off grid weather station
915 MHz Forecast: Rolling Your Own Offline Weather Station
There are a lot of options for local weather stations; most of them, however, are sensors tied to a base station, often requiring an internet connection to access all features. [Vinnie] over at vinthewrench has published his exploration into an off-grid weather station revolving around a Raspberry Pi and an RTL-SDR for communications.
The weather station has several aspects to it. The main sensor package [Vinnie] settled on was the Ecowitt WS90, capable of measuring wind speed, wind direction, temperature, humidity, light, UVI, and rain amount. The WS90 communicates at 915 MHz, which can be read using the rtl_433 project. The WS90 is also available for purchase as a standalone sensor, allowing [Vinnie] to implement his own base station.
For the base station, [Vinnie] uses a weatherproof enclosure that houses a 12V battery with charger to act as a local UPS. This powers the brains of the operation: a Raspberry Pi. Hooked to the Pi is an RTL-SDR with a 915 MHz antenna. The Pi receives an update from the WS90 roughly every 5 seconds, which it can decode using the rtl_433 library. The Pi then turns that packet into structured JSON.
The JSON is fed into a weather model backend that handles keeping track of trends in the sensor data, as well as the health of the sensor station. The backend has an API that allows for a dashboard weather site for [Vinnie], no internet required.
Thanks, [Vinnie], for sending in your off-grid weather station project. Check out his site to read more about his process, and head over to the GitHub page to check out the technical details of his implementation. This is a great addition to some of the other DIY weather stations we’ve featured here.
Bridging RTL-433 To Home Assistant
If you’ve got an RTL-SDR compatible receiver, you’ve probably used it for picking up signals from all kinds of weird things. Now, [Jaron McDaniel] has built a tool to integrate many such devices into the world of Home Assistant.
It’s called RTL-HAOS, and it’s intended to act as a bridge. Whatever you can pick up using the RTL_433 tool, you can set up with Home Assistant using RTL-HAOS. If you’re unfamiliar with RTL_433, it’s a multitalented data receiver for picking up all sorts of stuff on a range of bands using RTL-SDR receivers, as well as a range of other hardware. While it’s most closely associated with products that communicate in the 433 MHz band, it can also work with products that talk in 868 MHz, 315 MHz, 345 MHz, and 915 MHz, assuming your hardware supports it. Out of the box, it’s capable of working with everything from keyless entry systems to thermostats, weather stations, and energy monitors. You can even use it to listen to the tire pressure monitors in your Fiat Abarth 124 Spider, if you’re so inclined.
[Jaron’s] tool integrates these devices nicely into Home Assistant, where they’ll appear automatically thanks to MQTT discovery. It also offers nice signal metrics like RSSI and SNR, so you can determine whether a given link is stable. You can even use multiple RTL-SDR dongles if you’re so inclined. If you’re eager to pull some existing environmental sensors into your smart home, this may prove a very easy way to do it.
The cool thing about Home Assistant is that hackers are always working to integrate more gear into the ecosystem. Oftentimes, they’re far faster and more efficient at doing this than big-name corporations. Meanwhile, if you’re working on your own hacks for this popular smart home platform, we’d probably like to know about it. Be sure to hit up the tips line in due time.
Reverse Engineering A (Toy) Fire Engine
Your kid has a toy remote control fire truck. You have an RTL SDR. See where this is going? [Jacob] couldn’t resist tearing into the why and how of the truck’s remote control protocol.
The entire process began with a basic GNU Radio setup to determine the exact frequency of the signal. Then a little analysis suggested that it might be using amplitude shift keying. That is, the information is in the amplitude of the signal, where one possible amplitude is completely off in some cases.
Continue reading “Reverse Engineering A (Toy) Fire Engine”
End Of An Era: NOAA’s Polar Sats Wind Down Operations
Since October 1978, the National Oceanic and Atmospheric Administration (NOAA) has operated its fleet of Polar-orbiting Operational Environmental Satellites (POES) — the data from which has been used for a wide array of environmental monitoring applications, from weather forecasting to the detection of forest fires and volcanic eruptions. But technology marches on, and considering that even the youngest member of the fleet has been in orbit for 16 years, NOAA has decided to retire the remaining operational POES satellites on June 16th.
