This Week In Security: Chrome 0-day,Cassandra, And A Cisco PoC
Running Chrome or a Chromium-based browser? Check for version 98.0.4758.102, and update if you’re not running that release or better. Quick tip, use chrome://restart to trigger an immediate restart of Chrome, just like the one that comes after an update. This is super useful especially after installing an update on Linux, using apt, dnf, or the like.
CVE-2022-0609 is the big vulnerability just patched, and Google has acknowledged that it’s being exploited in the wild. It’s a use-after-free bug, meaning that the application marks a section of memory as returned to the OS, but then accesses that now-invalid memory address. The time gap between freeing and erroneously re-using the memory allows malicious code to claim that memory as its own, and write something unexpected.
Google has learned their lesson about making too many details public too early, and this CVE and associated bug aren’t easily found in in the Chromium project’s source, and there doesn’t seem to be an exploit published in the Chromium code testing suite. Continue reading “This Week In Security: Chrome 0-day,Cassandra, And A Cisco PoC” →
Bionic Eyes Go Dark
If you were blind, having an artificial retinal implant would mean the difference between seeing a few hundred pixels in greyscale and seeing all black, all the time. Imagine that you emerged from this total darkness, enjoyed a few years of mobility and your newfound sense, and then everything goes dark again because the company making the devices abandoned them for financial reasons.
This is a harrowing tale of close-source technology, and how a medical device that relies on proprietary hard- and software essentially holds its users hostage to the financial well-being of the company that produces it. When that company is a brash startup, with plans of making money by eventually pivoting away from retinal implants to direct cortical stimulation — a technology that’s in it’s infancy at best right now — that’s a risky bet to take. But these were people with no other alternative, and the technology is, or was, amazing.
One blind man with an implant may or may not have brain cancer, but claims that he can’t receive an MRI because Second Sight won’t release details about his implant. Those bugs in your eyes? When the firm laid off its rehab therapists, patients were told they weren’t going to get any more software updates.
If we were CEO of SecondSight, we know what we would do with our closed-source software and hardware right now. The company is facing bankruptcy, has lost significant credibility in the medical devices industry, and is looking to pivot away from the Argus system anyway. They have little to lose, and a tremendous amount of goodwill to gain, by enabling people to fix their own eyes.
Thanks to [Adrian], [Ben], [MLewis], and a few other tipsters for getting this one in!
Commodore 64 Monitor Traces I/O Calls, Eases Debugging
Developing for the Commodore 64 can be a rewarding retrocomputing experience, and thanks to [Dave Van Wagner], things are easier with his C64 IO_Monitor project, which opens the door to logging and tracing Kernal I/O calls for closer inspection. That’s not a typo, by the way. Kernal is what handles the C64’s low-level OS routines. Amusingly, as the story goes, it did in fact originate as a misspelling of kernel, but the name stuck.
What [Dave]’s program does is trace and log all input and output calls going through Kernal, which includes just about any function one might imagine. Things like keyboard input, screen output, and disk or tape I/O are all dutifully counted and logged, allowing one to really peek under the hood at a low level when doing any kind of development work. This kind of tool has turned out to be pretty handy given [Dave]’s penchant for porting Commodore emulators to a variety of (sometimes unusual) platforms.
Interested in giving it a spin? Head to the project’s GitHub repository for all the necessary files as well as some usage details, and enjoy making debugging and development a little less opaque than it otherwise would be.
Building A High-Capacity Linear Servo Actuator
Linear actuators are useful things, moving things in straight lines rather than annoying circles like so many motors. [Retsetman] recently built a linear servo actuator of his own design with accurate positional control.
The design relies on a carriage that moves along a threaded rod, perhaps the most rudimentary design of linear actuator. A large brushed DC motor is used to turn the threaded rod through a 3D-printed 9:1 herringbone geartrain, shifting the actuator back and forth. End stop switches are used to disengage the motor to avoid damage to the mechanism. Feedback is via a ten-turn potentiometer driven off the output geartrain to match the range of the actuator to the rotational range of the pot.
