Making The Fastest LEGO Technic Air-Powered Engine
Just because LEGO Technic is technically a toy doesn’t mean that you cannot do solid engineering with it, like building air-powered engines. After first building a simple air-powered piston engine, this time around [Jamie’s Brick Jams] sought to not only optimize the engine, but also build a clutch and something to power with said engine.
The four-piston design in radial configuration. (Credit: Jamie's Brick Jams, YouTube)
The piston head is one of the handful of 3D printed parts, with the new design featuring twin rubber o-rings as a seal instead of a single big one as in the old design. This incidentally matches the multiple seal rings on an internal combustion engine’s pistons, probably for similar blow-by related reasons. The air hose diameter was also increased from 2 to 3 mm to give the engine a larger volume of air to work with, which along with a new flywheel gave a lot more torque. Next the piston rod length was optimized.
The final radial 4-piston engine turns out to work pretty well, with the clutch engaging smoothly. This was used to drive a DIY generator that turned out to produce about 3 Watt of usable power in its final configuration at 6 V, though it’s admittedly a rather crude generator that could be further optimized. When trying a twin-piston configuration with the highest air pressure before air hoses began to pop off, it hit a dizzying 14,600 RPM.
These aren’t half bad results for some LEGO Technic together with some 3D printed bits, rubber o-rings and some lube.
Continue reading “Making The Fastest LEGO Technic Air-Powered Engine”
A photo of a white dog with curly fur riding a black skateboard with grey motors under the front deck. There are blue squares on the top of the deck that she is standing on to steer the board.
An Electric Skateboard For The Dogs
What’s a dog to do if they want to do some accessible skateboarding? [Simone Giertz]’s three-legged pup, [Scraps], got the chance to try a LEGO Technic board for her thrills.
This electric LEGO skateboard features six motors and paw pedals to let [Scraps] steer while [Giertz] remotely controls the speed of the board. While it’s not a particularly fast ride, it does let [Scraps] live out her dreams of being a YouTube dog skateboard celebrity.
A video from [Giertz] wouldn’t be complete without a life lesson, and this time it was the importance of rest to the creative process. Sometimes when a solution eludes you, it’s just time to take a break. The steering mechanism, in particular, was giving her trouble but became simple the next morning. We’re also treated to an adorable shot of [Scraps] napping when the initial shoot of her riding the board wasn’t going as planned.
Want to try your hand at making your own skateboard? How about a deck from recycled plastic, tank treads instead of wheels, or is a rocket-powered skateboard more your speed?
Continue reading “An Electric Skateboard For The Dogs”
A Simple Air Suspension Demo With Lego Technic
The most common suspension systems on automobiles rely on simple metal springs. Leaf spring and coil spring designs both have their pros and cons, but fundamentally it’s all about flexing metal doing the work. Air suspension works altogether differently, employing gas as a spring, as demonstrated by this simple Lego build from [JBRIX].
The suspension system is employed on a Lego Technic car, with a relatively unsophisticated design. The car has no real form of propusion, and serves solely to demonstrate the air suspension design. They may look like dampers, but the system is actually using Lego pneumatic pistons as springs for each wheel. The pistons are connected to the upper control arm of a double wishbone suspension setup. Each piston is pneumatically connected to a main reservoir. With the reservoir, and thus the pistons, pressurized, the suspension system can support the weight of the car. If a bump perturbs a wheel, the piston compresses the air in the system, which then returns the piston to its original position, thus serving as a spring. If the reservoir is vented, the suspension collapses. Air springs on real, full-sized automobiles work in basically the same way. However, they usually have a separate reservoir per corner, keeping each wheel’s suspension independent.
Overall, if you’re working on some kind of Lego rambler, you might find this suspension concept useful. Alternatively, you might simply find it good as a learning aid. If you want to learn more about oddball suspension systems, we can help there too. Video after the break.
Continue reading “A Simple Air Suspension Demo With Lego Technic”
Exploring Piston Engine Design With LEGO
When learning about the design of a machine or mechanism, reading and watching videos is certainly effective, but it’s hard to beat hands-on experimentation. In the video after the break, [Brick Technology] uses LEGO to gain some practical insight into the world of piston engine design, from single-cylinder all the way up to radial twelve-cylinder engines.
Using pneumatic cylinders from the LEGO Technic series, [Brick Technology] starts by getting the basics working with a single-cylinder design. Besides the fact that there are no fuel-air explosions involved, these pistons are also double-acting thanks to a valve mechanism that switches the pressurized side of the piston as it reaches the end of its stroke. After a couple of experiments, he settles on using a bank of six two liter soda bottles as a source of pressurized air.
