Powering Up A Pluggable Module From The 1948 IBM 604 Electronic Calculator
In that awkward transition phase between electromechanical accounting systems used in the 1940s and the introduction of fully digital computers we find systems such as the IBM 604 Electronic Calculator, advertised for accounting, calculating and engineering tasks. While not capable of complex instructions, loops and other advanced features, it did use an interesting modular architecture with easily swappable modules containing a vacuum tube and associated components. Recently [Ken Shirriff] took a poke at one of these and even powered it up.
This kind of pluggable system would become a staple of computer systems, as they enabled the use of modules or cards with specific functions that could be swapped and combined at will to increase system flexibility, lower costs and make repairs a snap. For the IBM 604 a total of about 1250 vacuum tubes were used, apparently all of which were found on these pluggable modules.
The module that [Ken] got his hands on has a thyratron tube, which is effectively a high current switch and rectifier. In the short demonstration video you can see it being used to switch a lamp on and off, with further details explained in the article.
Despite being rather limited in its functionality and limited by the punch card input and output speed, the IBM 604 was still a smashing commercial success with over 5600 units produced. A transistorized prototype version with 2200 transistors and 95% less power usage was created in 1954 that formed the basis for the IBM 608, the world’s first commercial all-transistorized calculator.
The 608 didn’t last too long, however, as at that point the breakneck pace of semiconductor technology meant that any newly released product was already obsolete by the time it hit the market. Despite this, fundamentals like pluggable modules would keep showing up over and over, ranging from the 1950s Bendix G-15 to even modern day systems, including PCs with pluggable RAM and expansion cards as well as mainframes where hot swapping of even entire CPU modules is just another feature.
Continue reading “Powering Up A Pluggable Module From The 1948 IBM 604 Electronic Calculator” →
Discovery Of An Active Wind From The Milky Way’s Central Black Hole
One of the fun aspects of astrophysics is that much of it involves phenomena which you cannot exactly study from up close, with the supermassive black hole (SMBH) at the center of this galaxy – called Sagittarius A* (Sgr A) – being a great example. Although it’s been predicted since 1971 that black holes like Sgr A radiate energy which then pushes away nearby matter to create something akin to solar wind, this had so far not been proven. Now astronomers have discovered evidence for this emanating from Sgr A*.
Using five years worth of observations made with the Atacama Large Millimeter/Submillimeter Array (ALMA) and correlating it with other observations, a Southern Lobe of movement was identified, along with evidence for a Northern Lobe. Unlike a star where you are dealing with relatively massive quantities of matter being hurled into space, in the case of a very quiet SMBH like Sqr A* you are talking about occasional small wisps of gas of which a fraction gets turned into the radiation that then exerts pressure on the remaining gas.
It is speculated to be exactly this quiescent nature of Sgr A* that makes it so difficult to find evidence of SMBH wind, though one could also argue that having a well-fed SMBH whose event horizon rapidly expands would be fascinating from an astrophysics perspective, but less exciting for any nearby inhabited planets.
Pico-Driven Ultrasound Enables Scaled Acoustic Model Of Home Stereo
There are plenty of ways to get sound into your house: good old fashioned headphones, the Dolby surround setup we all lusted after back in the day, or the 21st century’s ubiquitous soundbar, with its ‘spatial audio’ magic. Which will work in your space? If you were an audio engineer, you’d set up listening area and use a microphone to map the space– but that would be thousands of points and sounds like tedium. [PlasmatronX] had a better idea: use Schlieren imaging to see the sound waves as the travel through the space. Schlieren imaging has trouble with audio frequencies, though, and imaging the entire living room was going to be difficult. So he scaled it all down– including the sound waves, by shifting to ultrasonic frequencies.
He’s using the usual mirror-and-razor Schlieren setup with an 8″ telescope mirror– and if you don’t know what that is, we did a deep dive on this kind of optical flow visualizer a while back. Inside the circular imaging area where that lets him see density changes, he’s set up what he calls a CAT– Computer Acoustic Tomography– array. It’s a rig on a turntable he can set up ultrasonic transducers on, to match the various speaker setups he wants to test, and turn so he can see from all angles what the scaled-down waves are doing. To capture those waves, which aren’t going to be standing still, he adds a stroboscope. All the ultrasound signals are being generated by a Pi Pico, and are scaled 4:1 in the frequency domain– that is, a high 10kHz whine becomes inaudible 40kHz. Those signals are fed through a DIY 8-channel amp into both ultrasonic transducers and larger ‘cat-repellent speakers’ from AliExpress.
The microcontroller is actually a Pico 2W, which is using its “W” to communicate via Bluetooth with a Pi 4. That SBC is running the camera, the stepper for the turntable, and image processing, along with the timing for the audio signals. After that it’s a matter of setting up a scaled down 7.1 surround setup and itty-bity soundbar, and test it on a (stuffed) guinea pig. Obviously you can see a big difference between the steered beams from the tiny soundbar and the true surround, but how that translates to listening pleasure will be at least somewhat subjective.
What’s less subjective is the obvious effect soft furnishings add to the simulation. Now he doesn’t take the time to find a material that will scale the frequency response of a set of curtains, but we’re not sure how much that matters. At 5kHz or 20kHz, they’re going to deaden sound, and you can see that here, and you can see it’s a much bigger deal for the shaped beams of the soundbar than it is for surround sound. In the end, [PlasmatronX] decides to stick to headphones, but the whole video is very much worth watching, so we’ve embeddded it below. If you want to try it yourself he’s put his code on GitHub.
Thanks to [PlasmatronX] for the tip!
