Solar-Powered Prosthetic Skin
One of the biggest problems for prosthetic users is feel. If you’ve ever tried to hold a pen and write with a numb hand, you’ve realised how important feedback is to the motor control equation. Research is ongoing to find ways to provide feedback from prosthetic limbs, in even a basic format.  The human nervous system is a little more complex than just interfacing with the average serial UART. One of the requirements of many feedback systems is power, which usually would involve bulky batteries or some form of supercapacitors, but a British team has developed a way to embed solar cells in a touch-sensitive prosthetic skin.
The skin relies on everyone’s favourite material of the minute, graphene. A thin layer of graphene allows the prosthetic to feed signals back to the user of both temperature and contact pressure. The trick is that the graphene skin is incredibly transparent, reportedly allowing 98% of light on its surface to pass through. It’s then a simple matter of fitting solar panels beneath this skin, and the energy harvested can then be used to power the sensor system.
The team does admit that some power storage will later be required, as it would be difficult for any prosthetic user if their limbs lost all feedback when they walked into a dark room. The idea of one’s arm losing all feeling upon going to bed isn’t particularly appealing. Check out the paper here (paywalled). Video below the break.
We see a lot of great prosthetic projects cross our desk here at Hackaday – like this 3D printed prosthetic hand. Prosthetics definitely matter, so why not build your own and enter it in the 2017 Hackaday Prize?
Continue reading “Solar-Powered Prosthetic Skin”
Linear Clock Slows The Fugit Of The Tempus
We feature a lot of clocks here on Hackaday, and lately most of them seem to be Nixie clocks. Not that there’s anything wrong with that, but every once in a while it’s nice to see something different. And this electromechanical rack and pinion clock is certainly different.
[JON-A-TRON] calls his clock a “perpetual clock,” perhaps in a nod to perpetual calendars. But in our opinion, all clocks are perpetual, so we’ll stick with “linear clock.” Whatever you call it, it’s pretty neat. The hour and minute indicators are laser cut and engraved plywood, each riding on a rack and pinion. Two steppers advance each rack incrementally, so the resolution of the clock is five minutes. [JON-A-TRON] hints that this was a design decision, in part to slow the perceived pace of time, an idea we can get behind. But as a practical matter, it greatly simplified the gear train; it would have taken a horologist like [Chris] at ClickSpring to figure out how to gear this with only one prime mover.
In the end, we really like the look of this clock, and the selection of materials adds to the aesthetic. And if you’re going to do a Nixie clock build, do us a favor and at least make it levitate.
Continue reading “Linear Clock Slows The Fugit Of The Tempus”
Cerebrum: Mobile Passwords Lifted Acoustically With NASB
There are innumerable password hacking methods but recent advances in acoustic and accelerometer sensing have opened up the door to side-channel attacks, where passwords or other sensitive data can be extracted from the acoustic properties of the electronics and human interface to the device. A recent and dramatic example includes the hacking of RSA encryption  simply by listening to the frequencies of sound a processor puts out when crunching the numbers.
Now there is a new long-distance hack on the scene. The Cerebrum system represents a recent innovation in side-channel password attacks leveraging acoustic signatures of mobile and other electronic devices to extract password data at stand-off distances.
Continue reading “Cerebrum: Mobile Passwords Lifted Acoustically With NASB”
Scratchy Brings Digital Clarity To The Vinyl World
If you walk the halls of audiophilia, you may be aware that there has been a huge amount of work put in to software designed to clean up older audio recordings without compromising the quality of the recording itself. Sometimes the results can be amazing, such as when a stereo image is created from parallel mono recordings made before stereo was even a glint in the eye of a 1930s EMI engineer.
Bob Widlar on analogue versus digital. Original: EDN
[Bob Widlar] on analogue versus digital. Original: EDN.
