TinkerKit, physical computing toolkit
tinkerkit
TinkerKit is a collection of 20 different sensors and 10 actuators. It’s meant to make prototyping of physical computing devices much quicker/easier. The devices plug into a Sensor Hub Arduino shield. There is also a similar hub board that can emulate a keyboard; it translates sensor input directly to key strokes. It looks like a very ambitious project and it’s … Read the rest
Parking violation leads to malware download
parking
It seems some enterprising individual in Grand Forks, North Dakota has been placing fake parking violations on cars. If the recipient visited the URL on the flyer, they would be told to install a toolbar to view pictures of their vehicle. That piece of malicious software would then attempt to install several more. The actual vehicle pictures were from … Read the rest
SparkFun releases RGB button controller
rgb_button
SparkFun has been selling button pad parts for some time and we used them in our RGB door lock project. A excellent part, but you needed to implement your own interface to use the boards. SparkFun has just released two additional versions to make it easier on builders. The first is their Button Pad Controller USB. It has … Read the rest
Radio controlled sphere
[prabbit22m] has written an instructable on how to build a radio controlled sphere. The mechanism is fairly simple, with one drive motor, one servo and a gyro for stability. To turn, the servo shifts the center of gravity off to one side. You can see that the system works pretty well in the video above. If it didn’t have … Read the rest
Haptic compass
north
[eric], inspired by this Wired article, built his own haptic compass. Named “the clown belt”, it is a belt with 12 little vibrating motors mounted evenly all around. A digital compass vibrates whichever motor is closest to north at all times. This basically gives the owner an extra sense.  He doesn’t go much into his own experiences, but … Read the rest
