WSL9x: Add A Linux Subsystem To Your Windows 9x
Considering that Windows NT has the concept of so-called ‘subsystems’ whereby you can run different systems side-by-side, starting with the POSIX subsystem and later the Windows Subsystem for Linux (WSL), it was probably only a matter of time before someone figured that doing this with Windows 9x was also completely reasonable. Ergo we now got [Hailey Somerville]’s Linux Subsystem for Windows.
To make running Linux inside Windows 9x work, it was necessary to heavily patch a Linux kernel, as normally there are no provisions for such a subsystems in Windows 9x’s kernel unlike the NT kernel. Correspondingly, the Linux kernel is based on user-mode Linux and hacked to call Windows 9x kernel APIs instead of the POSIX ones.
In order to use WSL9x you thus need to build said modified Linux kernel – currently at version 6.19 – along with a disk image containing an installed copy of Windows 9x. From there WSL9x can be loaded with the wsl command and you’re then free to cooperatively run the Win9x and Linux kernel side-by-side. This is reminiscent of Cooperative Linux (coLinux), which did something similar except with Windows NT and Linux kernels running side-by-side, and of course we have WSL2 with Windows 10+.
Thanks to [adistuder] for the tip.
Encrypting Encrypted Traffic To Get Around VPN Bans
VPNs, Virtual Private Networks, aren’t just a good idea to keep your data secure: for millions of people living under restrictive regimes they’re the only way to ensure full access to the internet. What do you do when your government orders ISPs to ban VPNs, like Russia has done recently?  [LaserHelix] shows us one way you can cope, which is to use a ShadowSocks proxy.
If you’re not deep into network traffic, you might be wondering: how can an ISP block VPN traffic? Isn’t that stuff encrypted? Yes, but while the traffic going over the VPN is encrypted, you still need to connect to your VPN’s servers– and those handshake packets are easy enough to detect. You can do it at home with Wireshark, a tool that shows up fairly often on these pages. Of course if they can ID those packets, they can block them.
So, you just need a way to obfuscate what exactly the encrypted traffic you’re sending is. Luckily that’s a solved problem: Chinese hackers came up with something called Shadowsocks back in 2012 to help get around the Great Firewall, and have been in an arms-race with their authorities ever since.
Shadowsocks is not, in fact, a sibling of Gandalf’s horse as the name might suggest, but a tool to obfuscate the traffic going to your VPN. To invert a meme, you’re telling the authorities: we heard you don’t like encrypted traffic, so we put encryption in your encrypted traffic so you have to decrypt the packets before you recognize the encrypted packets.
What about the VPN? Well, some run their own shadowsocks service, while others will need to be accessed via a shadowsocks bridge: in effect, a proxy that then connects to the VPN for you. That means of course you’re bouncing through two servers you need to trust not to glow in the dark, but if you have to trust someone– otherwise it’s off to a shack in the woods, which never ends well.
Don’t forget that while VPNs can get you around government censorship, they do not provide anonymity on their own. If, like tipster [Keith Olson] –thanks for the tip, [Keith]!– you’re looking side-eyed at your government’s “think of the children!” rhetoric but don’t know where to start, we had a discussion about which VPNs to use last year.
This KiCAD Plugin Enables Breadboarding
Some people learning the noble art of electronics find the jump from simpler tools like Fritzing to more complex ones, such as KiCAD, a little daunting, especially since they need to learn at least two tools. Fritzing is great for visualising your breadboard layout, but what if you want to start from a proper schematic, make a prototype on a breadboard and then design a custom PCB? Well, with the Kicad-breadboard plugin for (you guessed it!) KiCAD, you can now do all of this in the same tool.
A simple dual-rail oscillator schematic corresponding to the featured image above
Originally designed to support EE students at the University of Antwerp, the tool presents you with a virtual breadboard with configurable size and style, along with a list of components and tools that can be placed. A few clicks and parts can be placed on the virtual breadboard with ease. Adding wires is the next logical step to make those connections that operate in the horizontal dimension. Finally, assigning power supplies and probe connections completes the process. It’s a simple enough tool to draw stuff, but drawing a layout is no use if you can’t verify it’s correctness. This is where this plugin shines: it can perform an ERC (check) between the schematic and the breadboard and flag up what you missed. Add to this that you can also perform an ERC at the schematic level, before even thinking about layout, and it’s pretty hard to make an error. Now, you can transfer this directly to a real breadboard, or even a veroboard, for more permanence once you have confidence in correctness. This will definitely save time correcting errors and help keep the magic smoke safely contained within those mysterious black rectangles.
