Commercial R/C aircraft have been getting smaller and smaller with each passing year. In the early 2000’s, a palm-sized plane or helicopter was the dream of many an R/C enthusiast. Today, you can pick them up for around $20 USD at the local mall. The smallest models however, are still built by an elite group of modelers. Weighing in at a mere 3 grams, [Martin Newell’s] P-51D mustang model certainly puts him into that group. While the P-51’s 11.6 cm wingspan may not make it the smallest plane in the world, its many functions make it incredible.
The Mustang is an 8 channel affair, with elevator, throttle, rudder, ailerons, flaps, navigation lights, working retracts, and flashing cannon lights. That’s Wright, we did say retracts, as in retractable landing gear on a 3 gram model.
All the Mustang’s flight surfaces feature fully proportional control. However, there are no closed loop servos involved. The flight surfaces use magnetic actuators, consisting of a tiny neodymium magnet surrounded by a coil of magnet wire. We’re not sure if the signals to these actuators is straight PWM or if [Martin] is varying the frequency, but the system works. The retracts use heat-sensitive Nitinol “muscle wire” along with a bellcrank system to make sure the landing gear is up and locked after takeoff, and comes down again before a landing.
We don’t have any in-flight video of the Mustang, but we do have footage of an even smaller 1.2 gram plane [Martin] has been flying lately. Click past the break to check it out!
Continue reading “Tiny R/C P-51D Mustang Tips The Scales At 3 Grams”
