Four large nixie tubes showing the number 2
[Dalibor Farný]’s Enormous Nixies Light Up Contemporary Art Museum
Nixie tubes come in many shapes and sizes, but in only one color: the warm orange glow that makes them so desirable. They don’t usually come in large numbers, either: a typical clock has four or six; a frequency counter perhaps eight or nine. But some projects go bigger – a lot bigger in [Dalibor Farný]’s case. He built an art installation featuring more than a hundred jumbo-sized nixie tubes that make an entire wall glow orange.
This project is the brainchild of renowned installation artist [Alfredo Jaar], who was invited to create an exhibition at the Hiroshima Museum of Contemporary Art. Its title, Umashimenkana, means “we shall bring forth new life” and refers to a poem describing the birth of a child amid the suffering and despair following the atomic bombing of Hiroshima. Visitors to the exhibit experience a dark room where they see a wall of orange numbers count down to zero and erupt into a waterfall of falling zeroes.
Nixie tube expert [Dalibor] was the go-to person to implement such an installation – after all, he’s one of very few people making his own tubes. But even he had to invest a lot of time and effort into scaling them up to the required 150 mm diameter, with 135 mm tall characters. We covered his efforts towards what was then known as the H-tube project two years ago, and we’re happy to report that all of the problems that plagued his efforts at the time have since been solved.
The cathodes of a large nixie tube being assembledOne of the major issues was keeping the front of the tubes intact during manufacture. Often, [Dalibor] and his colleagues would finish sealing up a tube, only for the front to pop out due to stress build-up in the glass. A thorough heating of the entire surface followed by a slow cooling down turned out to be the trick to evening out the stress. All this heat then caused oxidation of the cathodes, necessitating a continuous flow of inert gas into the tube during manufacture. Those cathodes already had to be made stronger than usual to stop them from flexing, and the backplate light enough to keep everything shock resistant. The list goes on.
After ironing out these quirks, as well as countless others, [Dalibor] was finally able to set up a small-scale production line in a new workshop to get the required 121 tubes, plus spares, ready for shipment to Japan. The team then assembled the project on-site, together with museum staff and the artist himself. The end result looks stunning, as you can see in the excellent video embedded below. We imagine it looks even better in real life – if you want to experience that, you have until October 15th.
You might remember [Dalibor] from his excellent video on nixie clock fault analysis – which we hope won’t be necessary for Umashimenkana. He might be able to make your favorite shape into a nixie tube, too. Thanks for the tip, [Jaac]!
Continue reading “[Dalibor Farný]’s Enormous Nixies Light Up Contemporary Art Museum” →
A Die-Cast Car Subframe, Pushing The Limit Too Far?
A piece of manufacturing news from Tesla Motors caught our eye, that Elon Musk’s car company plans to die-cast major underbody structures — in effect the chassis — for its cars. All the ingredients beloved of the popular tech press are there, a crazy new manufacturing technology coupled with the Musk pixie dust. It’s undeniably a very cool process involving a set of huge presses and advanced 3D-printing for the sand components of the mould, but is it really the breakthrough it’s depicted as? Or has the California company simply scored another PR hit?
We produced an overview of die casting earlier in the year, and the custom sand moulding in the Tesla process sounds to us a sort of half-way house between traditional die casting and more conventional foundry moulding. I don’t doubt that the resulting large parts will be strong enough for the job as the Tesla engineers and metallurgists will have done their work to a high standard, but I’m curious as to how this process will give them the edge over a more traditional car manufacturer building a monocoque from pressed steel. The Reuters article gushes about a faster development time which is no doubt true, but since the days of Henry Ford the automakers have continuously perfected the process of making mass-market cars as cheaply as possible. Will these cast assemblies be able to compete with pressed steel when applied to much lower-margin small cars? I have my doubts.
Aside from the excessive road noise of the Tesla we had a ride in over the summer, if I had a wish list for their engineers it would include giving their cars some longevity.
Header: Steve Jurvetson, CC BY 2.0.
Spinning CRT Makes A 360 Degree Audio Oscilloscope
A question for you: if the cathode ray tube had never been invented, what would an oscilloscope look like? We’re not sure ourselves, but it seems like something similar to this mechanical tachyscope display might worked, at least up to a point.
What’s ironic about this scenario is that the tachyscope [Daniel Ross] built actually uses a CRT from a defunct camcorder viewfinder as the light-up bit of what amounts to a large POV display. The CRT’s horizontal coil is disconnected while the vertical coil is attached to the output of a TEA205B audio amplifier. The CRT, its drive electronics, and the amp are mounted to a motorized plastic platter along with a wireless baby monitor, to send audio to the CRT without the need for slip rings — although a Bluetooth module appears to be used for that job in the video below.
Speaking of slip rings, you’d expect one to make an appearance here to transfer power to the platter. [Daniel] used a slip ring for his previous steampunk tachyscope, but this time out he chose a hand-wound air core transformer, with a stationary primary coil and secondary coil mounted on the platter. With a MOSFET exciter on the primary and a bridge rectifier on the secondary, he’s able to get the 12 volts needed to power everything on the platform.
