Hackaday Links Column Banner
Hackaday Links: February 15, 2026
It probably won’t come as much of a surprise to find that most of the Hackaday staff aren’t exactly what you’d call sports fanatics, so we won’t judge if you didn’t tune in for the Super Bowl last week. But if you did, perhaps you noticed Ring’s Orwellian “Search Party” spot — the company was hoping to get customers excited about a new feature that allows them to upload a picture of their missing pet and have Ring cameras all over the neighborhood search for a visual match. Unfortunately for Ring, the response on social media wasn’t quite what they expected.
Nope, don’t like that.
One commenter on YouTube summed it up nicely: “This is like the commercial they show at the beginning of a dystopian sci-fi film to quickly show people how bad things have gotten.” You don’t have to be some privacy expert to see how this sort of mass surveillance is a slippery slope. Many were left wondering just who or what the new system would be searching for when it wasn’t busy sniffing out lost pups.
The folks at Wyze were quick to capitalize on the misstep, releasing their own parody ad a few days later that showed various three-letter agencies leaving rave reviews for the new feature. By Thursday, Ring announced they would be canceling a planned expansion that would have given the divisive Flock Safety access to their network of cameras. We’re sure it was just a coincidence.
Speaking of three-letter agencies, the Environmental Protection Agency has announced this week that they will no longer incentivize the inclusion of stop-start systems on new automobiles. The feature, which shuts off the engine when the vehicle comes to a stop, was never actually required by federal law; rather, the EPA previously awarded credits to automakers that added the feature, which would help them meet overall emission standards. Manufacturers are free to continue offering stop-start systems on their cars if they wish, but without the EPA credits, there’s little benefit in doing so. Especially since, as Car and Driver notes, it seems like most manufacturers are happy to be rid of it. The feature has long been controversial with drivers as well, to the point that we’ve seen DIY methods to shut it off.
Continue reading “Hackaday Links: February 15, 2026” →
Looking in the back of the Tektronix 577
Repairing A Tektronix 577 Curve Tracer
Over on his YouTube channel our hacker [Jerry Walker] repairs a Tektronix 577 curve tracer.
A curve tracer is a piece of equipment which plots I-V (current vs voltage) curves, among other things. This old bit of Tektronix kit is rocking a CRT, which dates it. According to TekWiki the Tektronix 577 was introduced in 1972.
In this repair video [Jerry] goes to use his Tektronix 577 only to discover that it is nonfunctional. He begins his investigation by popping off the back cover and checking out the voltages across the voltage rails. His investigations suggest a short circuit. He pushes on that which means he has to remove the side panel to follow a lead into the guts of the machine.
Continue reading “Repairing A Tektronix 577 Curve Tracer” →
Clever Engineering Leaves Appliance Useless
Around these parts, we generally celebrate clever hacks that let you do more with less. So if somebody wrote in to tell us how they used multiplexing to drive the front panel of their latest gadget with fewer pins on the microcontroller than would normally be required, we’d be all over it. But what if that same hack ended up leading to a common failure in a piece of consumer hardware?
As [Jim] recently found out, that’s precisely what seems to be ailing the Meaco Arete dehumidifier. When his stopped working, some Internet searching uncovered the cause of the failure: if a segment in the cheap LED display dies and shorts out, the multiplexing scheme used to interface with the front panel essentially reads that as a stuck button and causes the microcontroller to lock up. He passed the info along to us as a cautionary tale of how over-optimization can come with a hidden cost down the line.
Continue reading “Clever Engineering Leaves Appliance Useless” →
Schematic of a circuit
Hacking Flux Paths: The Surprising Magnetic Bypass
If you think shorting a transformer’s winding means big sparks and fried wires: think again. In this educational video, titled The Magnetic Bypass, [Sam Ben-Yaakov] flips this assumption. By cleverly tweaking a reluctance-based magnetic circuit, this hack channels flux in a way that breaks the usual rules. Using a simple free leg and a switched winding, the setup ensures that shorting the output doesn’t spike the current. For anyone who is obsessed with magnetic circuits or who just loves unexpected engineering quirks, this one is worth a closer look.
