Bringing IMessage To The Mac
If you’ve invested in the Apple ecosystem, the joys of iMessage likely illuminate your life. Your phone and desktop and laptop all sync your messages. But what if your desktop is running Mac OS 9 or System 2? This is where [CamHenlin’s] MessagesForMacintosh comes in.
Unfortunately, it does require a more modern Mac to act as an access point into the wider iMessage network. The modern Mac sets up a GraphQL database that can be accessed. Then a serial cable connects your “retro daily driver” to a translation layer that converts the serial commands into GraphQL commands. This could be something simple and network-connected like an ESP32 or a program running on your iMessage Mac. [CamHenlin] has a second Mac mini in his demo, seen above.
[CamHenlin] leverages his library known as CoprocessorJS. It allows older machines to hand off complex workloads to more modern machines, allowing modern machines to act as a coprocessor. Getting a single binary to run across many different versions of Mac OS and System is tricky and there were a few tricks involved. Retro68 is a C++17 compiler that targets PowerPC and 68k architectures. Additionally, Nuklear Quickdraw is used to provide a GUI in a performant manner.
It is always a joy to see older hardware do new tricks, often with the help of a bit of modern hardware. Connecting your Mac to the internet can be as easy as Pi.
Glassblowing For The Lab
There was a time when ordering some glassware from a distributor meant making a sizable minimum order, sending a check in the mail and waiting weeks for a box full of — hopefully intact — glassware to arrive. In those days, blowing your own glassware from glass tubes was fairly common and [Wheeler Scientific] has been doing a series on just how to do that. Even if you aren’t interested in building a chemistry lab, you might find the latest episode on making a gas discharge tube worth a watch. There are several videos and you can see a few of them below.
Of course, blowing glass is literally playing with fire, so be careful. Most important rule? Don’t inhale. Then again, for a lot of things, blowing glass doesn’t involve you actually blowing, but it is more like bending and shaping and — technically — what he shows is lampwork, not actual glassblowing, but that’s a technicality.
Continue reading “Glassblowing For The Lab”
Automated Chess Board Plays You
If you’ve ever played chess or even checkers, you’ve probably thought about making a board that lets a computer play you without having to enter your moves and look at the board on a screen. [Greg06] not only thought about it, but he built it.
The board looks great and uses foamboard which makes it easy to reproduce. Each piece has a small magnet within and an electromagnet on an XY motion system can selectively pick up and move pieces. In addition, a reed switch under each square can tell if a square is occupied or not.
Continue reading “Automated Chess Board Plays You”
the active foil flying across the water
Hydrofoils Love This One Simple Trick
Earlier in the year, [rctestflight] created an active hydrofoil RC craft but found the actual performance very lacking. Luckily for him and for us, he continued to tweak it and one tweak suddenly turned it from a nightmare to a dream.
That tweak was adding ArduPilot’s airplane model. The design had three servos, which each actuated the angle of a foil underneath one of the three pontoons. The ship propelled itself via some propellers mounted near the top. If you know much about ArduPilot, you notice that active hydrofoil boat doesn’t show up on the list of supported platforms, and you’re right. [rctestflight] points out that the three servos actually function as a plane underwater. The front two are ailerons and the back one is an elevator, all things that ArduPilot knows how to handle with a tightly controlled loop except for one thing; there’s no altitude data.
So he stole a trick he developed earlier for his ground effect plane and used a distance sensor to let ArduPilot know how to adjust things. He used a sonar sensor instead of lidar as it works better with water and he was pleasantly surprised when he took it out on the lake and it just worked wonderfully. The original goal with the active stabilization was to have the efoil immune to choppy waters, and we’re sad to say that it didn’t quite reach that lofty target. The single sonar sensor follows the wave in front of it beautifully but can’t handle the complex waves being thrown at it. Perhaps some sort of sensor fusion algorithm could provide the necessary data to be truly resilient. But we love watching the foil glide across the water and it is hard to remember that it’s actively flying rather than just floating that way.
Others have tried and failed to 3D print a hydrofoil while others have succeeded. We love that [rctestflight] came back to finish the fight and came away a champion. Video after the break.
Continue reading “Hydrofoils Love This One Simple Trick”
Al Williams Tells All In The Logic Simulation Hack Chat
The list of requirements for hosting one of our weekly Hack Chats is pretty short: you’ve got to be knowledgeable, passionate, and above all else, willing to put those two quantities on display for a group of like-minded strangers. Beyond that, we’re not too picky. From industry insider to weekend hobbyist, high school dropout to double doctorate, if you’ve got something interesting to talk about, we’re ready to listen.
But in casting a such a wide net, we occasionally forget that we’ve got a considerable collection of potential hosts within our own worldwide roster of contributors. Among this cast of characters, few can boast the same incredible body of knowledge as Al Williams, who was able to pencil in some time this week to host the Logic Simulation Hack Chat.
