Real-time Shader, Running On A Game Boy Color
[Danny Spencer] has a brilliant graphical demo that, like all great demos, flexes a deep understanding of the underlying system: a real-time 3D shader on the Game Boy Color.
If you’re not familiar with shaders, they were originally mathematical lighting models (hence the name) and are an integral part of the modern 3D graphics pipeline. One no longer draws pixels directly to a screen to represent objects. Instead, 3D object data is sent to the Graphics Processing Unit (GPU) which handles the drawing. Shaders are what control things like an object’s lighting, textures, and more.
Implementing even a basic real-time shader in software on a Game Boy Color is pretty wild. Not only is it a pixels-and-sprites (and not 3D graphics) kind of system, but the Game Boy’s SM83 CPU doesn’t even have a multiply instruction, nor does it support floats. As [Danny] puts it: given that the entire mathematical foundation of his shader rests on multiplying non-integer numbers, he had to get creative. That makes his demo a very round peg in an extremely square hole.
In the case of [Danny]’s demo, the user can manipulate the position of, and lighting around, a classic Utah teapot in real time. He explains the workflow and shows how the process can be applied to other objects. The ROM is available on GitHub and there’s a video, embedded below.
[Danny] is no stranger to performing feats of technical prowess that are as creative as they are playful, like implementing a working adding machine in a DOOM level.
Continue reading “Real-time Shader, Running On A Game Boy Color”
Pico Pal Puts RP2350 Into Game Boy Color Shell
While modern gaming systems deliver ever more realistic experiences, there’s still something to be said for the consoles and handhelds of the 80s and 90s. For many, the appeal is nostalgic. Others are attracted to the “lo-fi” graphical and sound design of these games, necessitated by the limited hardware of the time.
That said nobody would claim those old systems were perfect. Which is why a hybrid approach like [Peter Khouly] has been working on with the Pico Pal might be the ultimate solution. This replacement motherboard for the Game Boy Color (GBC) is powered by the RP2350, meaning the external hardware will have the same look and feel as it did back in 1998, but you’ll still be able to reap the benefits of modern emulation.
While the origins of the project go a bit farther, [Peter] has been working on this particular variation of the Pico Pal GBC since August, and has kept a fascinating log of his progress. Just getting the RP2350 to emulate Pokémon isn’t really that big of a deal, but getting all the ancillary hardware implemented and fitted inside the case of the GBC is a different story. Especially since [Peter] intends to pack plenty of features into the final product, such as rechargable batteries, Bluetooth audio, real-time clock support, and digital video out.
The most recent status update is from just last week, where [Peter] goes over some of the new features he’s been working on. A major one is the soft power solution, where the physical power switch doesn’t just pull the plug like it did back in the 1990s. Instead, the switch triggers the board to save the game and enter into a low-power mode so that it can come right back on to where you left off. This does impact battery life, but so far, it looks like the Pico Pal GBC will be able to run for at least five hours on a charge, and more than twice that if you don’t mind turning off the audio.
It sounds like there’s still several gremlins to track down in the design, but even in its current state, the Pico Pal GBC looks very interesting. We’re immediately reminded of the phenomenal work [Bucket Mouse] has put in on a similar refit for the original DMG-1 Game Boy.
Porting Dragon’s Lair To The Game Boy Color Was A Technical Triumph
If you remember the 80s arcade game Dragon’s Lair, you probably also remember it was strikingly unlike anything else at the time. It didn’t look or play like anything else. So it might come as a surprise that it was ported to Nintendo’s Game Boy Color, and that took some doing!
Dragon’s Lair used LaserDisc technology, and gameplay was a series of what we’d today call quick-time events (QTE). The player essentially navigated a series of brief video clips strung together by QTEs. Generally, if the player chose correctly the narrative would progress. If they chose poorly, well, that’s what extra lives (and a stack of quarters) were for.
More after the break!
Continue reading “Porting Dragon’s Lair To The Game Boy Color Was A Technical Triumph”
Watch Any Video On Your Game Boy, Via Link Cable
Game Boys have a link cable that lets two of them play together. You know, to battle with a friend’s Pokemon and stuff like that. But who says that it should be limited to transmitting only what Big N wants you to?
[Chromalock] wrote a custom GB program that takes in data over the link cable, and displays it on the screen as video, as fast as it can be sent. Add in a microcontroller, a level shifter, and software on the big computer side, and you can hook up your Game Boy Color as a normal video device and send it anything you want, from a webcam to any program that outputs video.
