Detective Work Recovers Atari ST ASIC Designs
[Christian Zietz] wanted to know more about the Atari ST. He found information online from newer Atari machines like the Falcon030 and the Jaguar, but couldn’t find much else. While looking through some archives of old disk images from the Atari headquarters, he found a folder marked “Drawings\4118.” With some detective work and emulation of an old operating system, he was able to recover the schematics for the ST-4118 video shifter ASIC (Application-Specific Integrated Circuit).
Unfortunately, this appeared to be a chip for the unreleased Atari Panther video game console. However, it did show the way to how these older schematics were readable. [Christian] continued searching and found some floppy disk images that were a bit unusual. They didn’t have a proper file system but had been created by a backup program called FastBack for MS-DOS.
Continue reading “Detective Work Recovers Atari ST ASIC Designs”
Robots Invade Your Personal Space
If you have ever had to complete a task such as building a LEGO model over a remote connection, you will know that the challenges are like an absurd grade school group project. The person giving directions often has trouble describing what they are thinking, and the person doing the work has trouble interpreting what the instructor wants. “Turn the blue block over. No, only half way. Go back. Now turn it. No, the other way. NO! Not clockwise, downward. That’s Upward! Geez. Are you even listening‽” Good times.
While you may not be in this situation every day, the Keio University of Japan has an intuitive way to give instructors a way to physically interact with an instructee through a Moore/Swayze experience. The instructor has a camera in typical pirate parrot placement over the shoulder. Two arms are controlled by the instructor who can see through stereoscopic cameras to have a first-person view from across the globe. This natural way to interact with the user’s environment allows muscle memory to pass from the instructor to the wearer.
For some of the other styles of telepresence, see this deep-sea bot and a cylindrical screen that looks like someone is beaming up directly from the holodeck.
Continue reading “Robots Invade Your Personal Space”
Retro Console Upgrade Gives Atari Flair
If you’re desperate for a sense of nostalgia for video games of yore but don’t want to shell out the big bucks for an NES classic, you can always grab a single arcade-style game that’ll plug straight into your TV. Of course it’s no longer 1980, and playing Space Invaders or Asteroids can get old after a while. When that happens, just replace the internals for an upgraded retro Atari 2600 with all the games from that system instead of just one.
As expected for something that has to fit in such a tiny package, this upgrade is based on a Raspberry Pi Zero. It’s not quite as simple as throwing RetroPi on it and calling it a day, though. For one, [Blue Okiris] is still using the original two-button controller/joystick that came with the Ms. Pac-Man game this build is based on, and that added its own set of challenges. For another, RetroPi didn’t have everything he needed so he switched to another OS called Recalbox. It also includes Kodi so it could be used as a media center as well.
The build looks like a hack in the truest sense of the word. The circuit board sticks out the bottom a little bit, but this is more of a feature than a bug because that’s where some extra buttons and the power switch are. Overall, it’s a great Retro Atari system that has all the true classics that should keep [Blue Okiris] entertained until Atari releases an official system one day. If you’d like to go a little deeper in the Atari world, though, you could always restore one instead.
Continue reading “Retro Console Upgrade Gives Atari Flair”
3D Printed RC Jet Boat Gets Up To Speed
In one of those weird twists of fate, there’s currently a very high chance that anyone who owns a 3D printer has made a boat with it. In fact, they’ve probably printed several of them, so many that they might even have a shelf filled with little boats in different colors and sizes. That’s because it’s a popular benchmark to make sure the printer is well calibrated. But if you’re going to spend hours printing out a boat, why not print one that’s got some punch?
This 3D printable jet boat designed by [Jotham B] probably isn’t a great print to check your desktop machine’s calibration on, in fact you’re going to want to make sure you’ve got everything dialed in before taking on this challenge. If the classic “Benchy” is the beginners boat, then this is certainly for the 3D printing veterans. But if you’ve got the skills to pull it off, and some RC gear laying around to outfit it with, this could be a great project to end your summer on.
Unless you’ve got an exceptionally tall printer, the 460mm long hull will need to be printed in several pieces and then grafted back together. You could potentially use glue, but something a bit more robust like welding the parts together with a soldering iron is a better bet to make sure your printed boat doesn’t do its best Titanic reenactment out on the lake.
