Friends, there will likely come a time in your life when you have trouble sleeping. When this happens, it may behoove you to do some writing, any kind of writing. But consider that a physical journal will force you to turn past pages you’ve already filled, which may leave you deflated if you happen to read them.
So the answer lies in a sort of journalistic deposit box. That’s basically what we have here. [Simon Shimel]’s Bee Write Back writerdeck was inspired by sleepless nights, so you know it’s effective. The form factor is so great for [Simon], in fact, that he has developed more apps and functions for it, including a Claude client.
Inside is a Raspberry Pi Zero 2w, and input comes from an Air40 keyboard with quite awesome low-profile key caps. The display is a 5.5″ AMOLED, which leaves just enough room for a pair of the cutest bees ever. Be sure to check out the short video below for the build guide to accompany the build guide (PDF), and head over to GitHub for the full details.
Want to go even smaller and BYOK? Here’s a cheap writerdeck with an e-ink display.
Continue reading “We’re All Abuzz About The Bee Write Back Writerdeck”