Like most POV displays, this one probably looks better in person than it does in video. But it’s still pretty cool, with the audio waveforms sort of floating in midair as the CRT whizzes around. [Daniel] obviously put a lot of work into this, not least with the balancing necessary to get this running smoothly, so hats off for the effort.
Continue reading “Spinning CRT Makes A 360 Degree Audio Oscilloscope” →
The Science Behind The Majesty Of Dancing Raisins
Have you ever thrown a handful of raisins into a tub of sparkling water? Or peanuts into beer? It seems like an altogether strange thing to do, but if you’ve tried it, you’ll have seen the way the raisins dance and tumble in the fluid. As it turns out, there’s some really interesting science at play when you dive into the mechanics of it all. [Saverio Spagnolie] did just that, and even went as far as publishing a paper on the topic.
The fundamental mechanism behind the dancing raisins is down to the bubbles in sparkling water. When dropped into the fluid, bubbles form on the raisins and attach to them, giving them additional buoyancy.  They then float up, with some of the bubbles shedding or popping on the way, others doing so at the fluid surface. This then causes the raisins to lose buoyancy, rotate, flop around, and generally dance for our amusement.
[Saverio] didn’t just accept things at face value though, and started taking measurements. He used 3D-printed models to examine bubble formation and the forces involved. Along with other scientists, models were developed to explore bubble formation, shedding, and the dynamics of raisin movement. If you don’t have time to dive into the paper, [Saverio] does a great job of explaining it in a Twitter thread (Nitter) in an accessible fashion.
It’s a great example of cheap kitchen science that can teach you all kinds of incredible physics if you just care to look. Video after the break.
Continue reading “The Science Behind The Majesty Of Dancing Raisins” →
Open Source Rover Gets An Update For Easier Building
Once upon a time, NASA-JPL put out a design for an open-source rocker-bogie rover. It was an impressive and capable thing, albeit a little expensive and difficult to build. Now, the open source community has dived in and refreshed the design, making it cheaper and more accessible than ever before.
Many parts of the original design have either become prohibitively expensive, gone out of stock, or been discontinued entirely. The new version, developed by the community that formed around the project, focuses on using off-the-shelf parts to bring costs down. Where the original design could cost as much as $3000 to build, the new model slashes that bill almost in half. It also eliminates any need for anything custom fabricated, with no machined or 3D printed parts required.
Other optimizations include cutting the rover’s head out from the basic model, as it’s not necessary for a great deal of applications. There is also better fluid and dust ingress protection, and improved serviceability. The entire rover model can also be loaded in OnShape for those desiring to inspect it or make their own modifications.
Parts lists are on GitHub for those desiring to build their own. Alternatively, check out the original design to learn more. Video after the break.
Continue reading “Open Source Rover Gets An Update For Easier Building” →
Inspiration
While we were debating about whether it even makes any sense to reboot RadioShack, or indeed any brick-and-mortar electronics store in the modern era, Dan Maloney and I stumbled on what probably is the real source of all of our greybeard nostalgia for the store chain: inspiration.
For both of us, the appeal of a store like RadioShack was going through the place and thinking of what you’d do with all of those parts. Looking at the back of the beefiest MOSFET in the joint, you’d think about all the current you could pass with it. Or what you’d do with all of those piezo buzzers. And if you didn’t know yet what electronics project you wanted to make, there were things like the Forrest Mims notebooks to inspire you. There you’d find a way to turn the humble LED into a light sensor, whether you needed to or not. I wonder how many packs of assorted LEDs that book sold?!
Dan got his first hands on with a computer in RadioShack as well, because they let folks try them right there. If you didn’t know what you wanted a computer for, and that was the big question of the early microcomputer era, you could head into the store yourself and find out. Seeing, and playing with, Demon Dancer inspired.
A lot of this role is taken over by hackerspaces these days, and even more is taken by the Internet itself, of course. We have no shortage of inspiration – just read a day’s worth of Hackaday if you don’t believe me. So is there any room left for RadioShack’s inspirational role? Maybe not. But if that’s the cost of living in a world where we have access to more great ideas than we’ll ever have time to execute, then so be it!
Toy Bulldozer Becomes Epic Terrifying Lawnmower
Regular lawnmowers are a perfectly fine way to mow your lawn, but they can be a bit boring. They’re also not always the best at tackling thick brush and bushes. [rctestflight] has a solution to both of those problems, in the form of a plant-munching bulldozer.
The concept is simple — it starts with a hefty miniature RC bulldozer. Weighing in at 27 kilograms (60 pounds), the beast has actual functioning hydraulics to control the blade and plow. It struggles somewhat with traction, particularly in muddier conditions, and can’t really dig much, but it nonetheless looks the business.
As cool as it was, [rctestflight] decided to employ it for some real yard work by outfitting it with a mowing rig. The ‘dozer was outfitted with a pair of sawblades, run by twin brushless motors for plenty of grunt. That gave the bulldozer the ability to mow through not just lawn, but even thick blackberry bushes and two-foot high weeds.
It’s not great at steering, but it’s able to destroy thick brush with reckless abandon. Fundamentally, it looks like a very fun way to mow an overgrown yard.
Continue reading “Toy Bulldozer Becomes Epic Terrifying Lawnmower” →
