Reviving Google Cardboard, Without Google Or Cardboard
Remember Google Cardboard? The late, unlamented practice of strapping a phone to your face so you could get motion sickness in a virtual environment? [brenpoly] wants you to reconsider, because in the years since Google pulled the plug on mobile VR, phones have gotten really, really good and he’s got a project called CardboardXR on GitHub that the project video enbedded below bills as “A 5$ Apple Vision Pro”
Well, it’s 5$ if you already happen to have a flagship phone like the Pixel 9 Pro or iPhone 15 Pro he’s using for testing– otherwise you’d be out a rather larger chunk of change in order to pick up such a pocket supercomputer. In any case, he’s able to get 6 Degree of Freedom (DOF) tracking from these units, along with using the cameras for passthrough and object detection, hand tracking, and gesture control– everything the big boys net you, in other words. That’s pretty impressive compared to the 3DOF, and zero tracking or pass-through mobile VR used to get you.
He’s also built adjustable optics into his 3D-printed replacement for Google’s old face-hugging cardboard, which you can get on Makerworld.  On the other hand, presumably you could just cut a hole for the camera bumps in one of those if you’re the kind of person who throws nothing out. Either way you’d be using the same lenses; it turns out they’re still available online, so that’s what [brenpoly] spec’d.
All these fancy features aren’t entirely [brenpoly]’s own work: his software is based on Unity which has some slick VR/AR tools and the ability to build in all the relevant machine learning models for things like hand tracking. He’s also taking some major inspiration from the Google Cardboard SDK, which Google open-sourced back around the time they gave up on it. It’s still a very impressive project regardless of the toolchain involved, though there’s a certain irony that [brenpoly] is now strapping a phone to his face after his last project we featured  was all about getting him to put it down.
Continue reading “Reviving Google Cardboard, Without Google Or Cardboard” →
TAKTO, Open Source Hand-Tracking Built Like LEGO
Hand tracking in VR/AR can add a substantial amount of immersion and added interactivity. Unfortunately, most camera based tracking suffers when fingers get covered, intertwined, or simply out of view of the headset’s camera. What’s even less common are methods of giving feedback to the user’s hands. [Sebastian Molano] saw these issues and decided if anyone was going to make an open-source solution, it was going to be him with his thesis on TAKTO.
Clear visuals show step-by-step assembly.
TAKTO aims to remove the prior issues mentioned with visual tracking by using magnetic encoders to tell where the device is and the finger’s position inside it. Actuators are able to pull on the fingers themselves to add even further information to the user. Of course, none of this is too crazy, as we have seen similar projects before. Where TAKTO stands out is the extent of the support outside of a one-off hand tracker.
TAKTO.one not only holds general information about the project itself, but also an entire digital twin of the live device. This console can give you a visual of using the glove and general status information. Documentation on how to assemble one for yourself is presented in clean visuals, which should make the build process painless.
Everything else about how to make the hand for yourself can be found on the project’s GitHub. The price tag is steep for the actuated version, though there is a sensing-only version for hand tracking, and most of the cost comes from the quality actuators used. If you want to look into implementing some usability into existing VR hardware, make sure to look at what Valve has released publicly!
Pokemon Go Had Players Capturing More Than They Realized
Released in 2016, Pokemon Go quickly became a worldwide phenomenon. Even folks who weren’t traditionally interested in the monster-taming franchise were wandering around with their smartphones out, on the hunt for virtual creatures that would appear via augmented reality. Although the number of active users has dropped over the years, it’s estimated that more than 50 million users currently log in and play every month.
From a gameplay standpoint, Go is brilliant. Although the Pokemon that players seek out obviously aren’t real, searching for them closely approximates the in-game experience that the franchise has been known for since its introduction on the Game Boy back in 1996.
But now, instead of moving a character through a virtual landscape in search of the elusive “pocket monsters”, players find them dotted throughout the real world. To be successful, players need to leave their homes and travel to where the Pokemon are physically located — which often happens to be a high-traffic area or other point of interest.
As a game, it’s hard to imagine Pokemon Go being a bigger success. At the peak of its popularity, throngs of players were literally causing traffic jams as they roamed the streets in search of invisible creatures. But what players may not have realized as they scanned the world around them through the game was that they were helping developer Niantic build something even more valuable.
