No ARM Printer Driver? Just Write Your Own
When you think of the small machines that print the sticky labels on packages, you might not expect to find a complex printer with its own programming language (ZPL). However, [Dan Pastusek] was looking around online and found a small label printer on everyone’s favorite online warehouse for a great price that suggested it supported ZPL. Unfortunately, [Dan] had big dreams for creating a Raspberry Pi-based print station and found the drivers packaged for this particular printer were not ARM compatible. Not quite content to leave it there, he began to chip away at the layers until he had a working driver.
ZPL, at its core, is just a language describing ASCII commands transmitted over a serial connection. So while the printer showed up as an endpoint, it wasn’t working as the filters (the part of the driver that knows how to convert from a PNG to ZPL) was x86 only. On Linux, printer drivers also have a PPD file that describes what a printer can handle in paper size and other settings. The PPD file for the little printer gave the first clue. In the ShortNickName field, it identifies itself as HPRT N41, which is a popular HP printer. So this little printer must be a clone of a printer in that family. Notably, they don’t support ZPL. Instead, the HPRT series support TSPL, another printer language developed by TSC.
This presented a problem as the shipping service that provided the labels that [Dan] was using offered labels in three formats: PNG, PDF, and ZPL. Currently, it does seem like there’s a TSPL to ZPL converter out there for use, so rather than write his own, he took a shortcut and wrote a rasterizer instead. Initially, he tried to use some sample code that he found, and while he got something to come out of the printer, it was blank. So the next test was to save the raw TSPL output from a filer and cat directly to the serial port. This worked amazingly. Next, he wrote a converter to take a PNG and convert them into the bitmap format the TSPL has. The converter is in Javascript as it runs as part of the webserver that manages the print station. Could it be faster in a different language? Sure. But a different language wouldn’t make the printer any faster.
With the addition of a wireless barcode scanner, it’s satisfying to see the print station up and running. Here at Hackaday, we’re no stranger to seeing folks take apart printers to peel back the software and physical layers that make them up.
Two shots of the dispenser in question next to each other, showing it from different sides. One is showing the front panel, and the other shot gives us a better look at the top part, with a rotating disk that has openings for treats to be placed in.
Open-Hardware Dog Treat Dispenser Is A Stepping Stone For Behavioral Research
The principles of open-source hardware are starting to make great strides in scientific research fields. [Walker Arce] tells us about his paper co-authored with [Jeffrey R. Stevens], about a dog treat dispenser designed with scientific researchers in mind – indispensable for behavior research purposes, and easily reproducible so that our science can be, too. Use of Raspberry Pi, NEMA steppers and a whole lot of 3D printed parts make this build cheap (< $200 USD) and easy to repeat for any experiments involving dogs or other treat-loving animals.
Even if you’re not a scientist, you could always build one for your own pet training purposes – this design is that simple and easy to reproduce! The majority of the parts are hobbyist-grade, and chances are, you can find most of the parts for this around your workshop. Wondering how this dispenser works, and most importantly, if the dogs are satisfied with it? Check out a short demonstration video after the break.
Despite such dispensers being commercially available, having a new kind of dispenser designed and verified is more valuable than you’d expect – authors report that, in their experience, off-the-shelf dispensers have 20-30% error rate while theirs can boast just 4%, and they have test results to back that up. We can’t help but be happy that the better-performing one is available for any of us to build. The GitHub repository has everything you could want – from STLs and PCB files, to a Raspberry Pi SD card image and a 14-page assembly and setup guide PDF.
Open hardware and science are a match made in heaven, even if the relationship is still developing. The Hackaday community has come together to discuss open hardware in science before, and every now and then, open-source scientific equipment graces our pages, just like this recent assortment of biosensing hacks using repurposed consumer-grade equipment.
Continue reading “Open-Hardware Dog Treat Dispenser Is A Stepping Stone For Behavioral Research” →
The Q2, A PDP8-Like Discrete Transistor Computer
[Joe Wingbermuehle] has an interest in computers-of-old, and some past experience of building computers on perfboard from discrete transistors, so this next project, Q2, is a complete implementation of a PDP8-like microcomputer on a single PCB. Like the DEC PDP-8, this is a 12-bit machine, but instead of the diode-transistor logic of the DEC, the substantially smaller Q2 uses a simple NMOS approach. Also, the DEC has core memory, but the Q2 resorts to a pair of SRAM ICs, simply because who wants to make repetitive memory structures with discrete 2N7002 transistors anyway?
SMT components for easy machine placement
Like the PDP-8, this machine uses a bit-serial ALU, which allows the circuit to be much smaller than the more usual ALU structure, at the expense of needing a clock cycle per bit per operation, i.e. a single ALU operation will take 12 clock cycles. For this machine, the instruction cycle time is either 8 or 32 clocks anyway, and at a maximum speed of 80 kHz it’s not exactly fast (and significantly slower than a PDP-8) but it is very small. Small, and perfectly formed.
The machine is constructed from 1094 transistors, with logic in an NMOS configuration, using 10 K pullup resistors. This is not a fast way to build a circuit, but it is very compact. By looking at the logic fanout, [Joe] spotted areas with large fanouts, and reduced the pull-up resistors from 10 K to 1 K. This was done in order to keep the propagation delay within bounds for the cycle time without excessive power usage. Supply current was kept to below 500 mA, allowing the board to be powered from a USB connector. Smart!
