Google Home Meets ESP8266
[Luc Volders] is building his own smart house with the help of Google Home and an ESP-8266. Inspired by the house computers from the TV show, Eureka [Luc] created an IoT ecosystem using a mix of off the shelf devices and open source software.
There are about a thousand ways to create a DIY smart home these days. All of them involve setting up a command receiver (like Amazon’s Echo or Google Home), some sort of cloud connection, and an end device controller. This can get complex for the beginner. [Luc’s] article is great because he walks is through each step tutorial style. He even keeps things simple by programming the ESP8266 using BASIC with ESP-BASIC.
[Luc] uses If This Then That (IFTT) as his cloud service. IFTT is the glue between Google’s cloud service and the ESP8266 connected to his home WiFi network. Speaking of which, [Luc] shows how to set up port forwarding on the router so all accesses to port 8085 go to the ESP8266. Not exactly strong security – but it’s better than opening the entire home network.
You don’t need a real Google home device for this hack. You can build your own with a Raspberry Pi. Once that is set up you can do everything from turning on lights to watering your lawn.
Continue reading “Google Home Meets ESP8266”
How Has Amazon Managed To Make Hackers Love Alexa?
Our hackspace has acquired an Amazon Dot, courtesy of a member. It mostly seems to be used as a source of background music, but it has also spawned a seemingly never-ending new entertainment in which the hackspace denizens ceaselessly bait their new electronic companion with ever more complex and esoteric requests. From endless rephrasing and careful enunciation of obscure early reggae artists to try to settle a musical argument to hilarious mis-hearing on the part of our silicon friend, the fun never stops. “Alexa, **** off!” it seems results in “I’m sorry, I can’t find a device of that name on this network”.
amazon-dot-always-listeningThat is just the experience of one hackspace, but it evidently does not end there. Every other day it seems that new projects using Alexa pass through the Hackaday timeline, so it looks as though Amazon’s online personal assistant has been something of a hit within our community.
Fair enough, you might say, we’re always early adopters of any new technology. But it’s a development over which I wonder; am I alone in finding it surprising? It’s worth taking a moment to look at the subject.
Continue reading “How Has Amazon Managed To Make Hackers Love Alexa?”
Voice Activated Fireplace Is As Cool As It Gets
A fireplace can add a cozy, relaxed atmosphere  — and a touch of style — to any home. Redditor [hovee] saw the opportunity to add some flair to his gas fireplace by making it voice activated. Check out the video of it in action below.
Google Home and Google Assistant provides the voice recognition component. A Raspberry Pi 3 with Home Assistant does the legwork. An iTach TCP/IP-to-Contact-Closure relay toggles the fireplace, and an IFTTT account connected to Google Assistant brings it all together.
[hovee] then ran some thick 16/2 wire from the relay network port to the fireplace’s remote receiver circuit to actually turn it on. Some custom code and configuration of the Home Assistant files was necessary, but [hovee] has shown his work, with some tips besides, if you want to throw together a similar setup. It’s a help if your fireplace has a ‘remote’ setting, and a double bonus if there is documentation for the fireplace to be found that will help with the build process.
Once done, all you need to do is kick back with your favorite beverage in the lap of home automated luxury. Just be sure you have a backup to turn off your fireplace just in case your setup goes the way of Skynet. While you’re at it, you can set up your fireplace to save energy as well.
[via /r/homeautomation]
Continue reading “Voice Activated Fireplace Is As Cool As It Gets”
