Back To The 90s On Real Hardware
As the march of time continues on, it becomes harder and harder to play older video games on hardware. Part of this is because the original hardware itself wears out, but another major factor is that modern operating systems, software, and even modern hardware don’t maintain support for older technology indefinitely. This is why emulation is so popular, but purists that need original hardware often have to go to extremes to scratch their retro gaming itch. This project from [Eivind], for example, is a completely new x86 PC designed for the DOS and early Windows 98 era.
The main problem with running older games on modern hardware is the lack of an ISA bus, which is where the sound cards on PCs from this era were placed. This build uses a Vortex86EX system-on-module, which has a processor running a 32-bit x86 instruction set. Not only does this mean that software built for DOS can run natively on this chip, but it also has this elusive ISA capability. The motherboard uses a Crystal CS4237B chip connected to this bus which perfectly replicates a SoundBlaster card from this era. There are also expansion ports to add other sound cards, including ones with Yamaha OPL chips.
Not only does this build provide a native hardware environment for DOS-era gaming, but it also adds a lot of ports missing from modern machines as well including a serial port. Not everything needs to be original hardware, though; a virtual floppy drive and microSD card reader make it easy to interface minimally with modern computers and transfer files easily. This isn’t the only way to game on new, native hardware, though. Others have done similar things with new computers built for legacy industrial applications as well.
Thanks to [Stephen] for the tip!
Continue reading “Back To The 90s On Real Hardware”
Video Clips With Emacs
Sometimes it seems like there’s nothing Emacs can’t do. Which, of course, is why some people love it, and some people hate it. Apparently, [mbork] loves it and devised a scheme to show a video (with a little help), accept cut-in and out marks, and then use ffmpeg to output the video clip, ready for posting, emailing, or whatever.
This was made easier by work already done to allow Emacs to create subtitles (subed). Of course, Emacs by itself can’t play videos, but it can take control of mpv, which can. Interestingly, subed doesn’t insist on mpv since it won’t work on Windows, but without it, your editing experience won’t be as pleasant.
Continue reading “Video Clips With Emacs”
How’s The Weather? (Satellite Edition)
When [Tom Nardi] reported on NOAA’s statement that many of its polar birds were no longer recommended for use, he mentioned that when the satellites do give up, there are other options if you want to pull up your own satellite weather imagery. [Jacopo] explains those other options in great detail.
For example, the Russian Meteor-M satellites are available with almost the same hardware and software stack, although [Jacopo] mentions you might need an extra filter since it is a little less tolerant of interference than the NOAA bird. On the plus side, Meteor-M is stronger than the NOAA satellite on 1.7 GHz, and you can even use a handheld antenna to pick it up. There are new, improved satellites of this series on their way, too.
Continue reading “How’s The Weather? (Satellite Edition)”
Digital prototype of Zeusfilter 1.0
How To Stop Zeus From Toasting Your Pi
If you’ve ever lost gear to lightning or power spikes, you know what a pain they are. Out in rural Arkansas, where [vinthewrench] lives, the grid is more chaos than comfort – especially when storms hit. So, he dug into the problem after watching a cheap AC-DC module quite literally melt down. The full story, as always, begins with the power company’s helpful reclosers: lightning-induced surges, and grid switching transients. The result though: toasted boards, shorted transformers, and one very dead Raspberry Pi. [vinthewrench] wrote it all up – with decent warnings ahead. Take heed and don’t venture into things that could put your life in danger.
Back to the story. Standard surge suppressors? Forget it. Metal-oxide varistor (MOV)-based strips are fine for office laptops, but rural storms laugh at their 600 J limits. While effective and commonly used, MOVs are “self-sacrificing” and degrade over time with each surge event.
[vinthewrench] wanted something sturdier. Enter ZeusFilter 1.0 – a line-voltage filter stitched together from real parts: a slow-blow fuse, inrush-limiting thermistor, three-electrode gas discharge tube for lightning-class hits, beefy MOVs for mid-sized spikes, common-mode choke to kill EMI chatter, and safety caps to bleed off what’s left. Grounding done right, of course. The whole thing lives on a single-layer PCB, destined to sit upstream of a hardened PSU.