Continue reading “This KiCAD Plugin Enables Breadboarding” →
ESP32Synth : An Audio Synthesis Library For The ESP32
With MCUs becoming increasingly more powerful it was only a matter of time before they would enable some more serious audio-processing tasks. [Danilo Gabriel]’s ESP32Synth library is a good example here, which provides an ESP-IDF based 80+ voice mixing and synthesis engine. If you ever wanted to create a pretty impressive audio synthesizer, then all you really need to get started is an ESP32, ESP32-S3 or similar dual-core Espressif MCU that has the requisite processing power.
Audio output goes via I2S, requiring only a cheap I2S DAC like the UDA1334A or PCM5102 to be connected, unless you really want to use the internal DAC. With this wired up you get 80 voices by default, with up to 350 voices demonstrated before the hardware cannot keep up any more. You can stream multiple WAV files from an SD card for samples along with the typical oscillators like sinewave, triangle, sawtooth and pulse, as well as noise, wavetables and more.
In order to make this work in real-time a number of optimizations had to be performed, such as the removal of slow floating-point and division operations in the audio path. The audio rendering task is naturally pinned to a single core, leaving a single core for application code to use for remaining tasks. While the code is provided as an Arduino project, it uses ESP-IDF so it can likely be used for a regular ESP-IDF project as well without too much fuss.
2026 Green Powered Challenge: Cook With The Sun!
One of the problems facing any solar power installation comes in storing enough power for high-intensity operations such as cooking. The high-tech and expensive way involves battery banks and inverters, but [Solar Genius] is taking a more direct route by skipping the energy storage entirely.
A pair of parabolic antennas are pressed into service as mirrors, catching and focusing the sun’s energy onto a cooking pot. Of course, solar cookers like this are nothing new, so what makes this one different is the in-depth analysis of its performance. This thing can cook!
One antenna is covered in square mirrors while the other is covered in sticky chrome-effect mirror sheeting. They’re described as sun tracking, but since we don’t see any mechanism we’re guessing the tracking is done by hand. The experiment takes place in Pakistan, so there’s a plentiful supply of sunlight that those of us in more northern climes can only dream of.
This hack is part of our 2026 Green Powered Challenge. You’ve just got time to get your own entry in, so get a move on!
A Solar Powered Plant Monitor That Almost Works
Keeping plants alive is easy if you’re diligent and never forget to check on your green friends. However, a little electronic help never hurts. To that end, [Narrow Studios] built a simple solar powered monitor to assist in plant maintenance, and it mostly does the job.
An ESP32-C3 development board serves as the brains of the operation. It’s set up with a capacitive soil moisture sensor, a great choice because they tend to last longer than other types. Power is courtesy of a small lithium-polymer battery and a solar panel, which keeps everything running off the juice from interior lighting alone. SK6812 addressable LEDs are used to show current soil moisture status. To avoid excessively draining the batteries with the limited power available, a HCSR505 PIR motion sensor is used to only light the status LEDs if the device detects someone in the vicinity.
There were some issues in the build. The voltage regulator doesn’t supply enough current to enable the ESP32 to jump on WiFi, so soil dryness indication is via LED only. The solar setup is a little weak, too. Still, the project was a great learning experience and with a few mods, would be even more capable.
We’ve featured some great plant monitors over the years, like this Hackaday Prize entry from 2023.
Continue reading “A Solar Powered Plant Monitor That Almost Works” →
VCF East And Maker Faire Make For A Busy Weekend
For those of us with an interest in hacking and making, events where we can meet up with like minded folks and check out the projects they’re working on don’t exactly happen every day. Unless you’re able to travel around the country (or even better, the world), you usually have to make do with the handful of annual events that are within a reasonable distance of your home. If you’re lucky that may give you two or three opportunities during the year to look forward to, generally spaced out enough that you’ve got adequate time to prepare ahead of the event and decompress afterwards.
But occasionally, the planets and geekdoms align. Such was the case this past weekend in the Northeastern United States, with Vintage Computer Festival East and the Philadelphia Maker Faire taking place simultaneously. Both are established must-see events for their respective communities and cover roughly the same geographical area, so if you happened to have a foot in each camp, this presented quite a difficult decision.
That is unless you took the third option. As the Philly Maker Faire was on Sunday and VCF took place over the span of the whole weekend, there was a narrow path to attend both events. It wouldn’t be ideal, of course. For one thing it would mean speed running VCF East, and there was a couple hundred miles of travel to contend with. We won’t even talk about the physical toll incurred — while there doesn’t appear to be any official dosage recommendation from the Surgeon General, surely this level of exposure to non-conforming technologists carries with it some risks.
But sometimes such sacrifices must be made, especially if you’re being paid to make them. So I packed up twice the normal number of Wrencher stickers, and hit the road in an effort to deliver a condensed version of my experience at these two fantastic events.
Continue reading “VCF East And Maker Faire Make For A Busy Weekend” →
