[Trixter], connoisseur of old hardware, is celebrating the 25th anniversary of the PCjr. IBM’s PCjr was killed only 18th months after being revealed and [Trixter] lays out exactly why. Overall, it was designed to be cheap to produce and sell, but many of the choices made it difficult to use. They used the CPU instead of DMA for floppy access; cheaper to make, but you couldn’t do much during disk reads because of it. The video memory scheme left little room for programs that could take advantage of it. It also had compatibility issues that made IBM clones a more attractive choice. [Trixter] ends by pointing out that some good came of it when the Tandy 1000 copyied the good ideas while leaving out the restrictive memory issues. He recommends Mike’s PCjr Page for more information on this classic machine.
