There are so many things we approximate to make life simple. Wires, for example, have no resistance or other strange effects. Crystal oscillators output their exact frequency. But surely our model of how a computer stores and loads memory is accurate, right? You put data in a particular location and, later, you take it out. The [FEX-Emu] developers have a different perspective. Once you have caches and, perhaps, multiple CPUs, it isn’t that easy.
The basic problem is this: if one CPU (or, more accurately, bus master) writes to a location, will another CPU have access to the new value? X86’s Total Store Ordering model gives programmers strong guarantees about when loads and stores become visible, while ARM deliberately uses a weaker memory model that permits considerably more reordering for performance and efficiency.
An emulator can, in theory, compensate by translating ordinary x86 memory operations into ARM acquire/release operations, but doing that for nearly every memory reference can be expensive. Newer ARM extensions such as LRCPC help considerably, while Apple took a more direct approach by adding an x86-compatible TSO mode to Apple Silicon. That lets ordinary loads and stores behave the way translated x86 code expects with comparatively little overhead.
Continue reading “Emulating Memory Access: How Hard Can It Be?”
