Ford, Take Note: Classic Pickup Becomes The EV We Want
Ford does sell an electric pickup, but not very many of them. We can’t say for sure, but it’s possible that if the F150 Lightning had the classic cool of [ScottenMotors] 1977 F150 SuperCab conversion they’d have better numbers.
The battery box sits where a V8 used to choke on well-meaning emissions controls.
On Reddit, [Scotten] shares the takeaways from his conversion effort, which involved a custom Tesla-cell battery pack and a new rear axle assembly to house the Tesla SDU (Small Drive Unit). A Large Drive Unit (LDU) would probably fit, but the SDU already puts out 264 HP, which compares rather favourably to the 156 HP this truck’s malaise-era V8 put out stock. The old F-bodies were great trucks in a lot of respects, but even an die-hard ICE enthusiast is probably not going to be sad to see that motor go.
Continue reading “Ford, Take Note: Classic Pickup Becomes The EV We Want”
A small white work truck sitting on a faded road with trees in the background. In its bed is what looks like an enormous drill battery in an upside down position. The "battery" is black with red and yellow stripes. It has the words "125V, 500 Ah, 52 kWh" and "Mr. G's Workshop" emblazoned on the side.
Kei Truck Looks Like A Giant Power Tool
Kei trucks are very versatile vehicles, but their stock powerplant can leave a bit to be desired. If you need more power, why not try an electric conversion?
[Ron “Mr. G” Grosinger] is a high school auto shop and welding teacher who worked with his students to replace the 40 hp gas motor in this Daihatsu Hijet with the 127 hp of a Hyper 9 electric motor. The motor sits in the original engine bay under the cab and is mated to the stock transmission with a custom adapter plate made from plate steel for less than $150. We really appreciate how they left all the electronics exposed to see what makes the conversion tick.
The faux battery was made by a foam sculptor friend out of urethane foam shaped with a carving knife and then painted. It slides on a set of unistrut trolleys and reveals the 5 salvaged Tesla battery modules that power the vehicle. The fold down sides of the truck bed allow easy access to anything not already exposed if any tweaking is necessary.
We’ve seen a kei truck become a camper as well or an ebike powered with actual power tool batteries. If you’re thinking of your own electric conversion, which battery is best?
Continue reading “Kei Truck Looks Like A Giant Power Tool”
Can A $3200 Kit Convert Your Car To Electric Power?
Whether hardcore petrolheads like it or not, we appear to be living through the final years of the internal combustion engine. In many countries there are legislative timetables in place for their eventual phasing out, and even those which remain in production are subject to ever more stringent emissions legislation. If there’s a problem with the EVs with which we’re expected to replace our fossil fuel vehicles it’s the cost, those things are still very expensive. An Aussie student has an interesting idea that’s won the James Dyson Prize: a low cost conversion for existing vehicles that bolts onto their rear wheel hubs.
Electric conversion of fossil fuel cars is nothing new, indeed we’ve brought you news of units designed to replace the original engine and transmission. Neither are wheel hub motors new, but the difference with this system is that it doesn’t require significant mechanical modification to the vehicle. It retains the old engine, and this motor sits inside each rear wheel.
It almost seems too good to be true, but a closer reading shows the rotor bolted on one side to the old wheel hub and on the other side to the wheel. The stator meanwhile is bolted to the existing brake caliper mountings. This would lead to a slightly wider track and a greater unsprung weight, but we can see that it would work. Besides the motor there’s a battery pack for the spare wheel well and a set of electrically-powered systems to supply the brake servo vacuum and other services. The idea is that this whole kit could be fitted for 5000 Australian dollars, which is somewhere south of $3200 USD. It’s not perfect and it still involves hauling around the dead weight of an unused engine, but we can see it might still have a niche. If, and that’s a big if, it ever makes it to market, that is.
A DeLorean sitting on patchy snow next to a driveway. It's angled away from the viewer to the left showing off the open engine compartment with bright orange high voltage lines coming out of a square metallic charger box.
A DeLorean With An Electrifying Secret
There are few production cars with as much geek cred as the DMC DeLorean. If you want to kick the nerdiness up a notch without doing a full Back to the Future prop-mod, then the next best thing is to make it an EV.
[Bill Carlson] took a 1981 DeLorean and transplanted the drivetrain from a Chevy Bolt to electrify this ride. With the DeLorean being a rear wheel drive vehicle and the Bolt front wheel, there was some amount of component reshuffling to do. The motor is now in the rear of the car along with the main contactor, charger, and motor controller while the batteries are split between a pack in the original engine compartment and another up front under the hood.
The electric power steering and brake booster from the Bolt now also live under the hood, and the accelerator and steering column from the EV were transplanted into the cockpit. [Carlson] still needs to tidy up the interior of the car which is currently a nest of low voltage cables as well as add the cooling system which will bring this stainless monster up to a hefty 3200 lbs (~1450 kg) versus the original 2850 lbs (~1300 kg). We suspect the total bill came in a bit lower than getting an electric DeLorean Alpha5.
