A Non-Musical Use Case For 8-Track
There was a time in the not-too-distant past when magnetic tape was the primary way of listening to and recording audio. Most of us are familiar with the cassette tape, a four-track system that plays first one side of the tape, then the other. There was the eight-track tape as well which did not have quite as much popularity or longevity but did have a few interesting features that [Serial Hobbyism] took advantage of to make an interactive game.
The defining feature of the eight-track system, beyond the obvious eight tracks on the tape, is that the tape runs in a continuous loop, never needing to be stopped or flipped over. Instead, four buttons select pairs of the eight tracks, moving a head immediately to make the switch on-the-fly. [Serial Hobbyism]’s game plays a trivia-style audio recording and asks the player to answer questions by pushing one of the four “program” buttons to switch tracks. If the correct track is selected, the recorded audio congratulates the player and then continues on with the game. Likewise, if an incorrect track is selected, the recording notes that and the game continues.
Another interesting feature of this game is that it can be played without modifying an eight-track player, as the selectable tracks are a core function of this technology. They can be used in a similar way as cassette tapes to store computer data and a data recorder similar to the eight-track system was used on the Voyager space probes, although these only bear a passing resemblance.
Continue reading “A Non-Musical Use Case For 8-Track”
IBM’s Latest Quantum Supercomputer Idea: The Hybrid Classical-Quantum System
Although quantum processors exist today, they are still a long way off from becoming practical replacements for classical computers. This is due to many practical considerations, not the least of which are factors such as the need for cryogenic cooling and external noise affecting the system necessitating a level of error-correction which does not exist yet. To somewhat work around these limitations, IBM has now pitched the idea of a hybrid quantum-classical computer (marketed as ‘quantum-centric supercomputing’), which as the name suggests combines the strengths of both to create a classical system with what is effectively a quantum co-processor.
IBM readily admits that nobody has yet demonstrated quantum advantage, i.e. that a quantum computer is actually better at tasks than a classical computer, but they figure that by aiming for quantum utility (i.e. co-processor level), it could conceivably accelerate certain tasks for a classical computer much like how a graphics processing unit (GPU) is used to offload everything from rendering graphics to massively parallel computing tasks courtesy of its beefy vector processing capacity. IBM’s System Two is purported to demonstrate this when it releases.
What the outcome here will be is hard to say, as the referenced 2023 quantum utility demonstration paper involving an Ising model was repeatedly destroyed by classical computers and even trolled by a Commodore 64-based version. Thus, at the very least IBM’s new quantum utility focus ought to keep providing us with more popcorn moments like those, and maybe a usable quantum system will roll out by the 2030s if IBM’s projected timeline holds up.
Hands hold a set of white, 3D printed connectors above a wooden table. They look like a cross between a ballpoint pen tip and a spider. The shorter one on the right has yellow, green, black, purple, and white wires coming out the top.
SWD Interface Simplifies Debugging
The proliferation of microcontrollers has made it easier than ever to add some smarts to a project, but sometimes there just isn’t enough space for headers on a board, or you feel a little silly soldering something that will get used to flash a program then languish inside your build. [Dima] wanted to make his boards easier to flash, and developed a PCB footprint and flashing tool pair that makes use of the mounting holes on his boards.
While some debugging tools might use a clamp or tape, [Dima] discovered that using sprung pins only on one side of the connector wedged his fixed locator pin (originally a 1 mm drill bit) into the hole removing the need for any other holding mechanism.
His original prototype worked so well that it took him some time to get back around to making a more reproducible design that didn’t involve fine soldering and superglue. After enlarging the contact pads and several iterations of 3D printing, he developed an interface connector that uses standard jumper wires and a steel rod to provide a sturdy and reliable connection for flashing boards with the corresponding footprint. He’s currently a little disappointed with the overall size of the connector though, and is soliciting feedback on how to make it smaller.
While [Dima]’s MCU of choice is the STM32, but this design should be applicable to any other microcontrollers using a five wire system, or you could take one off for USB. Having trouble finding the SWD points on an existing device? Try this method.
Thanks to [DjBiohazard] for the tip!
Continue reading “SWD Interface Simplifies Debugging”
Hardware Bug In Raspberry Pi’s RP2350 Causes Faulty Pull-Down Behavior
Erratum RP2350-E9 in the RP2350 datasheet, detailing the issue.
