Ziehl-Neelsen Sputum Smear Microscopy (ZN) is one of most common methods for diagnosing Tuberculosis. On the equipment side, it requires not much more than an optical microscope, although it still needs a trained professional to look through the glass, identify and count the number of bacteria in a sample. To provide reliable and effective Tuberculosis diagnostic to regions, where both equipment and trained personnel is in short supply, [Rodrigo Loza] and [khalilnallar] are developing an automated digital microscope based on computer vision and machine learning, their entry for the Hackaday Prize.
They started out gathering images of Tuberculosis bacteria from the internet and experimented with color threshold algorithms to detect dyed bacteria, as well as algorithms for counting individual and clusters of bacteria. This process alone can, according to the team, take a trained professional 30 minutes or more. A graphical interface highlights identified bacteria and reads the bacteria count.
[Rodrigo Loza] and [khalilnallar] are testing their device at the Dr. Roberto Galindo Teran hospital in Cobija, Bolivia. However, getting access to a lab environment is one thing, and being given access to a steady supply of fresh M. Tuberculosis samples is another. Unable to obtain samples, which they need to test their algorithms on live subjects, they turned to another front of their project: The hardware. In several iterations, they developed a low-cost, 3D-printable kit, which transforms a laboratory-grade optical microscope into an embedded CNC-controlled microscopy platform. Their kit comprises three stepper-motor-based axis for the X, Y and Z direction, as well as a webcam mount. An Intel Edison and a custom, Arduino compatible shield control the system to achieve features such as homing procedures, autofocus and bacteria detection.
The team is currently in the process of refining their bacteria detection pipeline, exploring the feasibility of semi-automated detection methods, machine learning and neural networks for classification of bacteria within the hardware constraints. The video below shows their latest update on the Z-axis of their microscope.
GOMX-3 is a CubeSat with several payloads. One of them is a software defined radio configured to read ADS-B signals sent by commercial aircraft. The idea is that a satellite can monitor aircraft over oceans and other places where there no RADAR coverage. ADB-S transmits the aircraft’s ID, its position, altitude, and intent.
The problem is that ADS-B has a short-range (about 80 nautical miles). GOMX-1 proved that the signals can be captured from orbit. GOMX-3 has more capability. The satellite has a helical antenna and an FPGA.
When you work at Tektronix and they make a difficult to refuse offer for their ‘scopes, you obviously grab it. Even if the only one you can afford is the not-so-awesome TDS1012. [Jason Milldrum] got his unit before cheaper, and better ‘scopes appeared on the market. It served him well for quite a long time. But keeping it switched on all the time took a toll, and eventually the CCFL backlight failed. Here’s how he replaced the CCFL back light with a strip of LED’s and revived the instrument.
Searching for an original replacement CCFL backlight didn’t turn up anything – it had been obsoleted long back. Even his back-channel contacts in Tektronix couldn’t help him nor could he find anything on eBay. That’s when he came across a video by [Shahriar] who hosts the popular The Signal Path blog. It showed how the CCFL can be replaced by a thin strip of SMD LEDs powered by a DC-DC converter. [Jason] ordered out the parts needed, and having worked at Tektronix, knew exactly how to tear down the ‘scope. Maybe he was a bit rusty, as he ended up breaking some (non-critical) plastic tabs while removing the old CCFL. Nothing which could not be fixed with some silicone sealant.
The original DC-DC converter supplied along with his LED strip needed a 12V input, which was not available on the TDS1012. Instead of trying to hack that converter to work off 6V, he opted to order out another suitable converter instead. [Jason]’s blog details all the steps needed, peppered with lots of pictures, on how to make the swap. The one important caveat to be aware of is the effect of the LED DC-DC converter on the oscilloscope. Noise from the converter is likely to cause some performance issues, but that could be fixed by using a more expensive module with RF and EMI filtering.
This is not an original hack for sure. Here’s a “Laptop backlight converted from CCFL to LED” from a few years back, and this one for “LCD: Replacing CCFL with LEDs” from even further back in time. Hopefully if you have an instrument with a similar issue, these ought to guide you on how to fix things.
I could have sworn that we have asked this one before, but perhaps I’m thinking of our discussion of nuclear aircraft. In my mind the two share a similar fate: it just isn’t going to happen. But, that doesn’t mean flying cars can’t happen. Let me make my case, and then we want to know what you think.
