A photo of the air-wired circuit, with one LED on and the other off.
The Magic Of The Hall Effect Sensor
Recently, [Solder Hub] put together a brief video that demonstrates the basics of a Hall Effect sensor — in this case, one salvaged from an old CPU fan. Two LEDs, a 100 ohm resistor, and a 3.7 volt battery are soldered onto a four pin Hall effect sensor which can toggle one of two lights in response to the polarity of a nearby magnet.
If you’re interested in the physics, the once sentence version goes something like this: the Hall Effect is the production of a potential difference, across an electrical conductor, that is transverse to an electric current in the conductor and to an applied magnetic field perpendicular to the current. Get your head around that!
Of course we’ve covered the Hall effect here on Hackaday before, indeed, our search returned more than 1,000 results! You can stick your toe in with posts such as A Simple 6DOF Hall Effect ‘Space’ Mouse and Tracing In 2D And 3D With Hall Effect Sensors.
Continue reading “The Magic Of The Hall Effect Sensor” →
Was Action! The Best 8-Bit Language?
Most people’s memories of programming in the 8-bit era revolve around BASIC, and not without reason. Most of the time, it was all we had. On the other hand, there were other options if you sought them out, and [Paul Lefebvre] makes the case that Goto10Retro that Action! was the best of them.
The limits of BASIC as an interpreted language are well-enough known that we needn’t go over them here. C and Pascal were available for some home computers in the 1980s, and programs written in those languages ran well, but compiling them? That was by no means guaranteed.
The text editor. Unusual for Atari at the time, it allowed scrolling along a line of greater than 40 char.
For those who lived on the Atari side of the fence, the Action! language provided a powerful alternative. Released by Optimized Systems Software in 1983, Action! was heavily optimized for the 6502, to the point that compiling and running simple programs with “C” and “R” felt “hardly slower” than typing RUN in BASIC. That’s what [Paul] writes, anyway, but it’s a claim that almost has to be seen to be believed.
You didn’t just get a compiler for your money when you bought Action!, though. The cartridge came with a capable text editor, simple shell, and even a primitive debugger. (Plus, of course, a hefty manual.) It’s the closest thing you’d find to an IDE on a computer of that class in that era, and it all fit on a 16 kB cartridge. There was apparently also a disk release, since the disk image is available online.
Unfortunately for those of us in Camp Commodore, the planned C-64 port never materialized, so we missed out on this language.  Luckily our 64-bit supercomputers can easily emulate Atari 8-bit hardware and we can see what all the fuss was about. Heck, even our microcontrollers can do it.
Bambu Lab’s PLA Tough+ Filament: Mostly A Tough Sell
Beyond the simple world of basic PLA filaments there is a whole wild world of additives that can change this humble material for better or worse. The most common additives here are primarily to add color, but other additives seek to specifically improve certain properties of PLA. For example Bambu Lab’s new PLA Tough+ filament series that [Dr. Igor Gaspar] over at the My Tech Fun YouTube channel had over for reviewing purposes.
According to Bambu Lab’s claims for the filament, it’s supposed to have ‘up to’ double the layer adhesion strength as their basic PLA, while being much more robust when it comes to flexing and ‘taking a beating’. Yet as [Igor] goes through his battery of tests – comparing PLA Tough+ against the basic PLA – the supposedly tough filament is significantly worse in every count. That sad streak lasts until the impact tests, which is where we see a curious set of results – as shown above – as well as [Igor]’s new set of impact testing toys being put through their paces.
Of note is that although the Tough+ variants tested are consistently less brittle than their basic PLA counterparts, the Silver basic PLA variant makes an unexpectedly impressive showing. This is a good example of how color additives can have very positive impacts on a basic polymer like PLA, as well as a good indication that at least Bambu Lab’s Basic PLA in its Silver variant is basically better than Tough+ filaments. Not only does it not require higher printing temperatures, it also doesn’t produce more smelly VOCs, while being overall more robust.
