Ask Hackaday: How Much Compute Is Enough?
Over the history of this business, a lot of people have foreseen limits that look rather silly in hindsight– in 1943, IBM President Thomas Watson declared that “I think there is a world market for maybe five computers.” That was more than a little wrong. Depending on the definition of computers– particularly if you include microcontrollers, there’s probably trillions of the things.
We might as well include microcontrollers, considering how often we see projects replicating retrocomputers on them. The RP2350 can do a Mac 128k, and the ESP32-P4 gets you into the Quadra era. Which, honestly, covers the majority of daily tasks most people use computers for.
The RP2350 and ESP32-P4 both have more than 640kB of RAM, so that famous Bill Gates quote obviously didn’t age any better than Thomas Watson’s prediction. As Yogi Berra once said: predictions are hard, especially about the future. Continue reading “Ask Hackaday: How Much Compute Is Enough?”
Ask Hackaday: How Do You Detect Hidden Cameras?
The BBC recently published an exposé revealing that some Chinese subscription sites charge for access to their network of hundreds of hidden cameras in hotel rooms. Of course, this is presumably without the consent of the hotel management and probably isn’t specifically a problem in China. After all, cameras can now be very tiny, so it is extremely easy to rent a hotel room or a vacation rental and bug it. This is illegal, China has laws against spy cameras, and hotels are required to check for them, the BBC notes. However, there is a problem: At least one camera found didn’t show up on conventional camera detectors. So we wanted to ask you, Hackaday: How do you detect hidden cameras?
How it Works
Commercial detectors typically use one of two techniques. It is easy to scan for RF signals, and if the camera is emitting WiFi or another frequency you expect cameras to use, that works. But it also misses plenty. A camera might be hardwired, for example. Or store data on an SD card for later. If you have a camera that transmits on a strange frequency, you won’t find it. Or you could hide the camera near something else that transmits. So if your scanner shows a lot of RF around a WiFi router, you won’t be able to figure out that it is actually the router and a small camera.
Continue reading “Ask Hackaday: How Do You Detect Hidden Cameras?”
Ask Hackaday: Do You Curb Shop Components?
I’m not proud. When many of us were kids, we were unabashedly excited when trash day came around because sometimes you’d find an old radio or — jackpot — an old TV out by the curb. Then, depending on its size, you rescued it, or you had your friends help, or, in extreme cases, you had to ask your dad. In those days, people were frugal, so the chances of what you found being fixable were slim to none. If it was worth fixing, the people would have probably fixed it.
While TVs and radios were the favorites, you might have found other old stuff, but in those days, no one was throwing out a computer (at least not in a neighborhood), and white goods like refrigerators and washing machines had very little electronics. Maybe a mechanical timer or a relay, but that’s about it.
Continue reading “Ask Hackaday: Do You Curb Shop Components?”
Ask Hackaday: Solutions, Or Distractions?
The “Long Dark” is upon us, at least for those who live north of the equator, and while it’s all pre-holiday bustle, pretty lights, and the magical first snow of the season now, soon the harsh reality of slushy feet, filthy cars, and not seeing the sun for weeks on end will set in. And when it does, it pays to have something to occupy idle mind and hands alike, a project that’s complicated enough to make completing even part of it feel like an accomplishment.
But this time of year, when daylight lasts barely as long as a good night’s sleep, you’ve got to pick your projects carefully, lest your winter project remain incomplete when the weather finally warms and thoughts turn to other matters. For me, at least, that means being realistic about inevitabilities such as competition from the day job, family stuff, and the dreaded “scope creep.”
It’s that last one that I’m particularly concerned with this year, because it has the greatest potential to delay this project into spring or even — forbid it! — summer. And that means I need to be on the ball about what the project actually is, and to avoid the temptation to fall into any rabbit holes that, while potentially interesting and perhaps even profitable, will only make it harder to get things done.
Continue reading “Ask Hackaday: Solutions, Or Distractions?”
Ask Hackaday: When Good Lithium Batteries Go Bad
Friends, I’ve gotten myself into a pickle and I need some help.
