DIY AVR USB RGB LED Notifier
LED_notifier_in_place
Giving us a chance to break out the TLAs, [Blair] sent in his latest hack where he embedded an RGB LED into his EeePC to display twitter, pidgin, and email notifications. It is based around the ATtiny45, and requires very few additional parts. He based the project on a foundation of work laid by [Dennis Schulze] on notifications and the work of [Dave Hillier] that used V-USB, a library for implementing USB on AVRs. The entire circuit was done freehand and crammed inside the netbook. He says that it is a lot easier to see notifications, even when the laptop is shut.
Related: Email notification via RGB LED
C64 USB Keyboard
breadboard
[Maarten] told us about a C64 USB keyboard that was modified to be used as a standard input device. An interesting aspect of the project is the use of V-USB (formerly known as AVR-USB). V-USB is a software only approach to slow speed USB HID. In essence this is a two fold mod, The C64 keyboard is patched to a PC, and an off the shelf AVR is software-hacked to bit bang the USB communications. The author notes an initial problem with multiple key presses that was later corrected in the application. For the other side of the spectrum, we had covered the C64 twittering client, and a commodore 64 laptop.
Parts: Ferrite Beads
ferrite-bead.ii
Ferrite beads (L1 in the photo) filter high frequency power supply noise by converting it into a tiny amount of heat. Power supply noise can cause various problems for many parts, especially in analog audio and display circuits.
Ferrite beads are simple, but choosing one can be confusing because they’re not commonly used by hobbyists. Most designs will still work if you omit the ferrite bead(s), but beads are so cheap there’s no reason to sacrifice the added reliability they provide. We describe how we pick ferrite beads for our projects after the break.
Continue reading “Parts: Ferrite Beads” →
Tennis Practice For Hackers
wiimotetennis2
Here’s an interesting WiiMote based project. [Mans] is a tennis fan, though a bit out of practice. With the tennis season coming to a rather climactic end, he got excited and wanted to brush up on his skills. He found the toss part of his serve to be very sloppy. Being a hacker, the first thing he thought was that there must be some way of tracking and graphing his toss so that he could improve it in an intelligent and controlled manner. The WiiMote seemed a perfect fit for this. Only a small modification was necessary, an external button wired to the internal “-” button. This switch is active while he’s holding the ball, and inactive when the ball is released. In this manner, he can track and chart his toss to find out exactly where he needs improvement.  He uses [Johnny Chung Lee]’s code, with a small but unspecified modification to write the accelerometer data to a text file.
As he points out, this could be very usefull for any repetitive movement. Whith accelerometers getting cheaper and cheaper, there’s nothing stopping you from using multiple ones either. Imagine a golf rig to analyze your swing, Maybe a boxing rig that measured your hip twist and arm extension, or possibly a yoyo glove to tell you if your flick needs some help. Great job [Mans].
Automated Dorm Room Door
[youtube=http://www.youtube.com/watch?v=46s7nE72nvI]
[Chris] wrote in to tell us about this project he did while living in the dorms. He built a system to automate his dorm room door. It handles unlocking and opening/closing the door via iPhone, secret knock, and even the key.  The lock/knob portion is handled by a servo while the opening/closing action is hydraulic. After living with it for a year, he says that it never gets old, but there were a few bugs. Apparently it would randomly open in the middle of the night sometimes. If you’re interested in doing something like this, but not damaging the door, maybe you should check out the RFID dorm door lock project.