Or at least, that was the idea. In reality the Chat covered a wide range of topics, and was peppered with fascinating anecdotes pulled from Al’s decades of experience in the field. Though to be fair, we expected no less. He was building hardware before many of us were born, and can take credit for designs that have been at the bottom of the ocean as well as launched into orbit. He’s been writing about it just as long too, with articles of his appearing in iconic print magazines such as Dr. Dobb’s Journal.
Al has seen and done so much that he still surprises us with the occasional nugget, and we’ve been working with him for years. It was only a week or two back that he started a story with “Back when I used to manage a gas pipeline…” in the middle of a conversation about utility metering.
Of course, that’s not to say some technical discussion didn’t sneak in there from time to time. Sure Al’s  recollection of how they used to literally crawl over the schematics for the 68000 back at Motorola might stick out as a particular high point, but he also explains his personal preference for vendor-specific software tools over their more generic open source counterparts. He also draws comparisons between hardware description languages (HDLs) like Verilog and parametric CAD tools such as OpenSCAD in the way that they help model complex relationships in ways that can’t be easily done by more traditional means.
At one point the conversation lingers on the design and production of application-specific integrated circuits (ASICs), and how they compare to field-programmable gate arrays (FPGAs). Traditionally ASICs have been out of reach for the hobbyist, but with the recent collaboration between Google and SkyWater Technology to create an open source process design kit (PDK), they’re now within the capabilities of a dedicated individual. Matt Venn spoke on the topic during Remoticon 2021, and it’s good to see more folks in the community openly discussing the possibilities of custom silicon designed by hackers.
From there, things start really getting wild. From dreaming of virtual reality circuit simulators that let you fly amongst your creations like in Tron, to salivating over high-end technologies such as reflective memory, this Chat really runs the gamut. But then, that’s sort of why we hold them in the first place. Whether you actively participate or are just along for the ride, the Hack Chat gives everyone in the community a chance to gather around a virtual water cooler with fascinating characters that you won’t find anywhere else.
The Hack Chat is a weekly online chat session hosted by leading experts from all corners of the hardware hacking universe. It’s a great way for hackers connect in a fun and informal way, but if you can’t make it live, these overview posts as well as the transcripts posted to Hackaday.io make sure you don’t miss out.
Hackaday Podcast 158: Phased Array Physics, CRTs Two Ways, A Micro Microcontroller, And A Surgically Implanted Red Herring
Join Editor-in-Chief Elliot Williams and Staff Writer Dan Maloney as they take a look at the week’s top stories, taken straight off the pages of Hackaday. What happens when you stuff modern parts into a 90’s novelty PC case? Nothing good, but everything awesome! Is there any way to prevent PCB soil moisture sensors from being destroyed by, you know, soil moisture? How small is too small for a microcontroller, and who needs documentation anyway? We also cast a jaundiced eye — err, ear — at an electronic cheating scandal, and if you’ve ever wondered how phased arrays and beam steering work, gazing into a pan of water might just answer your questions. We also share all our soldering war stories, and hey — what’s with all these CRT projects anyway?
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct Download (52 MB, but sounds like at least 58 MB!)
Continue reading “Hackaday Podcast 158: Phased Array Physics, CRTs Two Ways, A Micro Microcontroller, And A Surgically Implanted Red Herring”
Are Apple Trying To Patent The Home Computer 45 Years Too Late?
In our recent piece marking the 10th anniversary of the Raspberry Pi, we praised their all-in-one Raspberry Pi 400 computer for having so far succeeded in attracting no competing products. It seems that assessment might be premature, because it emerges that Apple have filed a patent application for “A computer in an input device” that looks very much like the Pi 400. In fact we’d go further than that, it looks very much like any of a number of classic home computers from back in the day, to the extent that we’re left wondering what exactly Apple think is novel enough to patent.
A Raspberry Pi 400 all-in-one keyboard console computer
Looks pretty similar to us.
Reading the patent it appears to be a transparent catch-all for all-in-one computers, with the possible exception of “A singular input/output port“, meaning that the only port on the device would be a single USB-C port that could take power, communicate with peripherals, and drive the display. Either way, this seems an extremely weak claim of novelty, if only because we think that a few of the more recent Android phones with keyboards might constitute prior art.
We’re sure that Apple’s lawyers will have their arguments at the ready, but we can’t help wondering whether they’ve fallen for the old joke about Apple fanboys claiming the company invented something when in fact they’ve finally adopted it years after the competition.
Thinking back to the glory days of 8-bit computers for a moment, we’re curious which was the first to sport a form factor little larger than its keyboard. Apple’s own Apple ][ wouldn’t count because the bulk of the machine is behind the keyboard, but for example machines such as Commodore’s VIC-20 or Sinclair’s ZX Spectrum could be said to be all-in-one keyboard computers. Can anyone provide an all-in-one model that predates those two?
You can read our Raspberry Pi 400 review if the all-in-one interests you.
Via Extreme Tech.
