Lockdown Remote Control Project Is Free And Open
If you flew or drove anything remote controlled until the last few years, chances are very good that you’d be using some faceless corporation’s equipment and radio protocols. But recently, open-source options have taken over the market, at least among the enthusiast core who are into squeezing every last bit of performance out of their gear. So why not take it one step further and roll your own complete system?
Apparently, that’s what [Malcolm Messiter] was thinking when, during the COVID lockdowns, he started his own RC project that he’s calling LockDownRadioControl. The result covers the entire stack, from the protocol to the transmitter and receiver hardware, even to the software that runs it all. The 3D-printed remote sports a Teensy 4.1 and off-the-shelf radio modules on the inside, and premium FrSky hardware on the outside. He’s even got an extensive folder of sound effects that the controller can play to alert you. It’s very complete. Heck, the transmitter even has a game of Pong implemented so that you can keep yourself amused when it’s too rainy to go flying.
Of course, as we alluded to in the beginning, there is a healthy commercial infrastructure and community around other open-source RC projects, namely ExpressLRS and OpenTX, and you can buy gear that runs those software straight out of the box, but it never hurts to have alternatives. And nothing is easier to customize and start hacking on than something you built yourself, so maybe [Malcolm]’s full-stack RC solution is right for you? Either way, it’s certainly impressive for a lockdown project, and evidence of time well spent.
Thanks [Malcolm] for sending that one in!
The Transputer In Your Browser
We remember when the transputer first appeared. Everyone “knew” that it was going to take over everything. Of course, it didn’t. But [Oscar Toledo G.] gives us a taste of what life could have been like with a JavaScript emulator for the transputer, you can try in your browser.
If you don’t recall, the transputer was a groundbreaking CPU architecture made for parallel processing. Instead of giant, powerful CPUs, the transputer had many simple CPUs and a way to chain them all together. Sounds great, but didn’t quite make it. However, you can see the transputer’s influence on CPUs even today.
Continue reading “The Transputer In Your Browser”
First PCB With The Smallest MCU?
[Morten] works very fast. He has already designed, fabbed, populated, and tested a breakout board for the new tiniest microcontroller on the market, and he’s even made a video about it, embedded below.
You might have heard about this new TI ARM Cortex MO micro on these very pages, where we asked you what you’d do with this grain-of-rice-sized chunk of thinking sand. (The number one answer was “sneeze and lose it in the carpet”.)
From the video, it looks like [Morten] would design a breakout board using Kicad 8, populate it, get it blinking, and then use its I2C lines to make a simple digital thermometer demo. In the video, he shows how he worked with the part, from making a custom footprint to spending quite a while nudging it into place before soldering it carefully down.
But he nailed it on the first try, and honestly it doesn’t look nearly as intimidating as we’d feared, mostly because of the two-row layout of the balls. It actually looks easy enough to fan out. Because you can’t inspect the soldering work underneath the chip, he broke out all of the lines to a header to make it quick to check for shorts between those tiny little balls. Smart.
We love to see people trying out the newest hotness. Let us know down in the comments what new parts you’re trying out.
Continue reading “First PCB With The Smallest MCU?”
Vintage Computer Festival East This Weekend
If you’re on the US East Coast, you should head on over to Wall, NJ and check out the Vintage Computer Festival East. After all, [Brian Kernighan] is going to be there. Yes, that [Brian Kernighan].
Events are actually well underway, and you’ve already missed the first few TRS-80 Color Computer programming workshops, but rest assured that they’re going on all weekend. If you’re from the other side of the retrocomputing fence, namely the C64 side, you’ve also got a lot to look forward to, because the theme this year is “The Sounds of Retro” which means that your favorite chiptune chips will be getting a workout.
[Tom Nardi] went to VCF East last year, so if you’re on the fence, just have a look at his writeup and you’ll probably hop in your car, or like us, wish you could. If when you do end up going, let us know how it was in the comments!
Supercon 2024: Quick High-Feature Boards With The Circuit Graver
These days, if you want to build something with modern chips and components, you probably want a custom PCB. It lets you build a neat and compact project that has a certain level of tidiness and robustness that you can’t get with a breadboard or protoboard. The only problem is that ordering PCBs takes time, and it’s easy to grow tired of shipping delays when you don’t live in the shadow of the Shenzhen board houses.
[Zach Fredin] doesn’t suffer this problem, himself. He’s whipping up high-feature PCBs at home with speed and efficiency that any maker would envy. At the 2024 Hackaday Supercon, he was kind enough to give a talk to explain the great engineering value provided by the Circuit Graver.
Continue reading “Supercon 2024: Quick High-Feature Boards With The Circuit Graver”
Hackaday Podcast Episode 315: Conductive String Theory, Decloudified Music Players, And Wild Printing Tech
This week, Hackaday’s Elliot Williams and Kristina Panos met up across the (stupid, lousy) time zones to bring you the latest news, mystery sound, and of course, a big bunch of hacks from the previous week.
Again, no news is good news. On What’s That Sound, Kristina didn’t get close at all, but at least had a guess this time. If you think you can identify the sound amid all the talking, you could win a Hackaday Podcast t-shirt!
After that, it’s on to the hacks and such, beginning with a Dr. Jekyll and Mr. Hyde situation when it comes to a pair of formerly-cloud music players. We take a look at a crazy keyboard hack, some even crazier conductive string, and a perfectly cromulent list of 70 DIY synths on one wild webpage. Finally, we rethink body art with LEDs, and take a look at a couple of printing techniques that are a hundred years or so apart in their invention.
Check out the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Download in DRM-free MP3 and savor at your leisure.
Continue reading “Hackaday Podcast Episode 315: Conductive String Theory, Decloudified Music Players, And Wild Printing Tech”
3D Print (and Play!) The Super Mario Tune As A Fidget Toy
[kida] has a highly innovative set of 3D-printable, musical fidget toys that play classic video game tunes. Of course there’s the classic Super Mario ditty, but there’s loads more. How they work is pretty nifty, and makes great use of a 3D printer’s strengths.
To play the device one uses a finger to drag a tab (or striker) across the top, and as it does so it twangs vertical tines one-by-one. Each tine emits a particular note — defined by how tall the thicker part is — and plays a short tune as a result. Each one plays a preprogrammed melody, with the tempo and timing up to the user. Listen to them in action in the videos embedded just under the page break!
There are some really clever bits to the design. One is that the gadget is made in two halves, which effectively doubles the notes one can fit into the space. Another is that it’s designed so that holding it against something like a tabletop makes it louder because the surface acts like a sounding board. Finally, the design is easily modified so making new tunes is easy. [kida]’s original design has loads of non-videogame tunes (like the Jeopardy! waiting theme) as well as full instructions on making your very own versions.
Fidget toys are a niche all their own when it comes to 3D printed devices. The fidget knife has a satisfying snap action to it, and this printable linear toggle design is practically a fidget toy all on its own.
Continue reading “3D Print (and Play!) The Super Mario Tune As A Fidget Toy”