The newly released RP2350 microcontroller has a confirmed new bug in the current A2 stepping, affecting GPIO pull-down behavior. Listed in the Raspberry Pi RP2350 datasheet (page 1340) as erratum RP2350-E9, it involves a situation where a GPIO pin is configured as a pull-down with input buffer enabled. After this pin is then driven to Vdd (e.g. 3.3V) and then disconnected, it will stay at around 2.1 – 2.2 V for a Vdd of 3.3V. This issue was discovered by [Ian Lesnet] of [Dangerous Prototypes] while working on an early hardware design using this MCU.
The suggested workaround by Raspberry Pi is to enable the input buffer before a read, and disable it again immediately afterwards. Naturally, this is far from ideal workaround, and the solution that [Ian] picked was to add external pull-down resistors. Although this negates the benefits of internal pull-down resistors, it does fix the issue, albeit with a slightly increased board size and BOM part count.
As for the cause of the issue, Raspberry Pi engineer [Luke Wren] puts the blame on an external IP block vendor. With hindsight perhaps running some GPIO validation tests involving pull-up and pull-down configurations with and without input buffer set could have been useful, but we’re guessing they may be performed on future Pi chips. Maybe treating the RP2350 A0 stepping as an ‘engineering sample’ is a good idea for the time being, with A3 (or B0) being the one you may want to use in actual production.
In some ways this feels like déjà vu, as the Raspberry Pi 4 and previous SBCs had their own share of issues that perhaps might have been caught before production.
(Note: original text listed A0 as current stepping, which is incorrect. Text has been updated correspondingly)
FLOSS Weekly Episode 798: Building The Rust Desktop With COSMIC
This week Jonathan Bennett and Rob Campbell chat with Carl Richell about System 76, COSMIC, Wayland, Rust and more! What was the “last straw” that convinced System 76 to write their own desktop environment (DE)? What’s the story with smithay, and why did that jump start the whole process? Listen to find out!
Continue reading “FLOSS Weekly Episode 798: Building The Rust Desktop With COSMIC”
Boss Byproducts: Fordites Are Pieces Of American History
Some of the neatest products are made from the byproducts of other industries. Take petroleum jelly, for example. Its inventor, Robert Chesebrough, a chemist from New York, came upon his idea while visiting the oil fields of Titusville, Pennsylvania in 1859. It took him ten years to perfect his formula, but the product has been a household staple ever since. Chesebrough so believed in Vaseline that he ingested a spoonful of it every day, and attributed his 96-year longevity to doing so.
Well, some byproducts can simply be beautiful, or at least interesting. On that note, welcome to a new series called Boss Byproducts. We recently ran an article about a laser-engraved painting technique that is similar to the production of Fordite. I had never heard of Fordite, but as soon as I found out what it was, I had to have some. So, here we go!
Continue reading “Boss Byproducts: Fordites Are Pieces Of American History”
The Commodordion Gets A Big Usability Upgrade
The chiptune scene is dominated by Game Boys and other Nintendo hardware, but one should never forget the gorgeous, beautiful tones that come from the hallowed Commodore 64. [Linus Ã…kesson] knows this well, and it’s at the heart of his work on the Commodordion. Now, he’s built an even better version.
The original idea he had was to build an accordion-like control surface for the SID chip in a Commodore 64. The device is capable of creating beautiful accordion-like music with a simple 8-bit flair. He has since dubbed the original Commodordion the “bass Commodordion,” while the new version is classified as a tenor instrument.
The prime upgrades are ergonomic. The previous instrument was too heavy, with the left hand having to carry an entire Commodore 64 on its own. It was also hard to reach the keys. The new version is much lighter, with one of the two C64s of the original having been removed. The supporting electronics have been redesigned to more neatly fit into a space behind the bellows.
The result is a machine that’s far easier to play, and one that won’t injure the user in extended play sessions. “It’s now a pleasure, not a pain,” says [Linus]. The payoff in usability is obvious, and the tunes themselves are hauntingly beautiful.
We first covered the Commordordion back in 2022, but it wasn’t the first time we saw one of [Linus]’s impressive creations.
Continue reading “The Commodordion Gets A Big Usability Upgrade”