He also increased the performance of the LEGO cylinders by drilling out the ports and adding silicon oil for lubrication. In the initial prototypes, the cylinders also acted as connecting rods, tilting back and forth as the crankshaft rotates. After some testing, he discovered he could increase efficiency by constraining the cylinder with a slider mechanism and adding a separate connecting rod.
With the basics done, [Brick Technology] could start experimenting with engine arrangements and geometry. Inline two, three, and four cylinders and V2, V6, V8, and even R12 were all on the menu. He could also change crankshaft geometry to trade torque for RPM and vice versa, and build a starter motor, and torque generator.
Just like [Brick Technology]’s LEGO electronic drums and vortex machine, this video gives us a itch that can only be scratched by a few hundred LEGO pieces. For rapid prototyping of course.
Lego Orrery
LEGOpunk Orrery Knows Just The Right Technics
Is the unmistakable sound of the shuffling of LEGO pieces being dug through burned into your psyche? Did the catalog of ever more complex Technic pieces send your imagination soaring into the stratosphere and beyond? Judging by the artful contraption in the video below the break, we are fairly certain that [Marian] can relate to these things.
No doubt inspired by classic orreries driven by clockwork, [Marian]’s LEGO Sun-Earth-Moon orrery is instead driven by either hand cranks or by electric motors. The orrery aims to be astronomically correct. To that end, a full revolution of a hand crank produces a full day’s worth of movement.
Solar and lunar eclipses can be demonstrated, along with numerous other principals such as the tilt of the earth, moon phases, tidal locking, and more, which can be found at the project page.
While classical orreries predate the Victorian era, there seems to be an almost inexplicable link between orreries and the Steampunk aesthetic. But [Marian]’s orrery brought the term “LEGOpunk” to mind. Could it be? Given that there are 2305 pieces and 264 pages of instructions with 436 steps, we think so!
We’ve covered just a few orreries in the past, from this somewhat simple laser cut orrery to this horrifically complex and beautiful thing hereContinue reading “LEGOpunk Orrery Knows Just The Right Technics”
Lego Submarine Gets Balloon Ballast System
Lego is a fun building block which vast numbers of the world’s children play with every day. However, the mechanical Technic line of Lego building blocks has long offered greater options to the budding engineer. [Brick Experiment Channel] is one such soul, working hard on their latest Lego submarine.
The sub is built inside of a glass food container, chosen for its removable plastic lid with a watertight seal. This keeps all the mechanics dry, as well as the custom electronics built to allow a 27MHz RC controller to send signals to the Lego electronics. This is key as higher frequency radios such as Bluetooth or WiFi can’t penetrate water nearly as well.
A magnetic coupling fitted to a Lego motor is used to drive the propeller in the water without the leaks common when trying to seal a rotating shaft. A second coupling on a Lego servo along with a creative steering arrangement allows the propeller to be turned to steer the craft.
The ballast system is simple. A balloon is filled by a Lego motor running an air pump, capable of 3.0 mL a second and capable of creating a maximum pressure of 2.0 bar. When the balloon is inflated, the buoyancy goes up and the sub rises. Run the motor the other way and the balloon is emptied by a clever clutch and valve arrangement, reducing buoyancy and causing the sub to sink.
The sub isn’t perfect. Maintaining a set depth underwater can be difficult with the rudimentary ballast system, perhaps as the balloon changes shape with varying water pressure. Sometimes, Lego axles slip out of their gears, too, and the radio only works for a few meters under water.
However, simply building a Lego sub of any sort is a remarkable feat. It’s interesting to see the variances in the design compared to earlier projects from [Brick Experiment Channel], too, as we’ve featured their earlier subs before. Video after the break.
Continue reading “Lego Submarine Gets Balloon Ballast System”
DIY LEGO Record Cleaner Is Revolutionary
There are many schools of thought when it comes to keeping vinyl records clean. It’s a ritual that’s nearly as important as the one that comes after it — queuing up the record and lowering the needle. We’ve seen people use everything from Windex and microfiber towels to ultrasonic cleaning machines that cost hundreds or even thousands. In the midst of building a beefier ultrasonic record cleaner and waiting for parts, [Baserolokus] looked around at all the LEGO around the house and decided to build a plastic prototype in the interim.
The idea behind ultrasonic cleaning is simple — high-frequency sound waves pumped through distilled water produce tons of tiny bubbles. These bubbles gently knock all the dirt and grime out of the grooves without using any brushes, rags, or harsh cleaners. [Baserolokus] built two pieces that hang on the edge of a washtub. On one side, a Technic motor spins the record at just under one RPM, it spins against a 3D printer wheel embedded in the other side. Check it out in action after the break.
Cleaning your vinyl is a great first step, but you might be ruining your records with a sub-par turntable. Take a deep dive with [Jenny List]’s thorough primer on the subject.
Continue reading “DIY LEGO Record Cleaner Is Revolutionary”
