A grid of images shows pictures emerging from patches of random noise. To the left, images are more random, while to the right they become more recognizable.
Running Generative AI On An RP2350
Driven by a desire for privacy, customization, and lower costs, there’s growing interest in AI models which can be run on local hardware. Few of them go as far as [Tim], though, who built an image generation diffusion model which can run on an RP2350 microcontroller.
As might be expected, its capabilities are limited. The resolution is 128×128, it only generates images of human faces, and it takes about twenty seconds per image – still impressive for such limited hardware. It runs on a Waveshare RP2350 development board, and it can output the generated image over USB or display it with the aid of a VGA adapter board.
The generative model doesn’t directly create an image. Rather, it generates a distribution in a latent space, which a variational auto-encoder’s decoder component translates into an image. The auto-encoder was trained in two parts: an encoder which transforms an image into a latent-space distribution, and a decoder to transform that distribution back to an image; once this was trained, only the decoder was used.
The generative portion of the model uses a latent flow diffusion transformer; this takes in noise to start with, then iteratively predicts changes which bring it toward the desired image. It can also take in a output class, which guides the generator’s direction (toward a smiling face, for example). [Tim] trained two models, one larger and one faster, and quantized the weights for both to 8-bit integers. Both models, along with the inference program, then fit into 4 MB of flash memory.
For such a small model, the results are remarkably good; they don’t look quite natural, but they’re quite recognizable. For more on how diffusion image generators work, check out our article on Stable Diffusion.
Track Bird Visitors With A Raspberry Pi And A USB Mic
Avian Visitors is a lovely project by [Teddy Warner] that uses a Raspberry Pi and microphone to keep track of which birds have been visiting your home, and creates a colorful illustration of recent visitors on top of it all.
It reports on a web interface of its own making, but what really takes things to a new level is an optional, stylish E-Ink panel that shows the last 24 hours’ worth of visitors at a glance in a collage.
The key to identification is BirdNET (GitHub here), a deep learning classifier from Cornell that can reliably identify and classify more than 11,000 species worldwide based on sound alone.
Based on that information, the system pulls bird images from a reference set for the region and creates a collage representing the breadth and frequency of visitors in a single image. The larger the image of a bird, the more frequently it was heard.
That’s a cool project, but [Teddy] took things one step further by setting up a color E-Ink display to show a running summary of all the avian visitors the system identifies. [Teddy] has a knack for leveraging projects into wall-mounted art, as we saw with his generative art wall plotter. Continue reading “Track Bird Visitors With A Raspberry Pi And A USB Mic”
Understanding Deep Learning: Free MIT Press EBook For Instructors And Students
The recently published book Understanding Deep Learning by [Simon J. D. Prince] is notable not only for focusing primarily on the concepts behind Deep Learning — which should make it highly accessible to most — but also in that it can be either purchased as a hardcover from MIT Press or downloaded for free from the Understanding Deep Learning website. If you intend to use it for coursework, a separate instructor answer booklet and other resources can be purchased, but student resources like Python notebooks are also freely available. In the book’s preface, the author invites readers to send feedback whenever they find an issue.
Continue reading “Understanding Deep Learning: Free MIT Press EBook For Instructors And Students”
Generating 3D Scenes From Just One Image
The LucidDreamer project ties a variety of functions into a pipeline that can take a source image (or generate one from a text prompt) and “lift” its content into 3D, creating highly-detailed Gaussian splats that look great and can even be navigated.
Gaussian splatting is a method used to render NeRFs (Neural Radiance Fields), which are themselves a method of generating complex scenes from sparse 2D sources, and doing it quickly. If that is all news to you, that’s probably because this stuff has sprung up with dizzying speed from when the original NeRF concept was thought up barely a handful of years ago.
What makes LucidDreamer neat is the fact that it does so much with so little. The project page has interactive scenes to explore, but there is also a demo for those who would like to try generating scenes from scratch (some familiarity with the basic tools is expected, however.)
In addition to the source code itself the research paper is available for those with a hunger for the details. Read it quick, because at the pace this stuff is expanding, it honestly might be obsolete if you wait too long.
