Ambition, Thy Name Is A 3D Printed Transonic R/C Jet
Building anything that flies from scratch is an ambitious undertaking, even if it’s ‘just’ radio-controlled. 3D printing the aircraft isn’t that odd these days, but putting a hot jet engine into a plastic airframe is another ambitous reach. Getting said 3D printed airframe up to the transonic speed of Mach 0.8? Ambition, thy name is Kingchaser. Or at least, that’s the name [The Mach Initiative] give to their very ambitious aircraft, the video about which is embedded below.
The airframe is largely 3D printed from PETG– that’s all the orange bits– but there are carbon fiber rods and an aluminum frame to help take up the strain. The black section around the motor is printed from PPS-CF– that’s Polyphenylene sulfide with carbon fibre–wrapped in carbon fiber to take the heat. This all builds off a smaller PLA version that’s already flown called Kingfisher, which claimed the title of the first 3D printed jet. That flight is on their YouTube channel, if you’re interested.
Now with a bigger aircraft and a much bigger engine– 300 N or 68 lbf of thrust– they’re going for the speed record. If they get even close to the design goal of mach 0.8, they’re absolutely going to leave the world’s fastest drone– a 626 km/h quadcopter we’ve written about— in the dust.
The switch to PETG from PLA, for the record, was to deal with the expected aerodynamic heating at that speed, about 990 km/h or 615 mph. An interesting detail many don’t bother with when it comes to 3D printed airplanes is that the skin has all been polished smooth, since skin drag is dominant at that speed regime. The video is just chock full of those little details that it takes to defeat drag and get to the record speed, and there’s more to come from [The Mach Initiative].
Speaking of remote controlled speed records, we covered another batch of brits take home the land speed record a few years back. May [The Mach Initiative] see such success!
Continue reading “Ambition, Thy Name Is A 3D Printed Transonic R/C Jet” →
This Plane Flies Slow Because Its Wings Really Blow
The key to Short Takeoff and Landing (STOL) operations is the ability to fly slow– really slow. That’s how you get up fast without a long takeoff roll to build up speed. Usually, this involves layers of large flaps and/or leading edge slats, but [rctestflight] on YouTube decided he wanted to take a more active approach with a fully blown wing.
The airplane in question is R/C, of course, and good thing: these wings would be a safety nightmare for a manned aircraft. With a blown wing, air is blown out of a slot on the top end of the wing, producing a high-speed, high-pressure zone that keeps the wing flying when it would otherwise be completely stalled out. As long as everything works, that’s great! If an engine fails, well, suddenly you aren’t flying anymore — and you’re going too slow to glide. It ends badly.
[rctestflight] doesn’t have to worry about that, though, because this foamboard and pink styro R/C aircraft carries nothing that can’t survive a crash. (A couple of electric ducted fans (EDCs), an Ardupilot, a radio, and a battery are all pretty shock-resistant.) The EDCs sit midway down the chord of the wings, and blow air into a plenum carved into the foam. On each wing, the exhaust from the fans is driven rearward from a slot created by a piece of carbon fiber. This air serves not only as a lift-enhancement but also as the plane’s sole propulsion and a component of its control system.
Continue reading “This Plane Flies Slow Because Its Wings Really Blow” →
Flite Test Puts A Chair In The Air
The Flite Test crew is well known for putting some crazy flying contraptions together. They’ve outdone themselves this time with a flying IKEA chair. This build began with [Josh] issuing a challenge to [Stefan]. Take a standard IKEA ladderback chair and make it fly– in less than six hours. With such a tight schedule, measuring twice and cutting once was right out the window. This was a hackathon-style “throw it together and hope it works” build.
The chair was plenty sturdy, so it became the core of the fuselage. [Stefan] grabbed the wing from a previous plane and placed it on the seat of the chair. Two carbon fiber rods drilled into the seat frame formed a tail boom. The tailfeathers were built from Flite Test foam – paper coated foam-core board.