Continue reading “Pico-Driven Ultrasound Enables Scaled Acoustic Model Of Home Stereo” →
Server racks branded with Internet Archive
News Sites Are Blocking Internet Archive Over AI Scraping Fears
Especially in this era of the Internet, the role of the Internet Archive’s Wayback Machine has become increasingly essential as more and more web content vanishes into the ether or is surreptitiously altered to hide salient details. More recently a new worry has seemingly cropped up in the form of scraping of data for so-called AI systems, or at least that’s part of the excuses being offered for blocking the Wayback Machine’s web crawlers, with [Andrew Deck] and [Hanaa’ Tameez] of [Nieman Lab] detailing the impact and reasons provided.
Some news outlets like The Baltimore Banner insist that they’re only blocking the Wayback Machine crawlers because they are worried that LLM chatbots would otherwise ‘improperly cite’ the source of content, while outlets like The Atlantic have put a blanket anti-scraping policy in place. Meanwhile news outlets are generally happy to let paid commercial news archiving outlets like ProQuest and LexisNexis index their content, showing a potential financial incentive.
Whatever the reasons, the direct effect is that as content is modified or vanishes during for example a system migration, buy-out or bankruptcy, researchers who rely on the Wayback Machine are pretty much forced to rely on paid offerings by ProQuest and kin, without the pure archiving focus and free access to information. It will also leave big holes in what the Wayback Machine can cover in its archives, with news especially becoming very spotty.
Incidentally there’s an ongoing petition over at SaveTheArchive.com which people can sign.
Three brown pancakes are sitting in a frying pan.
Optimizing Pancakes From Chemical Principles
Although parents and teachers like to point out the deep link between cooking and chemistry, most people don’t deliberately apply any chemical principles beyond acid/base reactions to their recipes. Not so [Ben Kazez]: he’s written a thorough exploration of the chemical journey to the perfect pancake, and made a calculator for others to use with their own ingredients.
The goal is to optimize the pancakes along four dimensions: interior texture (light and smooth), a tangy flavour, rise, and a crisp, brown exterior layer. The tang comes from residual acids, and since lactic acid produces the best taste, dairy-based acid sources (such as Greek yoghurt or buttermilk) are preferable. Acids also react with baking soda to release carbon dioxide, making them a part of one of the four rising agents. The other three are carbon dioxide released when double-acting baking powder is heated, steam released from the batter, and air bubbles stabilized by egg white foam.
Dairy products, besides contributing acid, also provide a protein structure to keep the interior smooth. In a normal wheat-heavy pancake, two proteins (glutenin and gliadin) interact to form tough strands of gluten. Fats bind to hydrophobic amino acids in these proteins and shorten the gluten chains, hence the name shortening. Adding ricotta cheese also replaces some of this gluten network with a smoother structure of previously-denatured dairy proteins. Dairy products also contribute to the Maillard reaction between reducing sugars (such as lactose, glucose, and fructose) and amino acids, which causes the browning of the pancake’s surface. Besides being brown, the surface should be crisp; since amylose, found in corn starch, forms a brittle, glassy, crackly network when dehydrated, corn starch was added.
The result is a set of chemical equations which can be tuned to create perfect pancakes, combined in the calculator. This summary doesn’t do justice to the depth of the research here; [Ben] also investigated optimal batter resting times, fermentation, cooking fats, cooking surfaces, and spatula properties. If all this has you interested in more about dairy proteins, check out our article on cheesemaking.
Featured image: “Buttermilk pancakes from a recipe by Darina Allen” by [Didym].
Spy Tech: The GPS Numbers Station
We’ve talked before about number stations — mysterious shortwave transmitters repeating numbers, presumably for clandestine purposes. But, of course, the mere fact that they are unusual makes them stand out. The best place to hide something is in plain sight. In the old days, a broadcaster might slip a fake news story in mentioning a name that has a secret meaning, for example. But according to [Steven Murdoch], the United States has an even more obvious hiding place for a numbers station: inside GPS.
Every L1 C/A navigation message is a 176-bit field known by the affectionate moniker: Subframe 4, Page 17. The GPS specification says it is for “special messages.” No one has disclosed what those messages might be.
[Murdoch] at University College London analyzed over 12 million GPS packets from 2007 to 2026, trying to understand what was in this field. You might think 176 bits isn’t much, and you are right. But the L1 C/A signal carries 50 bits per second, and each frame is 1,500 bits. As [Murdoch] points out: “every bit must earn its place.” Each subframe is 300 bits, so this mysterious signal is 12% of the subframe. It must be important to someone.
Continue reading “Spy Tech: The GPS Numbers Station” →
Revisiting Using AI Coding Assistants: You’re Holding It Wrong Edition
After scathing accusations of skimping on due diligence, as well as other feedback to my article on trying to use an ‘AI coding assistant’ for the first time, the only rational, academic response is to lick one’s wounds following a particularly bruising peer review and try to address the raised issues. Reality after all does not care about one’s feelings, and there may be more to this AI assistant technology that can be coaxed out with a more in-depth look.
To this end I’ll do my best to try and work through each raised point, criticism and accusation, to see what I – and perhaps others – can learn of this endeavor. Said points include the use of the wrong frontend – i.e. Copilot – and the wrong model – being Claude Haiku 4.5 – as well as the egregious flaw on my end of ‘prompting wrong’.
For the sake of due diligence the best frontend and models will be investigated for particular tasks, with finally the verbal minefield of ‘prompt engineering’ examined for industry-standard approaches.
Continue reading “Revisiting Using AI Coding Assistants: You’re Holding It Wrong Edition” →
