OpenSound Control protocol is an emerging standard for communication between musical programs. It’s meant to replace MIDI. The DSMI, DS Music Interface, team has just added support for OSC. You can now use your DS as generic OSC music controller over WiFi. OSC has TCP/IP support built in, so there is no need to run a host sever to talk to DSMI like you did when they only supported MIDI. We’ve seen OSC used in other projects like the monome. It’s also the basis for the multitouch communication protocol TUIO.
[via CDM]
