Fire Extinguishers, Optical Density Ratings And Safely Using Home Lasers
Ski goggle type laser safety lenses may look dorky, but they leave no gaps and fit around glasses. (Credit: FauxHammer, YouTube)
After [Ross] from FauxHammer miniature model fame got lured into reviewing laser engravers and similar via the Bambu Lab H2D’s laser module, he found himself getting slightly nervous about the whole ‘safety’ aspect of these lasers. After all, lasers can not only light stuff on fire, but it’s a well-known fact that even reflected laser light can be sufficient to cause permanent damage to your retinas. Or worse.
Since your eyes generally do not regenerate, it makes sense to get caught up on laser safety before turning on one of those plentiful-and-increasingly-affordable home laser systems for engraving and/or cutting.
While the issue of stuff catching on fire is readily solved by having a good CO2 extinguisher – and plan B options – at the ready, for safety glasses it’s significantly more complex. There’s not just the issue of finding glasses that block the wavelength of the laser system that you are using, but also with the right optical density (OD) rating. Every mm of the safety lens material can attenuate a certain amount of laser light at the given wavelength, so the OD rating of your laser safety goggles need to match the laser’s power output level, or you might be living with a false sense of security.
Finally, there is the issue of the smoke and fumes produced by these lasers as they obliterate the target material. Much of what is in this smoke you do not want to breathe in, even ignoring long-term dust and VOC exposure issues, so having a solid fume extraction setup and PPE as necessary are absolute necessities. As [Ross] puts it, you don’t want to breathe in the smell of regret today, for your future self to reflect on a decade from now.
Work safe, work smart, don’t become the subject of a laser safety PSA.
Continue reading “Fire Extinguishers, Optical Density Ratings And Safely Using Home Lasers”
BCacheFS Is Now A DKMS Module After Exile From The Linux Kernel
It’s been a tense few months for users of the BCacheFS filesystem, as amidst the occasional terse arguments and flowery self-praise on the Linux Kernel mailing list the future of this filesystem within the Linux kernel hung very much in the balance. After some initial confusion about what ‘externally maintained’ means in Linux parlance, it’s now clear that this means that BCacheFS has effectively been kicked out of the kernel as [Linus] promised and will ship as a DKMS module instead. The gory details of this change are discussed in a recent video by [Brodie Robertson].
We covered the BCacheFS controversy in the Linux world a few months ago, amidst reports of data loss and filesystem corruption among its users. Its lead developer, [Kent Overstreet], came to blows with [Linus Torvalds] on the LKML after [Kent] insisted on repeatedly pushing new features into kernel release candidate branches along with rather haughty statements on why he should be able to do this.
To make a long story short, [Linus] didn’t like this and froze BCacheFS support in the current kernel release with all future in-kernel development ceased. Distributions like SuSE have initially said that will disable BCacheFS starting in kernel version 6.17, meaning that users of BCacheFS may now have to install the DKMS module themselves. Some distributions like Arch are likely to include this DKMS module by default, which is something you want to check if you use this filesystem.
Continue reading “BCacheFS Is Now A DKMS Module After Exile From The Linux Kernel”
Test Pattern Generator For SCART And RGB TVs
CRTs don’t last forever, and neither do the electronics that drive them. When you have a screen starting to go wonky, then you need a way to troubleshoot which is at fault. A great tool for that is a pattern generator, but they’re not the easiest to come by these days. [baritonomarchetto] needed a pattern generator to help repair his favourite arcade machine, and decided to make his own DIY Portable RGB CRT Test Pattern Generator.
One of the test patterns available from the device. This TV appears to be in good working order.
While he does cite [Nicholas Murray]’s RP2040 test pattern generator as a starting point (which itself builds on the PicoVGA library once featured here), he couldn’t just build one. That worthy project only outputs VGA and because [baritonomarchetto] is in Europe, he needed a SCART connector. Since he’s working on arcade machines, he needed non-SCART RGB signals, too. The arcade signals need to be at higher voltages (TLL level) than the RGB signal you’d find in SCART and VGA.
The upshot is while he’s using [Nicholas]’s code for the RP2040, he’s rolled his own PCB, including a different resistor ladders to provide the correct voltages depending on if he’s dealing with a home TV or arcade CRT. To make life easier, the whole thing runs off a 9V battery.
If you’re wondering what the point of these test patterns is, check out this 1981-vintage pattern generator for some context from the era. If a digital replica doesn’t float your boat, it is possible to recreate the original analog circuitry that generated these patterns back when the CRT was king.
Photo of the Haasoscope Pro
Haasoscope Pro: Open-Everything 2 GHz USB Oscilloscope
Our hacker [haas] is at it again with the Haasoscope Pro, a full redesign of the original Haasoscope, which was a successful Crowd Supply campaign back in 2018.