Continue reading “Bambu Lab’s PLA Tough+ Filament: Mostly A Tough Sell” →
O Brother, What Art Thou?
Dedicated word processors are not something we see much of anymore. They were in a weird space: computerized, but not really what you could call a computer, even in those days. More like a fancy typewriter, with a screen and floppy disks. Brother made some very nice ones, and [Chad Boughton] got his hands on one for a modernization project.
The word processor in question, a Brother WP-2200, was chosen primarily because of its beautiful widescreen, yellow-phosphor CRT display. Yes, you read that correctly — yellow phosphor, not amber. Widescreen CRTs are rare enough, but that’s just different. As built, the WP-2200 had a luggable form-factor, with a floppy drive, ̶m̶e̶c̶h̶a̶n̶i̶c̶a̶l̶ clacky keyboard, and dot-matrix printer in the back. Continue reading “O Brother, What Art Thou?” →
Business Card Ouija board
This Ouija Business Card Helps You Speak To Tiny Llamas
Business cards, on the whole, haven’t changed significantly over the past 600-ish years, and arguably are not as important as they used to be, but they are still worth considering as a reminder for someone to contact you. If the format of that card and method of contact stand out as unique and related to your personal or professional interests, you have a winning combination that will cement yourself in the recipient’s memory.
In a case study of “show, don’t tell”, [Binh]’s business card draws on technological and paranormal curiosity, blending affordable, short-run PCB manufacturing and an, LLM or, in this case, a Small Language Model, with a tiny Ouija board. While [Binh] is very much with us in the here and now, and a séance isn’t really an effective way to get a hold of him, the interactive Ouija card gives recipient’s a playful demonstration of his skills.
Continue reading “This Ouija Business Card Helps You Speak To Tiny Llamas” →
The Android Linux Commander
Last time, I described how to write a simple Android app and get it talking to your code on Linux. So, of course, we need an example. Since I’ve been on something of a macropad kick lately, I decided to write a toolkit for building your own macropad using App Inventor and any sort of Linux tools you like.
I mentioned there is a server. I wrote some very basic code to exchange data with the Android device on the Linux side. The protocol is simple:
  • All messages to the ordinary Linux start with >
  • All messages to the Android device start with <
  • All messages end with a carriage return
Security
You can build the server so that it can execute arbitrary commands. Since some people will doubtlessly be upset about that, the server can also have a restrictive set of numbered commands. You can also allow those commands to take arguments or disallow them, but you have to rebuild the server with your options set.
There is a handshake at the start of communications where Android sends “>.” and the server responds “<.” to allow synchronization and any resetting to occur. Sending “>#x” runs a numbered command (where x is an integer) which could have arguments like “>#20~/todo.txt” for example, or, with no arguments, “>#20” if you just want to run the command.
If the server allows it, you can also just send an entire command line using “>>” as in: “>>vi ~/todo.txt” to start a vi session.
Continue reading “The Android Linux Commander” →
Give Your Twist Connections Some Strength
We’ve all done it at some time — made an electrical connection by twisting together the bare ends of some wires. It’s quick, and easy, but because of how little force required to part it, not terribly reliable. This is why electrical connectors from terminal blocks to crimp connectors and everything else in between exist, to make a more robust join.
But what if there was a way to make your twist connections stronger? [Ibanis Sorenzo] may have the answer, in the form of an ingenious 3D printed clamp system to hold everything in place. It’s claimed to result in a join stronger than the wire itself.
The operation is simple enough, a spring clamp encloses the join, and a threaded outer piece screws over it to clamp it all together. There’s a pair of 3D printable tools to aid assembly, and a range of different sizes to fit different wires. It looks well-thought-out and practical, so perhaps it could be a useful tool in your armoury. We can see in particular that for those moments when you don’t have the right connectors to hand, a quick 3D print could save the say.
A few years ago we evaluated a set of different ways to make crimp connections. It would be interesting to subject this connection to a similar test. Meanwhile you can see a comprehensive description in the video below the break.
Continue reading “Give Your Twist Connections Some Strength” →
