Metal Detector Built With Smartphone Interface
If you think of a metal detector, you’re probably thinking of a fairly simple device with a big coil and a piercing whine coming from a tinny speaker. [mircemk] has built a more modern adaptation. It’s a metal detector you can use with your smartphone instead.
The metal detector part of the project is fairly straightforward as far as these things go. It uses the pulse induction technique, where short pulses are fired through a coil to generate a magnetic field. Once the pulse ends, the coil is used to detect the decaying field as it spreads out. The field normally fades away in a set period of time. However, if there is metal in the vicinity, the time to decay changes, and by measuring this, it’s possible to detect the presence of metal.
In this build, an ESP32 is in charge of the show, generating the necessary pulses and detecting the resulting field. It’s paired with the usual support circuitry—an op-amp and a few transistors to drive the coil appropriately, and the usual smattering of passives. The ESP32 then picks up the signal from the coil and processes it, passing the results to a smartphone via Bluetooth.
The build is actually based on a design by [Neco Desarrollo], who presents more background and other variants for the curious. We’ve featured plenty of [mircemk]’s projects before, like this neat proximity sensor build. Continue reading “Metal Detector Built With Smartphone Interface” →
The Engineer Behind Mine Detection
According to [Joanna Goodrich]  in IEEE Spectrum, prior to World War II, soldiers who wanted to find land mines, simply poked at the ground with pointed sticks or bayonets. As you might expect, this wasn’t very safe or reliable. In 1941, a Polish signals officer, [Józef Stanislaw Kosacki], escaped to Britain and created an effective portable mine detector.
[Kosaci] was an electrical engineer trained at the Warsaw University of Technology. He had worked as a manager for the Polish National Telecommunication Institute. In 1937, the government tasked him with developing a machine that could detect unexploded grenades and shells. The machine was never deployed.
When Germany invaded Poland in 1939, [Kosacki] returned to military service (he had done a year of compulsory service earlier). He was captured and kept in a prison camp in Hungary. But he managed to escape in late 1939 and joined the Polish Army Corps in Britain, teaching Morse code to soldiers.
Continue reading “The Engineer Behind Mine Detection” →
DIY Metal Detector
If you want to get rich by hunting with a metal detector, you might want to consider how much you invested in the hardware to start with. Finding a tin can with a $200 detector might not make economic sense. But building a metal detector yourself doesn’t have to be hard, as [Mirko] shows in a recent post. His STM32-based pulse induction metal detector looks good and works well, as you can see in the video below.
[Mirko] reports that the device can detect a coin at 30 cm and a large metal object at more than 80 cm. The project uses the Arduino IDE and a Blue Pill STM32 module. The project looks good with an LED module and a rotary encoder to set sensitivity.
Continue reading “DIY Metal Detector” →
A No-Calibration Metal Detector
A traditional early project for someone discovering a love for electronics has been for many years a metal detector. This would mean a few transistors back in the day, but today it’s more likely to involve a microcontroller. [Mircemk] has an example that bends both worlds, with a single transistor oscillator and an Arduino.
This type of metal detector has a large search coil which forms part of the tuned circuit in an oscillator. As a piece of metal enters its range the frequency of oscillation changes. In the old days, this would have been detected as an audible beat frequency with another oscillator. This design would require a calibration step at the start of detecting, to tune the two oscillators to the same frequency.
This detector keeps the first oscillator but eschews the second one in favor of an Arduino. The microcontroller acts as a frequency counter, monitoring the frequency and issuing an alarm when it detects a change likely to be caused by a piece of metal. It may not have some of the finess a human ear could apply to a beat frequency in the all-analogue days, but it’s simple enough to build and it avoids the need for calibration. Seeing it in the video below the break we’re sure that just like those transistor models old, there will be plenty of fun to be had with it.
An Arduino may be one of the current go-to parts, but will it ever displace the 555? Perhaps not in the world of metal detectors!
Continue reading “A No-Calibration Metal Detector” →
Metal Detector Gets Help From Smartphone
[mircemk] is quite a wizard when it comes to using coils of wires in projects, especially when their application is within easy-to-build metal detectors. There are all kinds of ways to send signals through coiled wire to detect metal objects in the ground, and today [mircemk] is demonstrating a new method he is experimenting with which uses a smartphone to detect the frequency changes generated by the metal detector.
Like other metal detectors, this one uses two coils of wire with an oscillator circuit and some transistors. The unique part of this build, though, is how the detector alerts the user to a piece of metal. Normally there would be an audible alert as the frequencies of the circuit change when in the presence of metal, but this one uses a smartphone to analyze the frequency information instead. The circuit is fed directly into the headphone jack on the smartphone and can be calibrated and used from within an Android app.
Not only can this build detect metal, but it can discriminate between different types of metal. [mircemk] notes that since this was just for experimentation, it needs to be calibrated often and isn’t as sensitive as others he’s built in the past. Of course this build also presumes that your phone still has a headphone jack, but we won’t dig up that can of worms for this feature. Instead, we’ll point out that [mircemk] has shown off other builds that don’t require any external hardware to uncover buried treasure.
Continue reading “Metal Detector Gets Help From Smartphone” →
DIY Metal Detector Gives You The Mettle To Find Some Medals
Hurricane season is rapidly approaching those of us who live in the northern hemisphere. While that does come with a good deal of stress for any homeowners who live in the potential paths of storms it also comes with some opportunities for treasure hunting. Storms tend to wash up all kinds of things from the sea, and if you are equipped with this DIY metal detector you could be unearthing all kinds of interesting tchotchkes from the depths this year.
The metal detector comes to us from [mircemk] who is known for building simple yet effective metal detectors. Unlike his previous builds, this one uses only a single integrated circuit, the TL804 operational amplifier. It also works on the principle of beat-balance which is an amalgamation of two unique methods of detecting metal.  When the wire coils detect a piece of metal in the ground, the information is fed to an earpiece through an audio jack which rounds out this straightforward build.
[mircemk] reports that this metal detector can detect small objects like coins up to 15 cm deep, and larger metal objects up to 50 cm. Of course, to build this you will also need the support components, wire, and time to tune the circuit. All things considered, though it’s a great entryway into the hobby.
Want to learn more about metal detecting? Check out this similar-looking build which works on the induction balance principle.
Continue reading “DIY Metal Detector Gives You The Mettle To Find Some Medals” →
Treasure Hunting With A Handful Of Common Components
Sometimes simpler is better — when you don’t need the the computational power of an onboard microcontroller, it’s often best to rely on a simple circuit to get the job done. With cheap Raspberry Pis and ESP32s all over the place, it can be easy to forget that many simpler projects can be completed without a single line of code (and with the ongoing chip shortage, it may be more important now than ever to remember that).
[mircemk] had the right idea when he built his simple induction-balance metal detector. It uses a couple of 555 timers, transistors, and passives to sense the presence of metallic objects via a coil of wire. He was able to detect a coin up to 15 cm away, and larger objects at 60cm — not bad for a pile of components you probably have in your bench’s spare parts drawer right now! The detector selectivity can be tuned by a couple of potentiometers, and in true metal detector fashion, it has a buzzer to loudly blare at you once it’s found something (along with a LED, in case the buzzer gets too annoying).
All in all, this metal detector looks like a terribly fun project — one perfectly suited to beginners and more seasoned hackers alike. It serves as a great reminder that not every project needs WiFi or an OLED display to be useful, but don’t let that stop you from overdoing things! If touchscreens are more your speed, [mircemk] has got you covered with a smartphone-integrated version as well.
Continue reading “Treasure Hunting With A Handful Of Common Components” →