As one of his readers pointed out, though, spikes don’t always stop at the input. Sudden cut-offs on the primary can still throw nasty pulses into the secondary, especially with bargain-bin transformers and ‘mystery’ regulators. The reader reminded that counterfeit 7805s are infamous for failing short, dumping raw input into a supposedly safe 5 V rail. [vinthewrench] acknowledged this too, recalling how collapsing fields don’t just vanish politely – Lenz makes sure they kick back hard. And yes, when cheap silicon fails, it fails ugly: straight smoke-release mode.
In conclusion, we’re not particularly asking you to try this at home if you lack the proper knowledge. But if you have a high-voltage addiction, this home research is a good start to expand your knowledge of what is, in theory, possible.
Web Dashboard For Zephyr
Over time, web browsers have accumulated a ton of features beyond what anyone from the 90s might have imagined, from an application platform to file management and even to hardware access. While this could be concerning from a certain point of view, it makes it much easier to develop a wide range of tools. All a device really needs to use a browser as a platform is an IP address, and this project brings a web UI dashboard to Zephyr to simplify application development.
Zephyr is a real-time operating system (RTOS) meant for embedded microcontrollers, so having an easy way to access these systems through a web browser can be extremely useful. At its core, this project provides a web server that can run on this operating system as well as a REST API that can be used by clients to communicate with it. For things like blinking lights this is sufficient, but for other things like sensors that update continuously the dashboard can also use WebSocket to update the web page in real time.
The web dashboards that can be built with this tool greatly reduce the effort and complexity needed to interact with Zephyr and the microcontrollers it typically runs on, especially when compared to a serial console or a custom application that might otherwise be built for these systems. If this is your first time hearing about this RTOS we recently featured a microcontroller-based e-reader which uses this OS as a platform.
Continue reading “Web Dashboard For Zephyr”
Finding A New Model For Hacker Camps
A nicht scene in a post-apocalyptic future, in this case an electronics bazaar adjacent to the rave area in EMF 2018 Null Sector.
Electromagnetic Field manage to get live music at a hacker camp right, by turning it into the most cyberpunk future possible.
A couple of decades ago now, several things happened which gave life to our world and made it what it has become. Hackerspaces proliferated, giving what was previously dispersed a physical focus. Alongside that a range of hardware gave new expression to our projects; among them the Arduino, affordable 3D printing, and mail-order printed circuit boards.
The result was a flowering of creativity and of a community we’d never had before.Visiting another city could come with a while spent in their hackerspace, and from that new-found community blossomed a fresh wave of events. The older hacker camps expanded and morphed in character to become more exciting showcases for our expression, and new events sprang up alongside them. The 2010s provided me and my friends with some of the most formative experiences of our lives, and we’re guessing that among those of you reading this piece will be plenty who also found their people.
And then came COVID. Something that sticks in my mind when thinking about the COVID pandemic is a British news pundit from March 2020 saying that nothing would be quite the same as before once the pandemic was over. In our community this came home to me after 2022, when the first large European hacker camps made a return. They were awesome in their own way, but somehow sterile, it was as though something was missing. Since then we’ve had a few more summers spent trailing across the continent to hang out and drink Club-Mate in the sun, and while we commend the respective orgas for creating some great experiences, finding that spark can still be elusive. Hanging out with some of my friends round a European hackerspace barbecue before we headed home recently, we tried to put our finger on exactly where the problem lay.
Continue reading “Finding A New Model For Hacker Camps”
Hackaday Podcast Episode 334: Radioactive Shrimp Clocks, Funky Filaments, Owning The Hardware
In this episode of the Hackaday Podcast, editors Elliot Williams and Tom Nardi start out with a warning about potentially radioactive shrimp entering the American food supply via Walmart, and things only get weirder from there. The extra spicy shrimp discussion makes a perfect segue into an overview of a pair of atomic One Hertz Challenge entries, after which they’ll go over the latest generation of 3D printer filament, using an old Android smartphone as a low-power Linux server, some tips for creating better schematics, and Lorde’s specification-bending transparent CD. Finally, you’ll hear about how the nature of digital ownership influences the hardware we use, and on the other side of the coin, how open source firmware like QMK lets you build input devices on your terms.
Check out the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Or download in DRM-free MP3 to enjoy with your shrimp.
Continue reading “Hackaday Podcast Episode 334: Radioactive Shrimp Clocks, Funky Filaments, Owning The Hardware”