But what if you are at home, without the benefit of a state-of-the-art studio or high-end digital signal processing? How can you then have pop and crackle free sound from your hi-fi when you put on a piece of vinyl? [Paul Wallace] may just have the answer, he’s made a smartphone app called Scratchy which listens to the output of a turntable, identifies the track being played, and plays the appropriate MP3 file for a digital experience from vinyl. It uses the algorithm published by Shazam to recognize tunes. The software also has a learn mode during which it can be taught about new records in the collection. The app itself is written using the Xamarin framework and has its source code in his GitHup repository, so it’s possible it could be produced for other platforms as well as Android.
Now vinyl purists will be speechless with horror at this wanton desecration of their format while audiophiles will be fuming at the smeary-in-the-midrange MP3s, but we can see its appeal if your vinyl is on the grubby side. It’s fair to say though that the stereo here won’t be sporting it, you’ll tear our analogue signal path from our cold dead hands. Take a look for yourselves, he’s put up a video showing it in operation.
Continue reading “Scratchy Brings Digital Clarity To The Vinyl World”
Ask Hackaday: Which Balaclava Is Best For Hacking?
At Hackaday, we’re tapped into Hacker Culture. This goes far beyond a choice of operating system (Arch Linux, or more correctly, ‘Arch GNU/Linux’, or as I’ve recently taken to calling it, ‘Arch GNU plus Linux’).  This culture infects every fiber of our soul, from music (DEF CON’s station on Soma FM), our choice in outerwear (black hoodies, duh), and our choice in laptops (covered in stickers). We all wear uniforms, although a gaggle of computer science and electronics nerds all wearing black t-shirts won’t tell you that. We all conform, whether we’re aware of it or not.
Despite a standardized uniform for this subculture, one small detail of this Hacker Uniform has remained unresolved for decades. Are one-hole or three-hole balaclavas best for hacking? Which balaclava is best for stealing bank accounts and hacking into NASA computers? What offers the best protection from precipitating ones and zeros in a real-life Matrix screensaver?
Continue reading “Ask Hackaday: Which Balaclava Is Best For Hacking?”
Quadruped Robot Can Crawl Under Cars And Jump-Kick-Open Doors
The wheel is a revolutionary invention — as they say — but going back to basics sometimes opens new pathways. Robots that traverse terrain on legs are on the rise, most notably the Boston Dynamics Big Dog series of robots — and [Ghost Robotics]’ Minitaur quadruped aims to keep pace.
One of [Ghost Robotics] founders, [Gavin Knneally] states that co-ordination is one of the main problems to overcome when developing quadruped robots; being designed to clamber across especially harsh terrain, Minitaur’s staccato steps carry it up steep hills, stairs, across ice, and more. Its legs also allow it to adjust its height — the video shows it trot up to a car, hunker down, then begin to waddle underneath with ease.
Continue reading “Quadruped Robot Can Crawl Under Cars And Jump-Kick-Open Doors”
Review: The O-scope Mayer D4/WG5 Calibrated Fleshy Test Probe
A selection of probes, from [Jim Williams'] Linear Technology app note 72.
A selection of probes, from [Jim Williams’] Linear Technology app note 72.
It’s not often that we are shown an entirely new class of test equipment here at Hackaday, so it was with some surprise that we recently received the new O-scope Mayer offering. If your most simple piece of test equipment is your own finger, able to measure temperature, detect voltage, and inject a 50 or 60 Hz sine wave, then what they have done is produce a synthetic analogue with a calibrated reading. The idea is that where previously you could only say “Too hot!”, or “High voltage!”, you should now be able to use their calibrated probe to gain an accurate reading.
The O-scope Mayer D4/WG5 Calibrated Fleshy Test Probe is a roughly 4″ (100mm) long cylinder of their InteliMeat™ synthetic finger analogue terminated with a calibrated matching unit and a BNC socket. In the box aside from the instruction leaflet is a BNC lead through which you can connect it to your oscilloscope.
Continue reading “Review: The O-scope Mayer D4/WG5 Calibrated Fleshy Test Probe”