[Jotham] recommends printing the impeller at 0.15mm layer height, as you’ll want all the detail you can muster to provide a smooth surface. You’ll also need to use supports, so expect to spend a fair bit of time cleaning it up post-print. The rest of the model can be printed at 0.3mm, which is going to save a lot of time on the hull. All told, it will take about half a roll of filament to print all the parts for the boat (assuming no mistakes), which puts the pre-electronics cost at around $10 USD.
Speaking of electronics, you’ll need a RC receiver, a servo for steering, an electronic speed controller (ESC), and a suitable motor. [Jotham] used a 3674 brushless motor with a 120A water-cooled ESC, but notes that the setup is way overpowered. In the video after the break you can see the boat spends as much time airborne as it does in the water, which might look cool, but isn’t exactly efficient.
If you want to round out your 3D PLA fleet, we’ve also seen a printed FPV lifeboat as well as a hydrofoil that “flies” through the water.
[Thanks to Aidan for the tip.]
Continue reading “3D Printed RC Jet Boat Gets Up To Speed”
Twenty Projects That Just Won The Human Computer Interface Challenge
The greatest hardware competition on the planet is going on right now. The Hackaday Prize is the Oscars of Open Hardware. It’s the Nobel Prize of building a thing. It’s the Fields Medal of firmware development, and simply making it to the finals grants you a knighthood in the upper echelon of hardware developers.
Last week, we wrapped up the fourth challenge in The Hackaday Prize, the Human Computer Interface challenge. Now we’re happy to announce twenty of those projects have been selected to move onto the final round and have been awarded a $1000 cash prize. Congratulations to the winners of the Human Computer Interface Challenge in this year’s Hackaday Prize. Here are the winners, in no particular order:
Human Computer Interface Challenge Hackaday Prize Finalists:
Continue reading “Twenty Projects That Just Won The Human Computer Interface Challenge”
All The Badges Of DEF CON 26 (vol 4)
From a cockroach filled with LEDs, to an impressively dense 576 RGB LED display, and even a hunk of carpet, our final installment of the unofficial hardware badges at DEF CON 26 are beyond impressive. I tried to see every badge and speak to every badge maker this year. So far we’ve covered a ton of badges in volume 1, volume 2, and volume 3 of this series, and now it’s time to finish up!
If I didn’t get a chance to cover your badge in these articles, we still want to hear about it. What everyone wants is to dig into the details of these gorgeous examples of unique hardware. So post a project page for you badge on Hackaday.io, and make sure you get on the Conference Badges list that has been growing by leaps and bounds.
Continue reading “All The Badges Of DEF CON 26 (vol 4)”
Friday Hack Chat: Environmental Sensors
When it comes to IoT and robotics, the name of the game is sensors. These aren’t just IMUs and the stuff that makes robots move — we’re talking about environmental sensors here. Everything from sensors that measure temperature, air quality, humidity, chemical sensors, and radiation sensors are on the table here. For this week’s Hack Chat, we’re talking all about environmental sensors with a hardware designer who has put them to the test.
Our guest for this week’s Hack Chat is Radu Motisan. He was a finalist in the 2014 Hackaday Prize with the uRad Monitor, a self-contained radiation monitoring network that sends radiation measurements out to a central server, that can be viewed by the entire world. The goal of this project is to create a worldwide network of radiation monitoring devices, and we’re going to say Radu has succeeded. There are hundreds of these uRad Monitors in over forty countries, and all of them are churning out data about the radiation environment in their neck of the woods.
By training, Radu is a software engineer with a masters in science. In his spare time, Radu plays around with chemistry, physics, and electronics. It’s this background that led Radu to create one of the most amazing Hackaday Prize projects ever.
We’ll kick off with a discussion of Radu’s uRad Monitor, and that means we’ll be covering:
  • Radiation Detection, why is it important, and what does it mean?
  • How do you detect radiation?
  • The differences between Geiger-Mueller tubes and scintillators
You are, of course, encouraged to add your own questions to the discussion. You can do that by leaving a comment on the Environmental Sensor Hack Chat Event Page and we’ll put that in the queue for the Hack Chat discussion.join-hack-chat
Our Hack Chats are live community events on the Hackaday.io Hack Chat group messaging. This week is just like any other, and we’ll be gathering ’round our video terminals at noon, Pacific, on Friday, September 7th. Need a countdown timer? We should look into hosting these countdown timers on hackaday.io, actually.
Click that speech bubble to the right, and you’ll be taken directly to the Hack Chat group on Hackaday.io.
You don’t have to wait until Friday; join whenever you want and you can see what the community is talking about.
