The Guinness Brewery Invented One Of Science’s Most Important Statistical Tools
The Guinness brewery has a long history of innovation, but did you know that it was the birthplace of the t-test? A t-test is usually what underpins a declaration of results being “statistically significant”. Scientific American has a fascinating article all about how the Guinness brewery (and one experimental brewer in particular) brought it into being, with ramifications far beyond that of brewing better beer.
William Sealy Gosset (aka ‘Student’), self-trained statistician. [source: user Wujaszek, wikipedia]
Head brewer William Sealy Gosset developed the technique in the early 1900s as a way to more effectively monitor and control the quality of stout beer. At Guinness, Gosset and other brilliant researchers measured everything they could in their quest to optimize and refine large-scale brewing, but there was a repeated problem. Time and again, existing techniques of analysis were simply not applicable to their gathered data, because sample sizes were too small to work with.
While the concept of statistical significance was not new at the time, Gosset’s significant contribution was finding a way to effectively and economically interpret data in the face of small sample sizes. That contribution was the t-test; a practical and logical approach to dealing with uncertainty.
As mentioned, t-testing had ramifications and applications far beyond that of brewing beer. The basic question of whether to consider one population of results significantly different from another population of results is one that underlies nearly all purposeful scientific inquiry. (If you’re unclear on how exactly the t-test is applied and how it is meaningful, the article in the first link walks through some excellent and practical examples.)
Dublin’s Guinness brewery has a rich heritage of innovation so maybe spare them a thought the next time you indulge in statistical inquiry, or in a modern “nitro brew” style beverage. But if you prefer to keep things ultra-classic, there’s always beer from 1574, Dublin castle-style.
PCB Design Review: Switching Regulator Edition
This article was prompted by a friend of mine asking for help on a board with an ESP32 heart. The board outputs 2.1 V instead of 3.3 V, and it doesn’t seem like incorrectly calculated feedback resistors are to blame – let’s take a look at the layout. Then, let’s also take a look at a recently sent in design review entry, based on an IC that looks perfect for all your portable Raspberry Pi needs!
What Could Have Gone Wrong?
Here’s the board in all its two-layer glory. This is the kind of board you can use to drive 5 V or 12 V Neopixel strips with a firmware like WLED – exactly the kind of gadget you’ll want to use for LED strip experiments! 3.3 V power is provided by a Texas Instruments TPS54308 IC, and it’s the one misfiring, so let’s take a look.
Continue reading “PCB Design Review: Switching Regulator Edition”
TDK Claims Solid State Battery With 100X Energy Density
Regulations surrounding disposable batteries have accelerated a quiet race to replace coin cells, which on the whole are not readily rechargeable. TDK produces solid-state batteries and has announced a new material that claims an energy density of about 100 times that of their conventional batteries.
Energy density measures how much energy a system contains relative to its volume. The new battery has 1000 Wh/L. For comparison, old nickel-cadmium cells had about 150 Wh/L. A typical lithium-ion battery usually turns in about 200 – 250 Wh/L.
There aren’t many technical details, but a few things caught our interest. For one, it uses an oxide-based solid electrolyte and lithium alloy anodes. However, what really caught our eye was that it is “intended for use in wearables… that come in direct contact with the human body.” We don’t know if that means the material is safe for your skin or if it depends on being next to your body to operate.
While the energy density is high, keep in mind that the batteries of this type are usually tiny, so the total actual power available is probably not very high. Tiny batteries are definitely a thing. We are always hearing about breakthroughs, but we always wonder if and when we’ll see actual products.
McDonald’s Terminates Its Drive-Through Ordering AI Assistant
McDonald’s recently announced that it will be scrapping the voice-assistant which it has installed at over 100 of its drive-throughs after a two-year trial run. In the email that was sent to franchises, McDonald’s did say that they are still looking at voice ordering solutions for automated order taking (AOT), but it appears that for now the test was a disappointment. Judging by the many viral videos of customers struggling to place an order through the AOT system, it’s not hard to see why.
This AOT attempt began when in 2019 McDonald’s acquired AI company Apprente to create its McD Tech Labs, only to sell it again to IBM who then got contracted to create the technology for McDonald’s fast-food joints. When launched in 2021, it was expected that McDonald’s drive-through ordering lanes would eventually all be serviced by AOT, with an experience akin to the Alexa and Siri voice assistants that everyone knows and loves (to yell at).