Well, almost. The biggest limitation is the data link cable, of course. On the older Game Boys, the link cable is apparently only good for 8 kHz, while the Color models can pull a not-quite-blistering 512 kHz. Still, that’s enough for 60 fps in a low-res black and white mode, or a slow, screen-tearing high-res color experience. You pick your poison.
There are gotchas that have to do with the way the GB displays palettes that get left as “to-do” on the software side. There is room for improvement in hardware too. (GB Link looks like SPI to us, and we’d bet you can push the speeds even higher with clever GB-side code.) In short, this is an awesome demo that just invites further hacking.
If you want to know more about the Game Boy to get started, and maybe even if you don’t, you absolutely must watch The Ultimate Game Boy Talk. Trust us on this one.
Continue reading “Watch Any Video On Your Game Boy, Via Link Cable”
Frog Boy Color Reimagines The Game Boy Color Hardware From The Ground Up
Sales figures suggest Nintendo did pretty well with the Game Boy Color during its original run, even if the hardware and visuals feel a tad archaic and limited today. [Chris Hackmann] has taken the Game Boy Color design and reworked it from the ground up as the Frog Boy Color, kitting it out with modern upgrades in a GBA-like form factor while retaining the original hardware underneath.
[Chris] went to the wide-style GBA layout for comfort, which he considers superior to the original rectangular Game Boy format. He iterated through over 50 3D-printed enclosure designs to get the design to work, ensuring that the final housing could be CNC machined. He then set out to trim down the original Game Boy Color circuit layout to cut out hardware he considered unnecessary. The original LCD driver could go, since the Q5 replacement LCD he intended to use didn’t need it, and he also considered the IR port to be surplus to requirements. He also set out to replace the original audio amp with his own stereo design.
The result is a wide-format Game Boy Color with a gorgeous modern LCD, USB-C charging, and excellent compatibility with original games and accessories. Files are on Github if you want to build one yourself. Of course, he’s not the only person working on building the best Game Boy ever, but we always love seeing new work in this space. Video after the break.
Continue reading “Frog Boy Color Reimagines The Game Boy Color Hardware From The Ground Up”
An Epic Quest To Build The Ultimate Game Boy
If you didn’t grow up clutching Nintendo’s original DMG-01 Game Boy, it might difficult to see the appeal in 2023. It had the ergonomics of a brick, the system’s unlit LCD screen utilized a somewhat nauseating green color palette, and when compared to its contemporary competition like the Sega Game Gear or Atari Lynx, it would certainly appear to be the inferior platform. But despite its faults there was just something magical about the machine, and those who have a soft spot for the iconic handheld are always eager to relive those glory days.
Now, thanks to the incredible work of [Bucket Mouse], playing the old “brick” Game Boy doesn’t have to be nearly as austere an experience as it was in 1989. That’s because he’s developed a set of replacement PCBs for the handheld that not only implement all of the features of the later Game Boy Color, but sprinkle in some modern niceties as well. The result is a handheld that looks like the original on the outside, but plays all your favorite games even better than you remember them. Continue reading “An Epic Quest To Build The Ultimate Game Boy”
Acid-Damaged Game Boy Restored
The original Game Boy was the greatest selling handheld video game system of all time, only to be surpassed by one of its successors. It still retains the #2 position by a wide margin, but even so, they’re getting along in years now and finding one in perfect working condition might be harder than you think. What’s more likely is you find one that’s missing components, has a malfunctioning screen, or has had its electronics corroded by the battery acid from a decades-old set of AAs.
That latter situation is where [Taylor] found himself and decided on performing a full restoration on this classic. To get started, he removed all of the components from the damaged area so he could see the paths of the traces. After doing some cleaning of the damage and removing the solder mask, he used 30 gauge wire to bridge the damaged parts of the PCB before repopulating all of the parts back to their rightful locations. A few needed to be replaced, but in the end the Game Boy was restored to its former 90s glory.
This build is an excellent example of what can be done with a finely tipped soldering iron while also being a reminder not to leave AA batteries in any devices for extended periods of time. The AA battery was always a weak point for the original Game Boys, so if you decide you want to get rid of batteries of any kind you can build one that does just that.
Continue reading “Acid-Damaged Game Boy Restored”