This isn’t the first electric DeLorean we’ve covered here, and if that isn’t cool enough, how about this DeLorean-inspired hovercraft?
Continue reading “A DeLorean With An Electrifying Secret”
An open engine bay for a small car. The wheels are off so the hubs and brakes are visible to the side and the electric motor mounted on top of the vehicle's original engine block is in the center of the image.
A Different Approach To EV Conversions
While there are a lot of exciting electric vehicles finally coming to market, many of us feel nostalgic for the fossil cars of our youth. [Mihir Vardhan] restored his grandfather’s car with an unusual gas-to-EV conversion.
While this conversion starts in the usual fashion by pulling out the gas engine, [Vardhan] takes a different tack than most by not just bolting an electric motor up to the transmission. Instead, he and his crew removed the head and pistons from the petrol burner and bolted the electric motor to the top on an L-shaped bracket. Using the timing belt to transfer power to the crankshaft, there is no need to figure out additional motors for the A/C compressor or power steering pump, greatly simplifying implementation.
[Vardhan] did need to add a vacuum pump for the braking system and used a DC/DC converter to step down the 72V traction battery voltage to the 12V needed to charge the accessory battery. While it doesn’t exactly boast the performance of a Tesla, his bargain-basement conversion does yield a converted vehicle that can get around town for only around $3k US, even if it does mean your EV still needs oil changes. We think this could work even better on a vehicle with a timing chain instead of a belt, but it’s certainly an interesting way to go about the conversion process.
We’ve covered our fondness for EV conversions in the past for cars, motorcycles, and boats if you’d like to dig deeper. Have your own EV conversion you think we should cover? Send us a tip!
Continue reading “A Different Approach To EV Conversions”
An EV Conversion Engineered As A Drop-in Replacement
With electric vehicles such as the Tesla or the Leaf being all the rage and joined by fresh competitors seemingly every week, it seems the world is going crazy for the electric motor over their internal combustion engines. There’s another sector to electric traction that rarely hits the headlines though, that of converting existing IC cars to EVs by retrofitting a motor. The engineering involved can be considerable and differs for every car, so we’re interested to see an offering for the classic Mini from the British company Swindon Powertrain that may be the first of many affordable pre-engineered conversion kits for popular models.
Swindon Powertrain's demo Mini
Swindon Powertrain’s demo Mini
The kit takes their HPD crate EV motor that we covered earlier in the year, and mates it with a Mini front subframe. Brackets and CV joints engineered for the kit to drop straight into the Mini. The differential appears to be offset to the right rather than the central position of the original so we’re curious about the claim of using the Mini’s own driveshafts, but that’s hardly an issue that should tax anyone prepared to take on such a task. They can also supply all the rest of the parts for a turnkey conversion, making for what will probably be one of the most fun-to-drive EVs possible.
The classic Mini is now a sought-after machine long past its days of being dirt-cheap old-wreck motoring for the masses, so the price of the kit should be viewed in the light of a good example now costing more than some new cars. We expect this kit to have most appeal in the professional and semi-professional market rather than the budget end of home conversions, but it’s still noteworthy because it is a likely sign of what is to come. We look forward to pre-engineered subframes becoming a staple of EV conversions at all levels. The same has happened with other popular engine upgrades, and no doubt some conversions featuring them will make their way to the pages of Hackaday.
We like the idea of conversions forming part of the path to EV adoption, as we’ve remarked before.
Crate EV Motor Hits Market: The Swindon Powertrain
Last year brought some exciting news from the unlikely quarter of an unexciting industrial estate in the British town of Swindon, the company Swindon Powertrain announced that they’d be marketing an all-in-one electric motor and transmission. Essentially this would be a crate engine for EV conversions, and since it’s pretty small it would be able to be shoehorned into almost any car. So often these announcements later prove to be vapourware, but not in this case, because Swindon Powertrain have announced that you can now order the HPD as they call it, for delivery in August. It’s not entirely cheap at £6400 ($7846) exclusive of British VAT sales tax, but when its integrated transmission and differential is taken into consideration it starts to seem more attractive when compared to engineering a random motor onto an internal combustion engine transmission.
They provide a product page with links to a load of data, installation information, and even a CAD model, as well as an ordering page in their webshop from which you can pay the deposit with the rest presumably payable in August before delivery. There is also a range of optional extras including matched inverters, drive shafts, a limited slip differential, and a coolant pump, which makes the whole ever more attractive as a package. 80kW should be enough to lend sprightly performance to all but the largest of cars, so we’ll expect to see this motor ever more often in years to come.
There is already a thriving home-made EV scene which we don’t expect this unit to displace. Instead it will find a niche at the professional and semi-professional conversion level, and we wouldn’t be surprised to see an aftermarket springing up offering ready made subframes to fit it to popular cars. If it is a success there will inevitably be copies and probably at a lower price, so it could be the start of a wave of very interesting conversion options. We hope that Swindon Powertrain will do well with it, and will manage to stay one step ahead of the upstarts. You can read our coverage of its announcement and their electric Mini prototype here.
Thanks [Carl Pickering] for the tip.
