Robot Looks Exactly Like A Roll Of Filament, If Filament Had Eyes
[Matt Denton]’s SpoolBot is a surprisingly agile remote-controlled robot that doesn’t just repurpose filament spool leftovers. It looks exactly like a 2 kg spool of filament; that’s real filament wound around the outside of the drum. In fact, Spoolie the SpoolBot looks so much like the real thing that [Matt] designed a googly-eye add-on, because the robot is so easily misplaced.
The robot’s mass rotates around a central hub in order to move forward or back.
SpoolBot works by rotating its mass around the central hub, which causes it to roll forward or back. Steering is accomplished by tank-style turning of the independent spool ends. While conceptually simple, quite a bit of work is necessary to ensure SpoolBot rolls true, and doesn’t loop itself around inside the shell during maneuvers. Doing that means sensors, and software work.
To that end, a couple of rotary encoders complement the gearmotors and an IMU takes care of overall positional sensing while an ESP32 runs the show. The power supply uses NiMH battery packs, in part for their added weight. Since SpoolBot works by shifting its internal mass, heavier batteries are more effective.
The receiver is a standard RC PWM receiver which means any RC transmitter can be used, but [Matt] shows off a slick one-handed model that not only works well with SpoolBot but tucks neatly into the middle of the spool for storage. Just in case SpoolBot was not hard enough to spot among other filament rolls, we imagine.
The googly-eye add-on solves that, however. They clip to the central hub and so always show “forward” for the robot. They do add quite a bit of personality, as well as a visual indication of the internals’ position relative to the outside.
The GitHub repository and Printables page have all the design files, and the video (embedded just below) shows every piece of the internals.
The kind of hardware available nowadays makes self-balancing devices much more practical and accessible than they ever have been. Really, SpoolBot has quite a lot in common with other self-balancing robots and self-balancing electric vehicles (which are really just larger, ridable self-balancing robots) so there’s plenty of room for experimentation no matter one’s budget or skill level.
Continue reading “Robot Looks Exactly Like A Roll Of Filament, If Filament Had Eyes”
Hackaday Links Column Banner
Hackaday Links: October 2, 2022
“Necessity is the mother of invention,” or so the saying goes. We’ve never held to that, finding that laziness is a much more powerful creative lubricant. And this story about someone who automated their job with a script is one of the best examples of sloth-driven invention since the TV remote was introduced. If we take the story at face value — and it’s the Internet, so why wouldn’t we? — this is a little scary, as the anonymous employee was in charge of curating digital evidence submissions for a law firm. The job was to watch for new files in a local folder, manually copy them to a cloud server, and verify the file with a hash to prove it hasn’t been tampered with and support the chain of custody. The OP says this was literally the only task to perform, so we can’t really blame them for automating it with a script once COVID shutdowns and working from home provided the necessary cover. But still — when your entire job can be done by a Windows batch file and some PowerShell commands while you play video games, we’re going to go out on a limb and say you’re probably underemployed.
People have been bagging on the US Space Force ever since its inception in 2019, which we think is a little sad. It has to be hard being the newest military service, especially since it branched off of the previously newest military service, and no matter how important its mission may be, there’s still always going to be the double stigmas of being both the new kid on the block and the one with a reputation for digging science fiction. And now they’ve given the naysayers yet more to dunk on, with the unveiling of the official US Space Force service song. Every service branch has a song — yes, even the Army, and no, not that one — and they all sound appropriately martial. So does the Space Force song, but apparently people have a problem with it, which we really don’t get at all — it sounds fine to us.
Continue reading “Hackaday Links: October 2, 2022”
Your Next Robot Needs Googly Eyes, And Other Lessons From Disney
There are so many important design decisions behind a robot: battery, means of locomotion, and position sensing, to name a few. But at a library in Helsinki, one of the most surprising design features for a librarian’s assistant robot was googly eyes. A company called Futurice built a robot for the Oodi library and found that googly eyes were a very important component.
