Running Video Through A Guitar Effects Pedal
Guitar pedals are designed to take in a sound signal, do fun stuff to it, and then spit it out to your amplifier where it hopefully impresses other people. However, [Liam Taylor] decided to see what would happen if you fed video through a guitar pedal instead.
The device under test is a Boss ME-50 multi-effects unit. It’s capable of serving up a wide range of effects, from delay to chorus to reverb, along with compression and distortion and a smattering of others. [Liam] hooked up the composite video output from an old Sony camcorder from the 2000s to a 3.5 mm audio jack, and plugged it straight into the auxiliary input of the ME-50 (notably, not the main guitar input of the device).
The multi-effects pedal isn’t meant to work with an analog video signal, but it can pass it through and do weird things to it regardless. Using the volume pedal on the ME-50 puts weird lines on the signal, while using a wah effect makes everything a little wobbly. [Liam] then steps through a whole range of others, like ring modulation, octave effects, and reverb, all of which do different weird things to the visuals. Particularly fun are some of the periodic effects which create predictable variation to the signal. True to its name, the distortion effect did a particularly good job of messing things up overall.
It’s a fun experiment, and recalls us of some of the fantastic analog video synths of years past. Video after the break.
Continue reading “Running Video Through A Guitar Effects Pedal” →
Trying A Vibe-Coded Operating System
If you were to read the README of the Vib-OS project on GitHub, you’d see it advertised as a Unix-like OS that was written from scratch, runs on ARM64 and x86_64, and comes with a full GUI, networking and even full Doom game support. Unfortunately, what you are seeing there isn’t the beginnings of a new promising OS that might go toe to toe with the likes of Linux or Haiku, but rather a vibe-coded confabulation. Trying to actually use the OS as [tirimid] recently did sends you down a vibe-coded rabbit hole of broken code, more bugs than you can shake a bug zapper at, and most of the promised features being completely absent.
[tirimid] is one of those people who have a bit of a problem, in that they like to try out new OSes, just to see what they’re like. The fun starts with simply making the thing run at all in any virtual machine environment, as apparently the author uses MacOS and there it probably ‘runs fine’.
After this the graphical desktop does in fact load, some applications also open, but it’s not possible to create new folders in the ‘file explorer’, the function keys simply switch between wallpapers, there’s no networking or Doom support despite the promises made, there’s no Python or Nano support at all, and so on.
Clearly it’s still got the hallmarks of a functioning OS, and it’s sort of nice that you don’t need to know what you’re doing to create a sort-of-OS, but it will not appease those who feel that vibe-coding is killing Open Source software.
Continue reading “Trying A Vibe-Coded Operating System” →
A 3D-printed mechanism is clamped between the jaws of a pair of calipers, which are surrounded by 3D-printed covers. A hammer is resting against one of the jaws, and a man's gloved hand is holding the calipers.
Embossing Precision Ball Joints For A Micromanipulator
[Diffraction Limited] has been working on a largely 3D-printed micropositioner for some time now, and previously reached a resolution of about 50 nanometers. There was still room for improvement, though, and his latest iteration improves the linkage arms by embossing tiny ball joints into them.
The micro-manipulator, which we’ve covered before, uses three sets of parallel rod linkages to move a platform. Each end of each rod rotates on a ball joint. In the previous iteration, the parallel rods were made out of hollow brass tubing with internal chamfers on the ends. The small area of contact between the ball and socket created unnecessary friction, and being hollow made the rods less stiff. [Diffraction Limited] wanted to create spherical ball joints, which could retain more lubricant and distribute force more evenly.
The first step was to cut six lengths of solid two-millimeter brass rod and sand them to equal lengths, then chamfer them with a 3D-printed jig and a utility knife blade. Next, they made two centering sleeves to hold small ball bearings at the ends of the rod being worked on, while an anti-buckling sleeve surrounded the rest of the rod. The whole assembly went between the jaws of a pair of digital calipers, which were zeroed. When one of the jaws was tapped with a hammer, the ball bearings pressed into the ends of the brass rod, creating divots. Since the calipers measured the amount of indentation created, they was able to emboss all six rods equally. The mechanism is designed not to transfer force into the calipers, but he still recommends using a dedicated pair.
In testing, the new ball joints had about a tenth the friction of the old joints. They also switched out the original 3D-printed ball mount for one made out of a circuit board, which was more rigid and precisely manufactured. In the final part of the video, he created an admittedly unnecessary, but useful and fun machine to automatically emboss ball joints with a linear rail, stepper motor, and position sensor.
On such a small scale, a physical ball joint is clearly simpler, but on larger scales it’s also possible to make flexures that mimic a ball joint’s behavior.