Explore Neural Radiance Fields In Real-time, Even On A Phone
Neural Radiance Fields (NeRF) is a method of reconstructing complex 3D scenes from sparse 2D inputs, and the field has been growing by leaps and bounds. Viewing a reconstructed scene is still nontrivial, but there’s a new innovation on the block: SMERF is a browser-based method of enabling full 3D navigation of even large scenes, efficient enough to render in real time on phones and laptops.
Don’t miss the gallery of demos which will run on anything from powerful desktops to smartphones. Notable is the distinct lack of blurry, cloudy, or distorted areas which tend to appear in under-observed areas of a NeRF scene (such as indoor corners and ceilings). The technical paper explains SMERF’s approach in more detail.
NeRFs as a concept first hit the scene in 2020 and the rate of advancement has been simply astounding, especially compared to demos from just last year. Watch the short video summarizing SMERF below, and marvel at how it compares to other methods, some of which are themselves only months old.
Continue reading “Explore Neural Radiance Fields In Real-time, Even On A Phone”
Here’s Why GPUs Are Deep Learning’s Best Friend
If you have a curiosity about how fancy graphics cards actually work, and why they are so well-suited to AI-type applications, then take a few minutes to read [Tim Dettmers] explain why this is so. It’s not a terribly long read, but while it does get technical there are also car analogies, so there’s something for everyone!
He starts off by saying that most people know that GPUs are scarily efficient at matrix multiplication and convolution, but what really makes them most useful is their ability to work with large amounts of memory very efficiently.
Essentially, a CPU is a latency-optimized device while GPUs are bandwidth-optimized devices. If a CPU is a race car, a GPU is a cargo truck. The main job in deep learning is to fetch and move cargo (memory, actually) around. Both devices can do this job, but in different ways. A race car moves quickly, but can’t carry much. A truck is slower, but far better at moving a lot at once. Continue reading “Here’s Why GPUs Are Deep Learning’s Best Friend”
Neuromorphic Computing: What Is It And Where Are We At?
For the last hundred or so years, collectively as humanity, we’ve been dreaming, thinking, writing, singing, and producing movies about a machine that could think, reason, and be intelligent in a similar way to us. The stories beginning with “Erewhon” published in 1872 by Sam Butler, Edgar Allan Poe’s “Maelzel’s Chess Player,” and the 1927 film “Metropolis” showed the idea that a machine could think and reason like a person. Not in magic or fantastical way. They drew from the automata of ancient Greece and Egypt and combined notions of philosophers such as Aristotle, Ramon Llull, Hobbes, and thousands of others.
Their notions of the human mind led them to believe that all rational thought could be expressed as algebra or logic. Later the arrival of circuits, computers, and Moore’s law led to continual speculation that human-level intelligence was just around the corner. Some have heralded it as the savior of humanity, where others portray a calamity as a second intelligent entity rises to crush the first (humans).
The flame of computerized artificial intelligence has brightly burned a few times before, such as in the 1950s, 1980s, and 2010s. Unfortunately, both prior AI booms have been followed by an “AI winter” that falls out of fashion for failing to deliver on expectations. This winter is often blamed on a lack of computer power, inadequate understanding of the brain, or hype and over-speculation. In the midst of our current AI summer, most AI researchers focus on using the steadily increasing computer power available to increase the depth of their neural nets. Despite their name, neural nets are inspired by the neurons in the brain and share only surface-level similarities.
Some researchers believe that human-level general intelligence can be achieved by simply adding more and more layers to these simplified convolutional systems fed by an ever-increasing trove of data. This point is backed up by the incredible things these networks can produce, and it gets a little better every year. However, despite what wonders deep neural nets produce, they still specialize and excel at just one thing. A superhuman Atari playing AI cannot make music or think about weather patterns without a human adding those capabilities. Furthermore, the quality of the input data dramatically impacts the quality of the net, and the ability to make an inference is limited, producing disappointing results in some domains. Some think that recurrent neural nets will never gain the sort of general intelligence and flexibility that our brains offer.
However, some researchers are trying to creating something more brainlike by, you guessed it, more closely emulates a brain. Given that we are in a golden age of computer architecture, now seems the time to create new hardware. This type of hardware is known as Neuromorphic hardware.
Continue reading “Neuromorphic Computing: What Is It And Where Are We At?”