[Steve] sent in a link to a Bloomberg article on Larry Page’s suspected investment in personal flying cars. It’s exciting to hear about test flights from a startup called Zee.Aero with 150 people on staff and a seemingly unlimited budget to develop such a fantastic toy. Surely Bruce Wayne Mr. Page is onto something and tiny 2-person vehicles will be whizzing up and down the airspace above your street at any moment now? Realistically though, I don’t believe it. They definitely will build a small fleet of such vehicles and they will work. But you, my friend, will never own one. Continue reading “Ask Hackaday: Where Are The Flying Cars?”→
Makerbot is in the gutter, 3D Systems and Stratasys stock is only a shadow of their 2014 glory, but this is the best year 3D printing has ever had. Machines are now good and cheap, there’s a variety of various thermoplastic filaments, and printing useful objects – instead of just plastic trinkets – is becoming commonplace.
The standard rectilinear infill from Slic3r
There’s one area of 3D printing that hasn’t seen as much progress, and it’s the software stack. Slicing, the process of turning a 3D object into a Gcode file for a printer has been basically the same for the last few years. Dual extrusion is still a mess, and automated bed leveling is still in its infancy.
One aspect of slicing that has been severely overlooked is infill. Obviously, you don’t want to print plastic trinkets completely solid – only the outside surface matters, and a part with 100% infill is just a waste of plastic. Different slicers have come up with different ways of filling the inside of a print, usually with a grid of squares, triangles, or hexagons.
While the most popular methods of filling in a 3D printed objects do the job of adding a little bit of strength to a print and supporting the top layers of a print, it’s not an ideal solution. The desired strength of the finished part is never taken into account, print artifacts are sometimes visible through the side of a print, and the spacing of the infill grid is completely arbitrary. You can only set a percentage of infill, and telling a slicer to make an internal support grid with 10mm spacing is impossible.
Type A Machines just changed all of this. With the release of their public beta of Cura Type A, the infill for a 3D printed part is also 3D. The dimensions of the infill are predictable, opening the door to stronger and better looking parts.
From the Type A press literature and white paper, this new type of ‘infill’ isn’t; it’s more properly referred to as ‘internal structure’, with proper dimensions between infill features. Instead of a grid of squares or triangles stacked one layer on top of each other, it’s a true structure, with the infill following the perimeter of the 3D printed object.
Generating 3D Infill
Infill generated from Type A Machine’s Cura beta. Note the 3D structure of the infill.
Right now, infill is generated in a slicer by specifying a percentage. Zero percent infill means a hollow object, and 100% infill is a completely solid part. These two edge cases are easy, but anything else means the slicer must fill the part with filament in a grid of tessellating shapes, either rectangles, triangles, or hexagons. With current slicers, the dimensions of this internal structure are, for all practical purposes, random. Printing an object with 20% infill might mean a grid of squares with 5mm or 2mm spacing. Telling the slicer to infill a part with a grid of squares spaced 10mm apart is impossible.
Type A Machine’s latest Cura release changes all of this, allowing a designer to set a precise distance between rows and columns of infill. By defining infill in absolute dimensions, this allows for stronger parts using less infill.
Absolute dimensioning is only one feature of the Type A Machine’s latest release of Cura. Even more exciting is the development of 3D internal structure. Instead of stacking layers of squares, triangles, or hexagons on top of each other, Type A Machine’s Cura uses an infill of cubes turned on their side. While each individual layer of infill looks like a series of triangles and irregular hexagons, when assembled into a printed 3D object, this infill forms a true 3D structure.
The closest comparison to this sort of structure is the difference between graphite and diamond. Both of these materials are made out of the same element, carbon. The physical structure of graphite is just, 1-atom-thick layers of graphene, producing a relatively weak material. Diamond, on the other hand, has a true 3D structure and is one of the hardest materials known to man. While adding 3D structure to the infill of 3D printed objects won’t make the objects any stronger, it will drastically reduce delamination, and be much more resistant to stresses in all three dimensions.
While Type A Machines has done some great work here, it does mean there’s yet another version of Cura to deal with. Type A Machine’s Cura, in addition to the LulzBot edition and the original are now the defacto standard for turning 3D objects into printed parts. Having an open source solution is great, but forking the development this much surely can’t be ideal.
Intel made an appearance at the recent summer X Games in Austin, TX with the Curie, a gadget for sensing the motion and position of skateboarders and BMXers. The Curie, attached to the bikes or helmets, measured the dynamics of the tricks performed by the participants.