A few years back, I decided to get into solar power by building a complete PV system inside a mobile trailer. The rationale for this doesn’t matter for the current discussion, but for the curious, I wrote an article outlining the whole design and build process. Briefly, though, the system has two adjustable PV arrays mounted on the roof and side of a small cargo trailer, with an integrated solar inverter-charger and a 10-kWh LiFePO4 battery bank on the inside, along with all the usual switching and circuit protection stuff.
It’s pretty cool, if I do say so myself, and literally every word I’ve written for Hackaday since sometime in 2023 has been on a computer powered by that trailer. I must have built it pretty well, because it’s been largely hands-off since then, requiring very little maintenance. And therein lies the root of my current conundrum.
Continue reading “Ask Hackaday: When Good Lithium Batteries Go Bad”
Ask Hackaday: What Would You Do With The World’s Smallest Microcontroller?
It’s generally pretty easy to spot a microcontroller on a PCB. There are clues aplenty: the more-or-less central location, the nearby crystal oscillator, the maze of supporting passives, and perhaps even an obvious flash chip lurking about. The dead giveaway, though, is all those traces leading to the chip, betraying its primacy in the circuit. As all roads lead to Rome, so it often is with microcontrollers.
It looks like that may be about to change, though, based on Texas Instruments’ recent announcement of a line of incredibly small Arm-based microcontrollers. The video below shows off just how small the MSPM0 line can be, ranging from a relatively gigantic TSSOP-20 case down to an eight-pin BGA package that measures only 1.6 mm by 0.86 mm. That’s essentially the size of an 0603 SMD resistor, a tiny footprint for a 24-MHz Cortex M0+ MCU with 16-kB of flash, 1-kB of SRAM, and a 12-bit ADC. The larger packages obviously have more GPIO brought out to pins, but even the eight-pin versions support six IO lines.
Of course, it’s hard not to write about a specific product without sounding like you’re shilling for the company, but being first to market with an MCU in this size range is certainly newsworthy. We’re sure other manufacturers will follow suit soon enough, but for now, we want to know how you would go about using a microcontroller the size of a resistor. The promo video hints at TI’s target market for these or compact wearables by showing them used in earbuds, but we suspect the Hackaday community will come up with all sorts of creative and fun ways to put these to use — shoutout to [mitxela], whose habit of building impossibly small electronic jewelry might be a good use case for something like this.
There may even be some nefarious use cases for a microcontroller this small. We were skeptical of the story about “spy chips” on PC motherboards, but a microcontroller that can pass for an SMD resistor might change that equation a bit. There’s also the concept of “Oreo construction” that these chips might make a lot easier. A board with a microcontroller embedded within it could be a real security risk, but on the other hand, it could make for some very interesting applications.
What’s your take on this? Can you think of applications where something this small is enabling? Or are microcontrollers that are likely to join the dust motes at the back of your bench after a poorly timed sneeze a bridge too far? Sound off in the comments below.
Continue reading “Ask Hackaday: What Would You Do With The World’s Smallest Microcontroller?”
Ask Hackaday: How Do You Make Front Panels?
We’ll admit it. The closer a project is to completion, the less enthusiasm we have for it. Once the main design is clearly going to work on a breadboard, we’re ready to move on to the next one. We don’t mind the PCB layout, especially with modern tools. However, once the board is done, you have to do the case. Paradoxically, this was easier in the old days because you just picked some stock box, drilled some holes, and while it looked terrible, it was relatively easy.
Today, the bar is much higher. You’ll probably 3D print or laser cut an enclosure. If it looks no better than what you did in the 1970s, you won’t win many admirers. We routinely cover projects that could easily pass for commercial products. So how do you do it?
The Parts
The enclosure may even be the easy part. There are plenty of scripts and generators that will make you a nice box that meets your specifications. You can probably even get the holes made as you build. Back in the day, it was a challenge to cut odd-shaped holes for things like serial port connectors. Now, no problem. The printer or laser will just make a hole with any shape you like. You may even want to try a new angle on 3D printing.
Mounting the PCB isn’t that hard, either. With 3D printing, you can create standoffs, but even if you laser cut, you can easily use conventional standoffs. In a pinch, we’ve used long bolts with nuts.
The real problem, it seems to us, is the front panel. Only Star Trek can get away with front panels containing a bunch of knobs and dials with no markings. And although we call them “front” panels, sometimes you need markings on the back or even the sides, too. Continue reading “Ask Hackaday: How Do You Make Front Panels?”
