that reusable components of the Orion spacecraft, such as the avionics and the crew seats, are already in the process of being removed from Integrity so they can be installed in the next capsule on the production line.
While watching the live stream of the Artemis mission is the closest most of us will ever get to experiencing spaceflight, that doesn’t mean you can’t explore the solar system from the comfort of your own home — or more specifically, your browser. [Sani Huttunen] has created an incredible web-based solar system simulator that lets you explore our celestial neighborhood throughout different periods of time. You can tour the moons of Jupiter, see how the planets aligned on the date of your birth, and even check in on the Voyager probes. There are some very valid reasons to be skeptical about software moving to the web, but we’ve got to admit, this is a very slick demonstration of just how far modern browsers have come.
Continue reading “Hackaday Links: April 26, 2026” →
Avoid Missed Connections With The Connectorbook’s Web Tool
Connectors are wonderful and terrible things. Wonderful, in that splicing wires every time you need to disassemble something is really, really annoying. Terrible in that it can be just such an incredible pain-in-the-assets to find the right one if you’re stuck with just a male or a female for some unfortunate reason. We’ve all been there, and all spent time growing increasingly frustrated poring over the DigiKey catalog (or its local equivalent) trying to figure out what the heck we were dealing with. That’s why [Davide Andrea]’s The Connectorbook exists–and even better, the free web service they call Identiconn.
The tool isn’t super new–the Wayback Machine has snapshots of it dating back to 2021–but it’s still very much worth highlighting. There’s a “quick pick” option that lets you narrow it down with photos, or if you want to get specific there are dozens of filters to try and help you find your exact part. You can filter based on everything from the pitch and geometry of the connectors, to how it terminates, attachments, latches, et cetera. While we can’t guarantee the database is fully exhaustive, it looks pretty darn big, and using it is going to be a lot less exhausting than pouring through catalogs hoping that particular vendor or manufacturer lists the matching part.
Some might argue that this database is not a hack, but it’s certainly going to enable a certain amount of hacking. That’s why we’re grateful to [Alex] for the tip! If you’ve got a know tool you think we all should know about that hasn’t been shared yet, please let us know.
Keep Tabs On Your Vehicle’s Needs With LubeLogger
It doesn’t matter if its a Vespa or a Peterbilt truck — if you ignore the maintenance needs of your vehicle, you do so at your own peril. But it can be difficult enough to keep track of basic oil changes, to say nothing of keeping records on what parts were changed when. Instead of cramming more receipts into your glove box, maybe give LubeLogger a try.
This free and open source software tool is designed to make it easy for individuals to keep track of both the routine maintenance needs of their vehicles, as well as keep track of any previous or upcoming repairs and upgrades. Released under the MIT license, LubeLogger is primarily distributed as a Docker image that makes it easy to self-host the tool should you wish to keep your data safe at home rather than on somebody’s server out in the Wild West of the modern Internet.
Continue reading “Keep Tabs On Your Vehicle’s Needs With LubeLogger” →