Memory is courtesy of two battery-backed 6264 SRAMs, with the four 12-bit general purpose registers built from discrete transistors. An LCD screen on board is a nice touch, augmenting the ‘front panel’ switches used for program entry and user input. A 40-pin header was added, for programming via a Raspberry Pi in case the front panel programming switches are proving a bit tedious and error prone.
Discrete transistor D-type flip flop with indicator. Latest circuit switched to 2N7002 NMOS.
In terms of the project write-up, there is plenty to see, with a Verilog model available, a custom programming language [Joe] calls Q2L, complete with a compiler and assembler (written in Rust!) even an online Q2 simulator! Lots of cool demos, like snake. Game of Life and even Pong, add some really lovely touches. Great stuff!
We’ve featured many similar projects over the years; here’s a nice one, a really small 4-bit one, and a really big one.
IBM PalmTop Running Modern (Modified) Linux
The handheld computing market might seem dominated by smartphones today, but before their mass adoption there were other offerings for those who needed some computing power on-the-go. If a 90s laptop was too bulky, there was always the IBM PalmTop which packed punch for its size-to-weight ratio, and for the era it was created in. [Mingcong Bai] still has one of these antiques and decided to see if it was still usable by loading a customized Linux distribution on it.
The PalmTop sported modest hardware even for its time with an Intel 486SL running at 33 MHz with 20 MiB of RAM. This one also makes use of a 1 GB CompactFlash card for storage and while [Mingcong Bai] notes that it is possible to run Windows 95 on it, it’s not a particularly great user experience. A Linux distribution customized for antique hardware, AOSC/Retro, helps solve some of these usability issues. With this it’s possible to boot into a command line and even do some limited text-based web browsing as long as the Ethernet adapter is included.
While the computer is running at its maximum capacity just to boot and perform basic system functions, it’s admirable that an antique computer such as this still works, especially given its small size and limited hardware functionality. If you’re curious about more PalmTop-style computers, take a look at the first one ever produced: the HP-200LX.
Continue reading “IBM PalmTop Running Modern (Modified) Linux” →
An OpenBikeSensor
OpenBikeSensor Measures Close Calls
Cycling is fun, healthy, and good for the environment. But unfortunately it’s not always the safest of activities, as inconsiderate drivers can be a significant hazard to cyclists. Several countries, including Germany, France, and Belgium have introduced legislation mandating a minimum passing distance of at least 1.5 meters between cars and bikes. Enforcing such a rule is tricky however, and without accurate data on average passing distances it’s hard to know how many drivers are following it.
Enter OpenBikeSensor, an open-source hardware and community science project designed to gather exactly this information. Currently in its prototype phase, it aims to make a simple bike-mounted sensor that measures the lateral distance to any passing vehicles. The resulting data is collected online to generate maps highlighting danger zones, which can ultimately be used by city planners to improve cycling infrastructure.
The hardware is based around a set of ultrasonic sensors that measure the lateral distance to any large object. A GPS module keeps track of the bike’s location, while an ESP32 reads out the data and stores it onto an SD card. The user interface consists of a handlebar-mounted display that shows the system’s status. There’s also a button that the user needs to press any time they are passed by a vehicle: this will trigger a measurement and log the location. Once back home, the user can connect the OpenBikeSensor to their WiFi network and download their trip data.
The initial results look promising, and any project that gets people cycling and tinkering with electronics at the same time is worth looking into. It’s not the first time we’ve seen bike-mounted sensors either: people have designed their own sensors to measure air pollution in South America, or simply their own bike’s speed or tire pressure. Continue reading “OpenBikeSensor Measures Close Calls” →
Camping For $25: Thrift Store Hacks To Keep Cozy
A hacker is somebody who’s always thinking creatively to solve problems, usually using what they have on hand. Sometimes that means using a 555 to build a CPU, and other times it means using a dead flashlight to start a fire. In the video below the break, [Kelly] shows us a series of hacks you can use while camping in the woods for a night to keep you warm, dry, and well fed!
[Kelly] started his camping trip not in the woods, but rather at a local thrift store. Instead of packing along hundreds of dollars in gear, his aim was to keep costs low. Very low. With some searching he was able to find a blanket, cooking utensils, rope, knife, tarp, and several other camp necessities for just $25.
A good campfire is a necessity of course, and [Kelly]’s full of great ways to start a fire even if all you have is a lighter with no butane or an old flashlight with dead batteries. The purpose of the video is to show how anyone can get their bush craft on even when all they have is a few dollars and a little know-how, which he generously shares. And after watching, we’re sure you’ll agree that he met his mark.
Will you raid the local second hand store before your next camping trip? After seeing this video, you just might! And while you’re there, make sure to grab the things you’ll need to make your own camping-friendly French press so you have some good coffee while you’re out camping in your… uh… Corolla?
Continue reading “Camping For $25: Thrift Store Hacks To Keep Cozy” →
Twist Promises Easier Quantum Programming
We keep trying to learn more about quantum computers. But the truth is, the way we program quantum computers — or their simulators — today will probably not have much in common with how we program them in the future. Think about it. Programming your PC is nothing like programming the ENIAC. So we expect we’ll see more and more abstractions over the “bare metal” quantum computer. The latest of these is Twist, from MIT.
According to the paper (and the video, below), Twist expresses entangled data and processes in a way that traditional programmers can understand. The key concept is known as “purity” of expressions which helps the compiler determine if data is actually entangled with another piece of data or if any potential entanglement is extraneous. A pure expression only depends on qubits it owns, while a mixed expression may use qubits owned by other expressions.
Continue reading “Twist Promises Easier Quantum Programming” →