With the structure complete, [Stefan] and his team added servos for control, a beefy motor for power, and some big LiPo batteries. The batteries hung from the bottom of the chair to keep the center of gravity reasonable.
When the time came for the maiden flight, everyone was expecting a spectacular failure. The chair defied logic and leaped into the air. It flew stable enough for [Josh] to take his fingers off the sticks. The pure excitement of seeing a crazy build that works is on full display as the entire Flite Test crew literally jumps for joy. [Alex] even throws in a cartwheel. This is the kind of story we love to cover here at Hackaday – watching a completely nutty build come together and perform better than anyone expected.
Continue reading “Flite Test Puts A Chair In The Air” →
A Micro RC Plane Builder Shares His Tricks
There are individuals who push tools, materials, and craftsmanship to the limit in the world of micro RC aircraft, and [Martin Newell] gives some insight into the kind of work that goes into making something like a 1:96 scale P-51 Mustang from scratch. The tiny plane is 100% flyable. It even includes working navigation lights and flashing cannons (both done with 0402 LEDs) and functional, retractable landing gear. It weighs an incredible 2.9 grams. Apart from the battery, everything in the plane was built or assembled from scratch. A video is embedded below.
Continue reading “A Micro RC Plane Builder Shares His Tricks” →
Modified R/C Jet Cannon Spews Nerf, Slays Cardboard Tanks
[ajw61185] made a video overview of a radio-controlled A-10 jet modified to spew a hail of harmless Nerf balls as it strafes helpless cardboard cutouts of T-72 tanks on a bright, sunny day.
A10 Nerf LoadingThe firing assembly in the jet comes from a Nerf Rival Zeus Blaster, which is itself an interesting device. It uses two electric flywheels to launch soft foam balls – much like a pitching machine. With one flywheel running a little faster than the other, the trajectory can be modified. For example, a slight topspin gives the balls a longer and more stable flight path. Of course, foam balls slow down quickly once launched and at high speeds the aircraft can overtake the same projectiles it just fired, but it’s fun all the same.
Cramming the firing assembly into aircraft took some cleverness. The front of the jet contains the flywheel assembly, and a stripped-down removable magazine containing the foam balls fits behind it. A flick of a switch on the controller spins up the flywheels, and another flick controls a servo that allows the balls to enter the firing assembly and get launched. The ammo capacity on the jet is low at only twelve shots per load, and it fires all twelve in roughly half a second. Since the balls are fired at the ground in a known area, they’re easy to retrieve.
Continue reading “Modified R/C Jet Cannon Spews Nerf, Slays Cardboard Tanks” →
Aerodynamics? Super Honey Badger Don’t Give A @#*^@!
honeybadger-rcplane
[Arron Bates] is a pro R/C Pilot from Australia. He’s spent the last few years chasing the dream of a fixed wing plane which could perform unlimited spins. After some promising starts with independently controlled wing spoilers, [Arron] went all in and created The Super Honey Badger. Super Honey Badger is a giant scale R/C plane with the tail of a helicopter and a soul of pure awesome.
Starting with a standard 87″ wingspan Extra 300 designed for 3D flight, [Arron] began hacking. The entire rear fuselage was removed and replaced with carbon fiber tubes. The standard Extra 300 tail assembly fit perfectly on the tubes. Between the abbreviated fuselage and the tail, [Arron] installed a tail rotor from an 800 size helicopter. A 1.25 kW brushless motor drives the tail rotor while a high-speed servo controls the pitch.
[Arron] debuted the plane at HuckFest 2013, and pulled off some amazing aerobatics. The tail rotor made 540 stall turn an easy trick to do – even with an airplane. Flat spins were a snap to enter, even from fast forward flight! Most of [Arron’s] maneuvers defy any attempt at naming them – just watch the videos after the break.
Sadly, Super Honey Badger was destroyed in May of 2014 due to a structural failure in the carbon tubes. [Arron] walked away without injury and isn’t giving up., He’s already dropping major hints about a new plane (facebook link).
Continue reading “Aerodynamics? Super Honey Badger Don’t Give A @#*^@!” →