Gwiz car and vapes
Vape-powered Car Isn’t Just Blowing Smoke
Disposable vapes aren’t quite the problem/resource stream they once were, with many jurisdictions moving to ban the absurdly wasteful little devices, but there are still a lot of slightly-smelly lithium batteries in the wild. You might be forgiven for thinking that most of them seem to be in [Chris Doel]’s UK workshop, given that he’s now cruising around what has to be the world’s only vape-powered car.
Technically, anyway; some motorheads might object to calling donor vehicle [Chris] starts with a car, but the venerable G-Wiz has four wheels, four seats, lights and a windscreen, so what more do you want? Horsepower in excess of 17 ponies (12.6 kW)? Top speeds in excess of 50 Mph (80 km/h)? Something other than the dead weight of 20-year-old lead-acid batteries? Well, [Chris] at least fixes that last part.
The conversion is amazingly simple: he just straps his 500 disposable vape battery pack into the back seat– the same one that was powering his shop–into the GWiz, and it’s off to the races. Not quickly, mind you, but with 500 lightly-used lithium cells in the back seat, how fast would you want to go? Hopefully the power bank goes back on the wall after the test drive, or he finds a better mounting solution. To [Chris]’s credit, he did renovate his pack with extra support and insulation, and put all the cells in an insulated aluminum box. Still, the low speed has to count as a safety feature at this point.
Charging isn’t fast either, as [Chris] has made the probably-controversial decision to use USB-C. We usually approve of USB-Cing all the things, but a car might be taking things too far, even one with such a comparatively tiny battery. Perhaps his earlier (equally nicotine-soaked) e-bike project would have been a better fit for USB charging.
Thanks to [Vaughna] for the tip! Continue reading “Vape-powered Car Isn’t Just Blowing Smoke” →
FLOSS Weekly Episode 865: Multiplayer Firewall
This week Jonathan chats with Philippe Humeau about Crowdsec! That company created a Web Application Firewall as on Open Source project, and now runs it as a Multiplayer Firewall. What does that mean, and how has it worked out as a business concept? Watch to find out!
Continue reading “FLOSS Weekly Episode 865: Multiplayer Firewall” →
Linux Fu: The USB WiFi Dongle Exercise
The TX50U isn’t very Linux-friendly
If you’ve used Linux for a long time, you know that we are spoiled these days. Getting a new piece of hardware back in the day was often a horrible affair, requiring custom kernels and lots of work. Today, it should be easier. The default drivers on most distros cover a lot of ground, kernel modules make adding drivers easier, and dkms can automate the building of modules for specific kernels, even if it isn’t perfect.
So ordering a cheap WiFi dongle to improve your old laptop’s network connection should be easy, right? Obviously, the answer is no or this would be a very short post.
Plug and Pray
The USB dongle in question is a newish TP-Link Archer TX50U. It is probably perfectly serviceable for a Windows computer, and I got a “deal” on it. Plugging it in caused it to show up in the list of USB devices, but no driver attached to it, nor were any lights on the device blinking. Bad sign. Pro tip: lsusb -t will show you what drivers are attached to which devices. If you see a device with no driver, you know you have a problem. Use -tv if you want a little more detail.
The lsusb output shows the devices as a Realtek, so that tells you a little about the chipset inside. Unfortunately, it doesn’t tell you exactly which chip is in use.
Continue reading “Linux Fu: The USB WiFi Dongle Exercise” →
Success With FreeDOS On A Modern Platform
Last summer we took a look at FreeDOS as part of the Daily Drivers series, and found a faster and more complete successor to the DOS of old. The sojourn into the 16-bit OS wasn’t perfect though, as we couldn’t find drivers for the 2010-era network card on our newly DOS-ified netbook. Here’s [Inkbox] following the same path, and bringing with it a fix for that networking issue.
The video below is an affectionate look at the OS alongside coding a TRON clone in assembler, and it shows a capable environment within the limitations of the 16-bit mode. The modern laptop here can’t emulate a BIOS as it’s UEFI only, and after trying a UEFI-to-BIOS emulator with limited success, he hits on a different approach. With just enough Linux to support QEMU, he has a lightweight and extremely fast x86 BIOS platform with the advantage of legacy emulation of network cards and the like.
The point of Daily Drivers is wherever possible to use real hardware and not an emulator, as it’s trying to be the machine you’d use day to day. But we can see in a world where a BIOS is no longer a thing it becomes ever more necessary to improvise, and this approach is better than just firing up an emulator from a full-fat Linux desktop. If you fancy giving it a try, it seems less pain than the route we took.
You can read our look at FreeDOS 1.4 here.
Continue reading “Success With FreeDOS On A Modern Platform” →
