So much of what we do relies on a certain societal structure that has been absent for a few months now. When the days run together, it’s hard to remember to do the things that must happen daily. You think you did something, and maybe you’re right, but it’s quite possible you’re thinking of yesterday.
[Flameeyes] has diabetes and must use an insulin pen every morning without fail, no matter what’s happening outside his door. This was pretty much a non-issue in the before-time, but quickly became a serious problem as the routine-free weeks wore on. With no room for false positives, he needed a solution that doesn’t trigger until the deed is done.
Now when [Flameeyes] puts the pen away, he also triggers a Flic smart button mounted nearby. The Flic shares its status with a Feather M4 Express through a web app, and the Feather in turn changes the RGB LED inside of Pikachu’s base from red to yellow for the day. Pikachu sits in plain sight by the kettle, so there’s no guessing whether [Flameeyes] took his insulin.
Insulin is a critical commodity with a lot of DIY interest, which is probably starting to spike about now. Our own [Dan Maloney] wrote a great piece on the subject that brings up an insulin hack from around 80 years ago.