The final build has a stroke of approximately 100 mm, and can lift and hold a 15 kg weight with ease. In a pull test, the actuator failed at a load just shy of 100 kg. If you’re looking for something smaller, though, you can try building a linear actuator out of old DVD drive parts instead. Video after the break.
Continue reading “Building A High-Capacity Linear Servo Actuator” →
Hello (Many Quantum) World(s)
Historically, the first program you write for a new computer language is “Hello World,” or, if you are in Texas, “Howdy World.” But with quantum computing on the horizon, you need something better. Like “Hello Many Worlds.” [IonQ] proposes what that looks like and then writes it in seven different quantum languages in a post you should check out.
Here’s the description of the simple program:
The basic quantum program we’ll write is simple. It creates a fully-entangled state between two qubits, and then measures this state. This state is sometimes called a Bell State, or Bell Pair, after physicist John Stewart Bell.
The measurement results for this program should give us 0 for both qubits or 1 for both qubits, in equal amounts. When running these, we’ll be able to tell that we’re running on real hardware because that’s not always what we get! These errors are what currently limit quantum computers, but the first steps to overcome this with quantum error correction have already begun.
Continue reading “Hello (Many Quantum) World(s)” →
Infinity Mirror Hypercrystal Is As Beautiful As It Sounds
Sometimes, we feature projects that are full to the brim with advanced functionality or solve some tricky little problem for the end-user. Other times, we feature stuff that just looks super damn cool, and the Infinity Mirror Hypercrystal is firmly in that latter category.
This show-stopping build comes to us from [Inanna Malick], who put together the design using algorithmic and generative art techniques she’s been working on for years. The form is a non-symmetrical, non-platonic solid, with each of its eight faces laser cut from mirrored acrylic. Plywood sections are used to hold together the structure.
Initially, the build was illuminated from within by white LEDs, but [Inanna] wasn’t satisfied with the look, which was too rooted in regular human technology. They were instead covered up with transparent dichroic tape, creating the lurid shifting colors that do so much to add to the mystery of the legendary Hypercrystal.
The result is an infinity mirror piece that looks more advanced, more alien, and more luridly enticing than most we’ve ever seen. The dichroic shift placed on the LEDs goes a long way to elevating this sculpture to new aesthetic heights. Video after the break.
Continue reading “Infinity Mirror Hypercrystal Is As Beautiful As It Sounds” →
akurobatto clock
Unique Clock Is All Hands, No Dial, And Does The Worm
Back in the old days, we didn’t have fancy digital clocks. No, we had good analog clocks with a big hand and a little hand, and if you wanted to know the time you had to look at the clock and figure out which number each hand was pointing at, or kind of pointing at. It wasn’t easy, and we liked it that way.
So now, along comes an analog clock that’s nothing but the hands — no dial, no numbers, just hands. How is such a thing possible? The clue is in the clock’s name: AKUROBATTO, and in the video below, which shows the acrobatic movements of the clock’s hands as it does its thing. Serial improbable-clock maker [ekaggrat singh kalsi] clearly put a lot of thought into this mechanism, which consists of the hands and a separate base. The hands are joined together at one end and powered by small stepper motors. The base has two docking areas, where servo-driven claws can grasp the hand assembly, either at the center pivot or at the tip of either hand. With a little bit of shuffling around at transition points, the hands sweep out the hours and minutes in a surprisingly readable way.
For as cool as the design of AKUROBATTO is, the internals are really something else. There are custom-built slip rings to send power to the motors and the Arduinos controlling them, sensors to determine the position of each hand, and custom gearboxes for the steppers. And the locking mechanisms on the base are worth studying too — getting that right couldn’t have been easy.
All in all, an impressive build. Whether displaying the time on a phosphorescent screen or a field of sequins, it seems like [ekaggrat] has a thing for unique clocks. Continue reading “Unique Clock Is All Hands, No Dial, And Does The Worm” →