NOAA Polar-orbiting Operational Environmental Satellite (POES)
Under normal circumstances, the retirement of weather satellites wouldn’t have a great impact on our community. But in this case, the satellites in question utilize the Automatic Picture Transmission (APT), Low-Rate Picture Transmission (LRPT), and High Resolution Picture Transmission (HRPT) protocols, all of which can be received by affordable software defined radios (SDRs) such as the RTL-SDR and easily decoded using free and open source software.
As such, many a radio hobbyist has pointed their DIY antennas at these particular satellites and pulled down stunning pictures of the Earth. It’s the kind of thing that’s impressive enough to get new folks interested in experimenting with radio, and losing it would be a big blow to the hobby.
Luckily, it’s not all bad news. While one of the NOAA satellites slated for retirement is already down for good, at least two remaining birds should be broadcasting publicly accessible imagery for the foreseeable future.
Continue reading “End Of An Era: NOAA’s Polar Sats Wind Down Operations”
RTL-SDR With Only A Browser
Surely by now you’ve at least heard of RTL-SDR — a software project that let’s cheap TV tuner dongles work as a software-defined radios. A number of projects and tools have spun off the original effort, but in his latest video, [Tech Minds] shows off a particularly unique take. It’s a Web browser-based radio application that uses WebUSB, so it doesn’t require the installation of any application software. You can see the program operating in the video below.
There are a few things you should know. First, you need the correct USB drivers for your RTL-SDR. Second, your browser must support WebUSB, of course. Practically, that means you need a Chromium-type browser. You may have to configure your system to allow raw access to the USB port, too.
Watching the video, you can see that it works quite well. According to the comments, it will work with a phone, too, which is an interesting idea. The actual Web application is available as open source. It isn’t going to compete with a full-fledged SDR program, but it looked surprisingly complete.
These devices have grown from a curiosity to a major part of radio hacking over the years. Firefox users can’t use WebUSB — well, not directly, anyway.
Continue reading “RTL-SDR With Only A Browser”
Writing A GPS Receiver From Scratch
GPS is an incredible piece of modern technology. Not only does it allow for locating objects precisely anywhere on the planet, but it also enables the turn-by-turn directions we take for granted these days — all without needing anything more than a radio receiver and some software to decode the signals constantly being sent down from space. [Chris] took that last bit bit as somewhat of a challenge and set off to write a software-defined GPS receiver from the ground up.
As GPS started as a military technology, the level of precision needed for things like turn-by-turn navigation wasn’t always available to civilians. The “coarse” positioning is only capable of accuracy within a few hundred meters so this legacy capability is the first thing that [Chris] tackles here. It is pretty fast, though, with the system able to resolve a location in 24 seconds from cold start and then displaying its information in a browser window. Everything in this build is done in Python as well, meaning that it’s a great starting point for investigating how GPS works and for building other projects from there.
The other thing that makes this project accessible is that the only other hardware needed besides a computer that runs Python is an RTL-SDR dongle. These inexpensive TV dongles ushered in a software-defined radio revolution about a decade ago when it was found that they could receive a wide array of radio signals beyond just TV.
Hacker Tools, Hacked Tools
We just love a good DIY tool project, and more so when it’s something that we can actually use cobbled together from stuff in our closet, or hacked out of cheap “toys”. This week we saw both a superb Pi Pico-based logic analyzer and yet another software frontend for the RTL-SDR dongle, and they both had us thinking of how good we have it.
If you don’t already have a logic analyzer, or if you have one of those super-cheap 8-channel jobbies, it might be worth your while to check out the Pico firmware simply because it gets you 24 channels, which is more than you’ll ever need™. At the low price of $4, maybe a little more if you need to add level shifters to the circuit to allow for 5 V inputs, you could do a lot worse for less than the price of a fancy sweet coffee beverage.
And the RTL dongle; don’t get us started on this marvel of radio hacking. If you vaguely have interest in RF, it’s the most amazing bargain, and ever-improving software just keeps adding functionality. The post above adds HTML5 support for the RTL-SDR, allowing you to drive it with code you host on a web page, which makes the entire experience not only cheap, but painless. Talk about a gateway drug! If you don’t have an RTL-SDR, just go out and buy one. Trust me.
What both of these hacker tools have in common, of course, is good support by a bunch of free and open software that makes them do what they do. This software enables a very simple piece of hardware to carry out what used to be high-end lab equipment functions, for almost nothing. This has an amazing democratizing effect, and paves the way for the next generation of projects and hackers. I can’t think of a better way to spend $20.