With the demise of this test at McDonald’s, it would seem that the biggest change is likely to be in the wider automation of preparing fast-food instead, with robots doing the burger flipping and freedom frying rather than a human. That said, would you prefer the McD voice assistant when going through a Drive-Thru® over a human voice?
A Brief Look Inside A Homebrew Digital Sampler From 1979
While we generally prefer to bring our readers as much information about a project as possible, sometimes we just have to go with what we see. That generally happens with new projects and work in progress, but it can also happen with old projects. Sometimes very old indeed, as is the case with this digital sampling unit for analog oscilloscopes, circa 1979.
We’ve got precious little to go on with this one other than the bit of eye candy in the video tour below and its description. Luckily, we’ve had a few private conversations with its maker, [Mitsuru Yamada], over the years, enough to piece together a little of the back story here — with apologies for any wrong assumptions, of course.
Built when he was only 19, this sampler was an attempt to build something that couldn’t be bought, at least not for a reasonable price. With no inexpensive monolithic analog-to-digital converters on the market, he decided to roll his own. A few years back he recreated the core of that with his all-discrete successive approximation ADC.
The sampler shown below has an 8-bit SAR ADC using discrete CMOS logic and enough NMOS memory to store 256 samples. You can see the ADC and memory cards in the homebrew card cage made from aluminum angle stock. The front panel has a ton of controls and sports a wide-range attenuator, DC offset, and trigger circuit with both manual and automatic settings.
It’s an impressive build, especially for a 19-year-old with presumably limited resources. We’ve reached out to [Yamada-san] in the hope that he’ll be able to provide more details on what’s under the hood and if this still works after all these years. We’ll pass along whatever we get, but in the meantime, enjoy.
Continue reading “A Brief Look Inside A Homebrew Digital Sampler From 1979”
Credit: Xinmei Liu
The US Surgeon General’s Case For A Warning Label On Social Media
The term ‘Social Media’ may give off a benign vibe, suggesting that it’s a friendly place where everyone is welcome to be themselves, yet reality has borne out that it is anything but. This is the reason why the US Surgeon General [Dr. Vivek H. Murthy] is pleading for a health warning label on social media platforms. Much like with warnings on tobacco products, it’s not expected that such a measure would make social media safe for children and adolescents, but would remind them and their parents about the risks of these platforms.
While this may sound dire for what is at its core about social interactions, there is a growing body of evidence to support the notion that social media can negatively impact mental health. A 2020 systematic review article in Cureus by [Fazida Karim] and colleagues found anxiety and depression to be the most notable negative psychological health outcomes. A 2023 editorial in BMC Psychology by [Ágnes Zsila] and [Marc Eric S. Reyes] concurs with this notion, while contrasting these cons of social media with the pros, such as giving individuals an online community where they feel that they belong.
Ultimately, it’s important to realize that social media isn’t the end-all, be-all of online social interactions. There are still many dedicated forums, IRC channels and newsgroups far away from the prying eyes and social pressure  of social media to act out a personality. Having more awareness of how social interactions affect oneself and/or one’s children is definitely essential, even if we’re unlikely to return to the ‘never give out your real name’ days of  the pre-2000s Internet.
A rectangular box with a purple section sandwiched between two red sections sits on a black tabletop. The end of the box is open. Black and red wires run out of the back of the box to a breadboard.
Improving Wind Turbine Testing With A Better Air Source
When comparing the efficiency of different wind turbine blade designs, [AdamEnt] found using a hair dryer wasn’t the best tool for the job. Enter his new 3D-printed wind tunnel.
After several prototypes, [AdamEnt] decided on a design that exploits slicer infill to create a flow straightener without having to do any tedious modeling of a lattice. Combined with a box on both ends of the straightener to constrain the flow, he has a more controllable air source with laminar instead of turbulent flow for testing his wind turbines.
The BLDC motor driving the air is attached to a toroidal blade of MIT fame. We get a little bit of the math behind calculating wind turbine efficiency and see a quick test of a blade placed next to the outlet of the air source at the end of the video.
If you’re planning on building your own wind tunnel, we’ve covered a few. We’ve even seen one that goes up to Mach 20, although that probably wouldn’t be useful for wind turbine design!
Continue reading “Improving Wind Turbine Testing With A Better Air Source”