This new Pro version was funded on Crowd Supply in April this year and increases the bandwidth from 60 MHz to 2 GHz, the vertical resolution from 8 to 12 bits, and the sample rate from 125 MS/s to 3.2 GS/s. Selling for $999 it claims to be the first open-everything, affordable, high-bandwidth, real-time sampling USB oscilloscope.
The firmware and software are under active development and a new version was released yesterday.
Continue reading “Haasoscope Pro: Open-Everything 2 GHz USB Oscilloscope”
Unobtanium No More; Perhaps We Already Have All The Elements We Need
It’s been a trope of the news cycle over the past decade or so, that there’s some element which we all need but which someone else has the sole supply, and that’s a Bad Thing. It’s been variously lithium, or rare earth elements, and the someone else is usually China, which makes the perfect mix of ingredients for a good media scare story. Sometimes these things cross from the financial pages to the geopolitical stage, even at times being cited in bellicose language. But is there really a shortage?
The Colorado School of Mines say perhaps not, as they’ve released a paper  from an American perspective pointing out that the USA already has everything it needs but perhaps doesn’t realize it. We’re surprised it seems to have passed unnoticed in a world preoccupied with such matters.
We’ve covered a few stories about mineral shortages ourselves, and some of them even point to the same conclusion reached by the School of Mines, that those mineral riches lie not in the mines of China but in the waste products closer to American industry. In particular they point to the tailings from existing mines, a waste product of which there is a huge quantity to hand, and which once stripped of the metal they were mined for still contain enough of the sought-after ones to more than satisfy need.
The history of mining from medieval lead miners processing Roman tailings to 19th century gold miners discovering that their tailings were silver ore and on to the present day, includes many similar stories. Perhaps the real story is economic both in the publicity side and the mining side, a good scare story sells papers, and it’s just cheaper to buy your molybdenum from China rather than make your own. We’ll keep you posted if we see news of a tailings bonanza in the Rockies.
Hackaday Podcast Episode 338: Smoothing 3D Prints, Reading CNC Joints, And Detecting Spicy Shrimp
This week, Hackaday’s Elliot Williams and Kristina Panos met up over the tubes to bring you the latest news, mystery sound, and of course, a big bunch of hacks from the previous seven days or so.
In Hackaday news, we’ve got a new contest running! Read all about the 2025 Component Abuse Challenge, sponsored by DigiKey, and check out the contest page for all the details. In sad news, American Science & Surplus are shuttering online sales, leaving just the brick and mortar stores in Wisconsin and Illinois.
On What’s That Sound, it’s a results show, which means Kristina gets to take a stab at it. She missed the mark, but that’s okay, because [Montana Mike] knew that it was the theme music for the show Beakman’s World, which was described by one contestant as “Bill Nye on crack”.
After that, it’s on to the hacks and such, beginning with a really cool way to smooth your 3D prints in situ. JWe take a much closer look at that talking robot’s typewriter-inspired mouth from about a month ago. Then we discuss several awesome technological feats such as running code on a PAX credit card payment machine, using the alphabet as joinery, and the invention of UTF-8 in general. Finally, we discuss the detection of spicy shrimp, and marvel at the history of email.
Check out the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Download in DRM-free MP3 and savor at your leisure.
Continue reading “Hackaday Podcast Episode 338: Smoothing 3D Prints, Reading CNC Joints, And Detecting Spicy Shrimp”
A photo of the internal wiring.
Imagining The CPS-1: An Early 70s 4-bit Microcomputer From Canada
[Michael Gardi] wrote in to let us know about his project: CPS-1: Imagining An Early 70s 4-bit Microcomputer.
The CPS-1 was the first Canadian microprocessor-based computer. It was built by Microsystems International Ltd. (MIL) in Ottawa between 1972 and 1973 and it is unknown how many were made and in what configurations. The CPS-1 supported a 12-bit address bus and a 4-bit data bus. MIL also developed the supporting hardware including RAM. The processor was called the MIL 7114.
[Michael] worked in collaboration with [Zbigniew Stachniak] from York University Computer Museum. [Zbigniew] had developed a MIL CPS-1 Emulator and [Michael]’s job was to implement a front panel hardware interface for the emulator which runs on a Raspberry Pi. The only complication: there are no remaining CPS-1 computers, and no known photographs, so no one can say for sure what a real front panel might have looked like!
With a bit of guess work and 3D printing, as well as some inspiration from contemporaneous hardware such as the DEC PDP-11, [Michael] came up with an implementation. He used an IO extender HAT which adds 32 IO pins to the existing Pi GPIO pins that are accessible via an 3-wire I2C interface. This was enough hardware to support the 26 switches and 29 LEDs on the panel. There’s a brief demo of the custom printed switches in the video embedded below.
If you’re interested in old school 4-bit tech you might also like to check out 4-bit Single Board Computer Based On The Intel 4004 Microprocessor.
Continue reading “Imagining The CPS-1: An Early 70s 4-bit Microcomputer From Canada”
