Built-In Batteries: A Daft Idea With An Uncertain Future
Having a gadget’s battery nestled snugly within the bowels of a device has certain advantages. It finally solves the ‘no batteries included’ problem, and there is no more juggling of AA or AAA cells, nor their respective chargers. Instead each device is paired to that one battery that is happily charged using a standardized USB connector, and suddenly everything is well in the world.
Everything, except for the devices that cannot be used while charging, wireless devices that are suddenly dragging along a wire while charging and which may have charging ports in irrational locations, as well as devices that would work quite well if it wasn’t for that snugly embedded battery that’s now dead, dying, or on fire.
Marrying devices with batteries in this manner effectively means tallying up all the disadvantages of the battery chemistries and their chargers, adding them to the device’s feature list, and limiting their effective lifespan in the process. It also prevents the rapid swapping with fresh batteries, which is why everyone is now lugging chunky powerbanks around instead of spare batteries, and hogging outlets with USB chargers. And the task of finding a replacement for non-standardized pouch cell batteries can prove to be hard or impossible.
Looking at the ‘convenience’ argument from this way makes one wonder whether it is all just marketing that we’re being sold. Especially in light of the looming 2027 EU regulation on internal batteries that is likely to wipe out the existence of built-in batteries with an orbital legal strike. Are we about to say ‘good riddance’ to a terrible idea?
Continue reading “Built-In Batteries: A Daft Idea With An Uncertain Future”
Why Does The FCC Care About Computers?
Unless you are over a certain age, you probably take it for granted that electronic gadgets you buy have some FCC marking on them. But it wasn’t always true. [Ernie] submits that the FCC’s regulation of the computer industry was indirectly the result of the success of CB radio in that same time period.
Today, there is a high chance you don’t watch TV directly over the airwaves or even consume audio from a traditional radio station. Even if you do, the signal is increasingly likely to be digital. But only analog radio and TV were highly susceptible to interference. When a professional radio station or the power company interfered with you watching I Love Lucy, you could count on them to resolve it. Even ham radio operators, a small segment of the population, would, in general, graciously help you if their transmissions interfered with your equipment.
Never mind that, in many cases, it was the cheap TV or some other problem on the receiving end. Then there was another source of potential interference: CB radio. At first, you were about as likely to encounter a CB operator as a ham radio operator. But then in the 1970s, CB exploded, becoming a cultural phenomenon, and you can hear what a state it was in by watching the contemporary TV report in the video below.
Continue reading “Why Does The FCC Care About Computers?”
Making A Clock With A Retooled Unihiker K10
The Unihiker K10 is intended to be a small single-board solution for light AI and machine learning tasks. However, you don’t have to use it in that way if you don’t want to. [mircemk] figured out how to repurpose the device, and whipped up a simple Internet clock build to demonstrate how it’s done.
While the Unihiker K10 is based on the common ESP32 microcontroller, out of the box, it isn’t compatible with standard Arduino libraries. However, [mircemk] had previously figured out how to get the K10 to play nice with the Arduino environment, building a simple light meter as a proof of concept. It just took a little tinkering to get everything playing nicely together, but soon enough, the TFT LCD and a light sensor were playing nicely with the K10 platform.
Moving forward, [mircemk] wanted to unlock more capability, so set about figuring out how to get WiFi and the onboard buttons working within the Arduino environment. A great way to test this was building a clock—the screen would show an analog clock face, the buttons would be used for control, and the WiFi would be used to query an NTP time server to keep it synced up and accurate.
It took a little work, particularly as the buttons are accessed through an external I/O expansion chip, but [mircemk] got there in the end. The clock may not be a particularly advanced project, but the write-up demonstrates how the K10 can readily be used with Arduino libraries for when you’re not interested in leveraging its fancier AI/ML capabilities.
We’ve seen a few good builds from [mircemk] before, too, like this neat proximity sensor. Continue reading “Making A Clock With A Retooled Unihiker K10”