Continue reading “Pokemon Go Had Players Capturing More Than They Realized” →
Augmented Reality Project Utilizes The Nintendo DSi
[Bhaskar Das] has been tinkering with one of Nintendo’s more obscure handhelds, the DSi. The old-school console has been given a new job as part of an augmented reality app called AetherShell.
The concept is straightforward enough. The Nintendo DSi runs a small homebrew app which lets you use the stylus to make simple line drawings on the lower touchscreen. These drawings are then trucked out wirelessly as raw touch data via UDP packets, and fed into a Gemini tool geometric reconstruction script written in Python which transforms them into animation frames. A Gemini tool is used to classify what the drawings are in order for a future sound effects upgrade, too. These are then sent to an iPhone app, which uses ARKit APIs and the phone’s camera to display the animations embedded into the surrounding environment via augmented reality.
One might question the utility of this project, given that the iPhone itself has a touch screen you can draw on, too. It’s a fair question, and one without a real answer, beyond the fact that sometimes it’s really fun to play with an old console and do weird things with it. Plus, there just isn’t enough DSi homebrew out in the world. We love to see more.
Continue reading “Augmented Reality Project Utilizes The Nintendo DSi” →
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The C64 Keyboard
[Jean] wrote into the tips line (the system works!) to let all of us know about his hacked and hand-wired C64 keyboard, a thing of beauty in its chocolate-brown and 9u space bar-havin’ glory.
A C64 keyboard without the surrounding C64.
Image by [Jean] via GitHub
This Arduino Pro Micro-based brain transplant began as a sketch, and [Jean] reports it now has proper code in QMK. But how is a person supposed to use it in 2025, almost 2026, especially as a programmer or just plain serious computer user?
The big news here is that [Jean] added support for missing characters using the left and right Shift keys, and even added mouse controls and Function keys that are accessed on a layer via the Shift Lock key. You can see the key maps over on GitHub.
I’ll admit, [Jean]’s project has got me eyeing that C64 I picked up for $12 at a thrift store which I doubt still works as intended. But don’t worry, I will test it first.
Fortunately, it looks like [Jean] has thought of everything when it comes to reproducing this hack, including the requisite C64-to-Arduino pinout. So, what are you waiting for?
Continue reading “Keebin’ With Kristina: The One With The C64 Keyboard” →
Brilliant Labs Has New Smart Glasses, With A New Display
Brilliant Labs have been making near-eye display platforms for some time now, and they are one of the few manufacturers making a point of focusing on an open and hacker-friendly approach to their devices. Halo is their newest smart glasses platform, currently in pre-order (299 USD) and boasting some nifty features, including a completely new approach to the display.
Development hardware for the Halo display. The actual production display is color, and integrated into the eyeglasses frame.
Halo is an evolution of the concept of a developer-friendly smart glasses platform intended to make experimentation (or modification) as accessible as possible. Compared to previous hardware, it has some additional sensors and an entirely new approach to the display element.
Whereas previous devices used a microdisplay and beam splitter embedded into a thick lens, Halo has a tiny display module that one looks up and into in the eyeglasses frame. The idea appears to be to provide the user with audio (bone-conduction speakers in the arms of the glasses) as well as a color “glanceable” display for visual data.
Some of you may remember Brilliant Labs’ Monocle, a transparent, self-contained, and wireless clip-on display designed with experimentation in mind. The next device was Frame, which put things into a “smart glasses” form factor, with added features and abilities.
Halo, being in pre-release, doesn’t have full SDK or hardware details shared yet. But given Brilliant Labs’ history of fantastic documentation for their hardware and software, we’re pretty confident Halo will get the same treatment. Want to know more but don’t wish to wait? Checking out the tutorials and documentation for the earlier devices should give you a pretty good idea of what to expect.
Supercon 2024: Photonics/Optical Stack For Smart-Glasses
Smart glasses are a complicated technology to work with. The smart part is usually straightforward enough—microprocessors and software are perfectly well understood and easy to integrate into even very compact packages. It’s the glasses part that often proves challenging—figuring out the right optics to create a workable visual interface that sits mere millimeters from the eye.
Dev Kennedy is no stranger to this world. He came to the 2024 Hackaday Supercon to give a talk and educate us all on photonics, optical stacks, and the technology at play in the world of smart glasses.
Continue reading “Supercon 2024: Photonics/Optical Stack For Smart-Glasses” →