An Intel 32 bit Quark SE system on a chip sent the telemetry data in real-time using Bluetooth. The module contains an accelerometer and gyroscope to capture all the twists, turns, and tumbles of the athletes. An analysis of the data was presented as part of the on-screen graphic displays of the events.
One of the biggest challenges for a company that holds invaluable data is protecting it. At first, this task would seem fairly straightforward. Keep the data on an encrypted server that’s only accessible via the internal network. The physical security of the server can be done with locks and other various degrees of physical security. One has to be thoughtful in how the security is structured, however. You need to allow authorized humans access to the data in order for the company to function, and there’s the rub. The skilled hacker is keenly aware of these people, and will use techniques under the envelope of Social Engineering along with her technical skills to gain access to your data.
Want to know how secure your house is? Lock yourself out. One of the best ways to test security is to try and break in. Large companies routinely hire hackers, known as penetration testers, to do just this. In this article, we’re going to dissect how a hired penetration tester was able to access data so valuable that it could have destroyed the company it belonged to.
The start of any hack involves information gathering. This is usually pretty easy for larger companies. Their website along with a few phone calls can reveal quite a bit of useful information. However, you can be assured that any company who has hired a pen tester has taken the necessary precautions to limit such information.
And such was the case for our hacker trying to gain access to the ACME Corp. servers. Her first target was the dumpsters – dumpster dives have been proven to unearth a trove of valuable information in the past. But the dumpsters were inside the complex, which was guarded by a contracted security firm. Through a bit of website snooping and a few phone calls, she was able to find out the department that was in charge of trash removal for the company. She then placed a phone call to this department. Using a social engineering (SE) technique known as pretexting, she pretended to be with a trash removal company and wanted to submit a quote to service their business. Using another SE technique called elicitation, she was able to find out:
that trash collection took place on Wednesdays and Thursdays
the total number of dumpsters
that there was a special dumpster for paper and technology trash
the name of the current waste removal company – Waster’s Management
the name of the employee in charge of the waste removal – [Christie Smith]
Dumpster Dive
Armed with this information, she went to the Waster’s Management website and grabbed their JPEG logo. Within a few days, she had a shirt and hat with the logo in her hands. She called the security department and said she was with Waster’s Management, and that [Christie Smith] had told her one of the dumpsters was damaged, and she needed to take a look at it before the next trash removal.
The next day, wearing the shirt and hat she had ordered online, she was given a badge from security and allowed access to the dumpsters. Now, any hacker worth her weight in PIC16F84’s already knows what dumpster she dove into. It didn’t take her long to walk away with several hard drives, a few USB drives and some useful documents. She was able to gain knowledge of an upcoming IT contract work, the name of the CFO, and the name of a server with some level of importance – prod23.
Hacking the Server
With some more SE, she was able to find out when the IT work was scheduled. It was after hours. She showed up a bit late and was able to walk right through the front door by claiming she worked for the IT contract company. She then shifted roles and pretended to be an employee. She approached one the real IT contract guys, and said she worked for the CFO, [Mr. Shiraz], and asked if he knew to be careful with the prod23 server. With more SE, she was able to find out the prod23 server was off-limits, encrypted, and only accessible by specific admins.
She was able to access an admin office, and it was there she would don her black hat. She booted the computer with BackTrack via USB and installed a key logger. She made an SSH tunnel to her personal server where she could dump the contents of the key logger, along with some other shells. Now, this is where things get interesting. She opened Virtual Box and used the computer’s hard drive as the boot medium. The VM booted the OS, and she hid all of the screen decorations to make it look like the target OS was running. The admin would log in without a clue, and our hacker would get their username and password through the key logger.
Once the login information came in, she was able to access the admin’s computer, and from there the prod23 server. You can imagine the look on the faces of the top executives for ACME Corp when our hacker handed them a copy of the keys to their kingdom.
Social engineering is human hacking, and a dark art in itself. Our hacker in this story would have never been able to even get close to the server if she did not have SE skills. No matter how secure you make something, so long as you allow humans access to it, it’s vulnerable to attack. And then it’s down to how well-trained your people are in repelling these kinds of intrusions.Just ask Target.
You can find the full story in the source below.
Sources
Social Engineering, The Art of Human Hacking, Chapter 8, by Christopher Hadnagy, ISBN-13: 860-1300286532
