Creating An Electronic Board For Catan-Compatible Shenanigans
[Sean Boyce] has been busy building board games. Specifically, an electronic strategy boardgame that is miraculously also compatible with Settlers of Catan.
[Sean’s] game is called Calculus. It’s about mining asteroids and bartering. You’re playing as a corporation attempting to mine the asteroid against up to three others doing the same. Do a good job of exploiting the space-based resource, and you’ll win the game.
Calculus is played on a board made out of PCBs. A Xiao RP2040 microcontroller board on the small PCB in the center of the playfield is responsible for running the show. It controls a whole ton of seven-segment displays and RGB LEDs across multiple PCBs that make up the gameboard. The lights and displays help players track the game state as they vie for asteroid mining supremacy. Amusingly, by virtue of its geometry and some smart design choices, you can also use [Sean]’s board to play Settlers of Catan. He’s even designed a smaller, cheaper travel version, too.
We do see some interesting board games around these parts, because hackers and makers are just that creative. If you’ve got your own board game hacks or builds in the works, don’t hesitate to let us know!
Build That Catan Board You Designed
A couple of months ago, we posted about the one day design [Sam March] did of an electronic Settlers of Catan board. Now he’s released a video with the second half. His first video was about the design of the game, specifically the electronic components. In this video, [Sam] takes us through the physical build of the board.
A couple of visits to his local maker space allows him to cut both the wooden parts of the board, as well as the acrylic hexes that go on top of each piece. Even with a CNC machine, there’s still some clean-up that needs to be done. After cleaning up the edges of the wood with a chisel and staining it, it’s time to put the circuit boards in, wire them up and program them. The build includes a dice roller – pushing a button shows the number rolled by lighting up the tiles in the form of the rolled number. The final touch is having some friends over to actually play the game.
Between the design process in the last article and the build process in this one, we get a good look at the way [Sam] designs things from beginning to finished product. Take a look at our previous article on [Sam]’s design as well as some other Catan articles.
Continue reading “Build That Catan Board You Designed”
Design An Electronic Catan Board In A Day
One of the things that makers sometimes skip over is the design of the project that they’re creating. Some of us don’t do any design at all, we just pants it. The design part of making something can take quite a while – there is sketching to do, as well as 3d-modelling and PCB creation. [Sam March] wanted to try and create something interesting where he did the design in a single day. The result is, or will be, a 3D printed, electronic, Settlers of Catan game board.
Continue reading “Design An Electronic Catan Board In A Day”
Why Settle For The Standard Catan Board?
Let’s face it, game night can get downright rowdy. Whether your game nights involve wine and cats, beer and dogs, or vodka and bear cubs, things happen. Maybe the robber gets batted irretrievably far under the couch, or someone gesticulates wildly and spills wine all over your sheep. [EEEEEEEEEDEN]’s gatherings were getting way out of hand, and it was time to design a custom Catan board.
But she didn’t stop with the board tiles — this is Catan redesigned from the ground up, including the pieces, the resource cards, and a custom storage box. [EEEEEEEEEDEN] even planned for player expansion by designing a leaf to drop in the middle. There are a few hundred magnets built into the frame, so there shouldn’t be any more lost pieces. And as far as liquor-proofing all the cardboard goes, [EEEEEEEEEDEN] designed new board tiles and cards, laser cut them from acrylic, and painstakingly painted them all with Plasti-Dip spray.
We think it’s gorgeous, but understand that maybe this minimalist style isn’t for everyone. If you want to go custom, it’s hard to argue against the beauty of 3D Catan.
Thanks to [Johannes] for the tip! via /r/DIY
Get Ready For Games Night With 3D Catan
Settlers of Catan is a staple for boardgaming aficionados. Some fans like to express themselves by building a custom set of their own, and [Maclsk] is no different. Enter 3D Catan!
The models for the various pieces were designed in Blender, a great open source 3D modelling program. They were then printed on an Anycubic i3 Mega, taking about 80 hours and using 700 grams of PLA filament. With 116 game pieces, there was plenty of filing and sanding to do.
With this completed, it was then time for paint. [Maclsk] shows off a strong understanding of model painting fundamentals, from dry brushing to using PVA glue to give water elements a glossy sheen. If you’re new to the techniques, sit down with your local Warhammer players – they’ll be more than able to point you in the right direction.
Overall, it’s a great build that really pops on the gaming table. We’ve seen other die-hard Catan fans come out with their own builds, too. Video after the break.
Continue reading “Get Ready For Games Night With 3D Catan”
Image from official site catan.com
How Provably Loaded Dice Lead To Unprovable Cheating
Here’s a really interesting writeup by [Mike] that has two parts. He shows that not only is it possible to load wooden dice by placing them in a dish of water, but that when using these dice to get an unfair advantage in Settlers of Catan, observation of dice rolls within the game is insufficient to prove that the cheating is taking place.
[Mike] first proves that his pair of loaded dice do indeed result in a higher chance of totals above seven being rolled. He then shows how this knowledge can be exploited by a Settlers of Catan player to gain an average 5-15 additional resource cards in a typical game by taking actions that target the skewed distribution of the loaded dice.
The second part highlights shortcomings and common misunderstandings in current statistical analysis. While it’s possible to prove that the loaded dice do have a skewed distribution by rolling them an arbitrary number of times, as [Mike] and his wife do, it is not possible to detect this cheating in a game. How’s that? There are simply not enough die rolls in a game of Settlers to provide enough significant data to prove that dice distribution is skewed.
Our staff of statistics Ph.D.s would claim that [Mike] overstates his claims about shorcomings in the classical hypothesis testing framework, but the point remains that it’s possible to pass through any given statistical testing process by making the effect just small enough. And we still think it’s neat that he can cheat at Settlers by soaking wooden dice in water overnight.
This isn’t the first time we’ve seen Settlers of Catan at the center of some creative work. There’s this deluxe, hand-crafted reboot, and don’t forget the electroshock-enabled version.
[via Reddit; images from official Catan site]
Ultra-Polished, Handmade Settlers Of Catan Redux
[Fuzzy Wobble] and [Amy Wang]’s Deep Space Settlers project is a one-of-a-kind re-invention of the popular board game Settlers of Catan, and showcases the polished results that are possible with the fabrication tools and methods available in many workshops and hackerspaces today. We reached out to the makers for some of the fabrication details, which they were happy to share.
(For those of you who are familiar with the game, technically this is a remake and slight evolution of the Seafarers expansion to the base Settlers of Catan game. A few rule changes were made, but it is mostly a total remodel and redesign.)
Continue reading “Ultra-Polished, Handmade Settlers Of Catan Redux”