The eyes are not to help the robot see, because of course they aren’t functional — at least not in that way. However without the eyes, robot designers found that people had trouble relating to the service robot. In addition, the robot needed emotions that it could show using the eyes and various sounds along with motion. This was inspired, apparently, by Disney’s rules for animation. In particular, the eyes would fit the rule of “exaggeration.” The robot could look bored when it had no task, excited when it was helping people, and unhappy when people were not being cooperative.
Continue reading “Your Next Robot Needs Googly Eyes, And Other Lessons From Disney”
Clever Battery Holder Hack Makes Brilliant Earrings
A ‘googly eye’ with hole for LED leads on one side, slot for coin cell on the other. Black disk for pupil removed.
We love seeing a thing get used effectively for other than its intended purpose, and this DIY LED Earrings project is a great example. [IdunnGoddess] liked the idea of making light-up LED earrings powered by a small coin cell, but an enclosure and power connection for the battery were sticking points. The solution? A googly eye after a few minor modifications turned out to be perfect.
A googly eye resembles a thin, flat, hollow plastic bulb. Choose one that’s just a bit bigger than the coin cell, and cut a slot in one end and a small hole in the other. The LED leads go into the hole, and the coin cell slides into the slot. The result? A lightweight battery holder for an attached LED, and as a bonus the hacked googly eye is a clean and super smooth surface that can easily be painted or decorated to make it part of the design. The video embedded below demonstrates the process and showcases a few sample designs.
Continue reading “Clever Battery Holder Hack Makes Brilliant Earrings”
Googly Eyes Follow You Around The Room
If you’re looking to build the next creepy Halloween decoration or simply thinking about trying out OpenCV for the first time, this next project will have you covered. [Glen] made a pair of giant googly eyes that follow you around the room using some servos and some very powerful software.
The project was documented in three parts. In Part 1, [Glen] models and builds the eyes themselves, including installing the servo motors that will eventually move them around. The second part involves an Arduino and power supply that will control the servos, and the third part goes over using OpenCV to track faces.
This part of the project is arguably the most interesting if you’re new to OpenCV; [Glen] uses this software package to recognize different faces. From there, the computer picks out the most prominent face and sends commands to the Arduino to move the eyes to the appropriate position. The project goes into great detail, from Arduino code to installing Ubuntu to running OpenCV for the first time!
We’ve featured some of [Glen]’s projects before, like his FPGA-driven LED wall, and it’s good to see he’s still making great things!
Continue reading “Googly Eyes Follow You Around The Room”
Hackaday Links: November 24, 2011
Finally an Arduino shield that does nothing
The folks at Evil Mad Scientist labs have finally created the Googly Eye Shield for Arduinos. With it’s pass-through .100 headers, it adds googly eyes to your Arduino projects. Of course, instead of in addition to the googly eyes you could add a breadboard, making it somewhat useful. A million fake internet points goes to the first person to implement Xeyes on this thing.
Phat beats from kids toys
[Ville] couldn’t afford an Akai MPC for laying down some beats. Wanting a real tactile interface, he hacked this kid’s toy. It’s just an RCA cable attached to the tiny chip inside the toy. The new line out goes to his mixers where he does some pretty impressive stuff.
Mona Lisa is Vigo the Carpathian
What did we just say about real-life Xeyes? [Geert] just made a print of the Mona Lisa follow you around the room with her eyes (Dutch, translation). The build is a pair of servos and a DIY motion capture app running on a laptop. Now we need to find a print of Vigo…
Quantifying heat sink efficiencies
[Mike] is an experimenter at heart. He was wondering about the efficiency of small, clip-on heat sinks versus the ones we use to defrost frozen food. The results are exactly as you would expect, but he did find something interesting – his experimental technique didn’t find much of a difference between thermal paste/grease/pads and no thermally conductive material.
Mini-fig sized R/C LEGO car
The guys at Brickmodder.net took a car from a LEGO set and made it remote control. The drive train and steering both use servos controlled by the smallest 3-channel receiver they could find.
