Fix A Broken DS By Removing A Screen
There are apparently a lot of broken Nintendo DS Lites out and about on eBay, and [Fede] has gotten his hands on one. His idea was to essentially turn one of these DS Lites into a SS (single screen?) (.es, Google translate) by modding the case, and he’s done it with pretty spectacular results.
If you’re going to do a case mod, you should go all out. To that end, [Fede] started by taking everything out of the DS and tossing the original 1000 mAh battery in favor of a 4000 mAh battery. From there he is able to shoehorn the two PCBs into the case with the speaker in between, which he notes doesn’t sound as nice as the original but works well enough.
After reshaping the plastic case in a few subtle ways and putting a few layers of paint on it, [Fede] now has a single-screen Nintendo DS for €2 plus parts and paint. While we’ve seen similar mods before, we’d be interested to see this one in action; some DS games don’t utilize the second screen as much as others, so perhaps this wouldn’t play every DS game perfectly, but for the price it can’t be beat.
The Hard Drive MIDI Controller
[shantea] builds MIDI controllers, and after a successful first endeavor with a matrix of buttons and knobs, he decided to branch out to something a little bit cooler. It’s called Ceylon, and it’s effectively a turntable controller built from an old hard drive.
As a contrast to the first MIDI controller, this would be a stripped-down build, with just three faders, LEDs for eye candy, a pair of pots for gain control, and a hard disk surrounded by six anti-vandal buttons. The hard disk is the star of the show, acting as a rotary encoder.
When manually spun, the hard disk generates a few phases of sinusoidal waves. The faster you spin it, the higher the amplitude and frequency. These signals are far too weak to be sampled directly by a microcontroller, and for digital control – as in, MIDI – you don’t need to read the analog signals anyway. These signals were turned digital with the help of an LM339 quad comparator. With two of these comparators and signals out of the hard disk that are 90 degrees out of phase, quadrature encoding is pretty easy.
The software for this MIDI controller is based on the OpenDeck Platform, a neat system that allows anyone to create their own MIDI controllers and devices.  It’s also a great looking board that seems to perform well. Video below.
Continue reading “The Hard Drive MIDI Controller” →
RetroPie Turned Game Gear
Running vintage console emulators on a Raspberry Pi seems to be the thing all the cool kids are doing. The coolest RetroPie builds take a vintage console – usually of the Nintendo genus – stuff a Raspi in there somehow, and Bob’s your uncle. [Phil Herlihy] over at Adafruit is throwing his hat into the ring with a similar build. For this one, though, he’s using Sega’s oft-maligned Game Gear. He might actually get more than a few hours out of the battery with this one, and the battery is rechargeable, too. You can’t beat that.
The build begins with tearing down an old Game Gear, chopping up the PCB to save the button contact, and starting to fit all the components in there. The display is completely replaced with a 3.5″ composite display, a bit larger than the 3.2″ display found in a stock Game Gear. That’s not a problem, there’s a surprising amount of space behind the bezel, and if you’re good enough with an xacto blade and a file, it will look stock.
The rest of the components include an amplifier board, battery charge regulator, a 2500mAh LiPo, and a Teensy to read the buttons. There are a few modifications required for the Pi, but the finished device presents a USB port to the outside world; keep a keyboard by your side, and this is a portable Pi in every respect.
Building A Transcutaneous Electrical Nerve Stimulation Device In A Weekend
Transcutaneous electrical nerve stimulation (TENS) is a technique that applies electrical current to nerves and muscles for the relief of pain. Before you ask, yes, some of these devices are FDA approved for various ailments. [Eric], [Conor], [Jacob], [lnr0626] and [rdrdrdrd] were down at HackDFW this weekend and built a TENS device from parts in their scrap bin.
A semi-decent TENS machine can cost somewhere between $70 and $200, but the team here have reduced the cost tremendously simply by separating the futzing analog/contact pad part from the signal generation part of the project. The signal generation actually happens on an Android phone, with settings to ‘relieve pain’, ‘relax’, ‘pulse’, and ‘random’. These signals are generated as audio and sent out over the headphone port. From there, the signal is amplified and sent to the neat skin-contact pads.
After prototyping their circuit, the team actually etched a circuit board for the final phase of the hackathon. Demo video below.
Continue reading “Building A Transcutaneous Electrical Nerve Stimulation Device In A Weekend” →
Using The Red Pitaya As An SDR
The Red Pitaya is a credit-card sized board that runs Linux, has Ethernet, and a good bit of RAM. This sounds a lot like a Raspberry Pi and BeagleBone Black, but the similarities end there. The Red Pitaya also has two RF inputs, two RF outputs, and a load of digital IOs, all connected to an Xilinx SoC that includes an FPGA. [Pavel] realized the Pitaya had all the components of a software-defined radio, and built an implementation to prove it.
The input for the SDR taps directly into one of the high impedance inputs with a simple loop antenna made out of telephone cable. The actual software-defined part of this radio borrows heavily from an Xilinx application note, while everything is controlled by either SDR# or HDSDR.
[Pavel] included a pre-built SD card image with all his software, so cloning this project is simply a matter of copying an SD card and building an antenna. The full source is also available, interesting if you would like to muck about with FPGAs and SDRs.
The Wisest Wizard Doesn’t Drink From Cans
“Wizard Staff” or “Wisest Wizard” is a drinking game played at parties where the attendees participate by taping the empty cans of the drinks they’ve consumed on top of one another to form a staff of inebriated power. A person with a longer staff is considered to be at a higher level and can therefore command lesser wizards to pound their current beverage to a point they see fit. Not everyone at a party necessarily drinks their tasty libation of choice from a can however. So, [Ahmed] and his group came up with a solution for those of us who might alternately prefer to wield a pint glass of power instead.
In their hardware project for Hack Illinois 2015, [Brady Salz], [Ahmed Suhyl], [Dario Aranguiz], and [Kashev Dalmia] decided to add a zest of tech to the game. For their updated rendition, glasses are equipped with battery packs for mobility, a Spark micro-controller, and different colored LEDs as indicators. A couple of wires reach into the bottom of each glass to measure conductivity and keep track of the number of times it is filled and then emptied. In leu of towers of aluminum husks and duct-tape, the group developed a simple Android app for participants to log into which will track and visualize the standings of each player registered to one of the glasses. They even created a pebble version of the app that will display all the same information in case you don’t want to risk handling your phone while drinking… heh.
For an added level of fun, once a player reaches a certain level above someone else, they unlock the option to “challenge” the lesser adversary. By selecting that person’s user name in the app, the LED and buzzer on their glass will spring to life, letting them know they’ve been chosen to chug the rest of their drink. If you’re curious how they made it work, you can check out the team’s code on Github and maybe take a stab at giving the game a makeover of your own.
Continue reading “The Wisest Wizard Doesn’t Drink From Cans” →
NXP & Freescale Merge
Buyouts, acquisitions, and mergers of semiconductor companies are not unfamiliar territory for anyone who deals with chips and components for a living. Remember Mostek? That’s STMicroelectronics now. The switches used to type this post – Cherry blues – were made by ON Semiconductor. Remember Motorola? Freescale.
Today marks another merger, this time between NXP and Freescale. The merger will result in a $40 Billion dollar company, putting it in the top ten largest semiconductor companies.
Hackaday readers should know NXP for being the only company ever to produce an ARM microcontroller in a DIP package along with thousands of other cool components. Freescale is perhaps best known for their i.MX6 series of ARM processors, but of course both companies have a portfolio that stretches back decades and is filled with tens of thousands of parts.