So, what’s going on under the hood? The trick lies in flux redistribution. In a typical transformer, shorting an auxiliary winding invites a surge of current. Here, most of the flux detours through a lower-reluctance path: the magnetic bypass. This reduces flux in the auxiliary leg, leaving voltage and current surprisingly low. [Sam]’s simulations in LTspice back it up: 10 V in yields a modest 6 mV out when shorted. It’s like telling flux where to go, but without complex electronics. It is a potential stepping stone for safer high-voltage applications, thanks to its inherent current-limiting nature.
The original video walks through the theory, circuit equivalences, and LTspice tests. Enjoy!
Continue reading “Hacking Flux Paths: The Surprising Magnetic Bypass” →
Locate Faults With The Leakseeker-89R
Have you ever needed to hunt down a short circuit, but you’ve had no idea where it is or how it’s happening? As it turns out, there are tools to help in that regard. Enter the Leakseeker-89R.
The device is able to help hunt down short circuits that measure anywhere from 0 to 300 ohms. The device is typically used with two leads on a given pair of traces, and it has a display made up of red, yellow and green LEDs. As the leads are moved closer or farther from the short circuit, the display changes to indicate if you’re getting hotter or colder. There’s also a third lead that can be used to allow testing under more challenging conditions when there is a large capacitance in-circuit with the traces you’re testing.
Fundamentally, it’s basically a very accurate resistance meter, finely honed for the purpose of hunting down short circuits. We’ve featured similar tools before. They can be of great use for troubleshooting. Meanwhile, if you’re building your own test tools in your home lab, don’t hesitate to let us know! We’re always dying for hot tips on the best DIY lab equipment for saving time, frustration, and money.
A schematic for a continuity tester that modulates its pitch based on the resistance measured
Op Amp Contest: Clever Continuity Tester Tells You Where The Problem Is
A continuity tester, as found on most multimeters today, is a great tool for finding broken connections and short circuits. But once you’ve found a short, it’s up to you to figure out which part of the circuit it’s in – a tedious job on a large PCB with hundreds of components. [John Guy] aims to ease this task with a continuity tester that modulates the beeper’s tone according to the resistance measured in the circuit. Tracking down a short circuit is then simply a matter of probing multiple points along a track and observing whether the pitch goes up or down.
The circuit is based on a single AD8534 quad op amp chip. The first stage measures the voltage across the circuit under test in response to small current and amplifies it. The resulting signal is fed into a voltage-controlled oscillator (VCO) made from one op amp connected as an integrator and another working as a comparator with hysteresis. Op amp number four amplifies the resulting square wave and drives a speaker. A low-pass filter makes the sound a bit more pleasing to the ears by removing the higher notes.
[John] paid particular attention to the PCB design to make it easy to assemble despite having a large number of SMD components on a small board. He even placed a parts list on the rear silkscreen, so anyone can assemble it even without the accompanying documents. The resulting board can be placed in a laser-cut acrylic case, turning it into a neat handheld instrument that will definitely find a place in any engineer’s toolbox. Measuring resistance through sound is not as accurate as using a full four-wire setup with an ohmmeter, but will be much faster and easier if you just want to find that annoying solder bridge hiding somewhere on your board.
Your Multimeter Might Be Lying To You
Multimeters are indispensable tools when working on electronics. It’s almost impossible to build any but the most basic of circuits without one to test and troubleshoot potential issues, and they make possible a large array of measurement capabilities that are not easily performed otherwise. But when things start getting a little more complex it’s important to know their limitations, specifically around what they will tell you about circuits designed for high frequency. [watersstanton] explains in this video while troubleshooting an antenna circuit for ham radio.
The issue that often confuses people new to radio or other high-frequency projects revolves around the continuity testing function found on most multimeters. While useful for testing wiring and making sure connections are solid, they typically only test using DC. When applying AC to the same circuits, inductors start to offer higher impedance and capacitors lower impedance, up to the point that they become open and short circuits respectively. The same happens to transformers, but can also most antennas which often look like short circuits to ground at DC but can offer just enough impedance at their designed frequency to efficiently resonate and send out radio waves.
This can give some confusing readings, such as when testing to make sure that a RF connector isn’t shorted out after soldering it to a coaxial cable for example. If an antenna is connected to the other side, it’s possible a meter will show a short at DC which might indicate a flaw in the soldering of the connector if the user isn’t mindful of this high-frequency impedance. We actually featured a unique antenna design recently that’s built entirely on a PCB that would show this DC short but behaves surprisingly well when sending out WiFi signals.
Continue reading “Your Multimeter Might Be Lying To You” →
