A person with blonde hair and light skin in a black t-shirt points at an image of a large QR code with what appear to be pictographic humans dancing in place of the usual blocky squares between the finding squares.
Reading QR Codes By Hand
QR codes can be a handy way to send a link or contact details without all that tedious mucking about with typing in a link, but they aren’t very useful without a smartphone to decode them. [Noel Friedrich] wondered if there was a way to do it by hand.
If it all seems a bit daunting at first, [Friedrich]’s write-up helps you work through copying a QR code to paper and then decoding it, as long as it’s version 1-5. Slashes in the template tell you where error correction has been applied to the code and you need to flip the bit back to what it was.
[Friedrich] then goes into some more details with a practical example of how the error correction works and how to exploit the ways QR codes are generated and read to make artistic QR codes. This even works to make human readable codes (without the worksheet), although the quality of the text still makes it somewhat challenging.
This isn’t the first time we’ve featured reading QR codes without a computer, but once you learn, maybe this QR code clock will be a bit more useful!
Continue reading “Reading QR Codes By Hand” →
Read QR Codes On The Cheap
Adding a camera to a project used to be a chore, but modern camera modules make it simple. But what if you want to read QR codes? [James Bowman] noticed a $7 module that claims to read QR codes so he decided to try one out.
The module seems well thought out. There’s a camera, of course. A Qwiic connector makes hooking up easy. An LED blinks blue when you have power and green when a QR code shows up.
Reading a QR code was simple in Python using the I2CDriver library. There are two possible problems: first, if the QR code contains a large amount of data, you may exceed the I2C limit of 254 bytes. Second, despite claiming a 110-degree field of view, [James’] testing showed the QR code has to be almost dead center of the camera for the system to work.
What really interested us, though, was the fact that the device is simply a camera with an RP2040 and little else. For $7, we might grab one to use as a platform for other imaging projects. Or maybe we will read some QR codes. We’d better pick up a few. Then again, maybe we can just do it by hand.
Visual Code Generator To End All Generators
QR codes are something that we all take for granted in this day and age. There are even a million apps to create your own QR codes, but what if you want to make a barcode? How about making a specific kind of barcode that follows UPC-E, CODE 39, or even the infamous… CODABAR? Well, it might be more difficult to find a single app that can handle all those different standards. Using “yet-another-web-app”, Barcode Tool – Generator & Scanner, you can rid these worries, created by [Ricardo de Azambuja].
When going to [Ricardo]’s simple application, you will find a straightforward interface that allows you to make far more different strips and square patterns than you’ve ever imagined. Of course, starting with the common QR code, you can create custom overlaid codes like many other QR generators. More uniquely, there are options for any barcode under the sun to help organize your hacker workspace. If you don’t want to download an app to scan the codes, you can even use the included scanner function.
If you want to use the web app, you can find it here! In-depth solutions to rather simple problems are something we strive to provide here at Hackaday, and this project is no exception. However, if you want something more physical, check out this specialized outdoor city cooking station.
SHOUT For Smaller QR Codes
QR codes have been with us for a long time now, and after passing through their Gardenesque hype cycle of inappropriate usage, have now settled down to be an important and ubiquitous part of life. If you have ever made a QR code you’ll know all about trying to generate the most compact and easily-scannable one you can, and for that [Terence Eden] is here with an interesting quirk. Upper-case text produces smaller codes than lower-case.
His post takes us on a journey into the encoding of QR codes, not in terms of their optical pattern generation, but instead the bit stream they contain. There are different modes to denote different types of payload, and in his two examples of the same URL in upper- and lower- cases, the modes are different. Upper-case is encoded as alphanumeric, while lower-case, seemingly though also containing alphanumeric information, is encoded as bytes.
To understand why, it’s necessary to consider the QR codes’ need for efficiency, which led its designers to reduce their character set as far as possible and only define uppercase letters in their alphanumeric set. The upper-case payload is thus encoded using less bits per character than the lower-case one, which is encoded as 8-bit bytes. A satisfying explanation for a puzzle in plain sight.
Hungry for more QR hackery? This one contains more than one payload!
Back Up Your Data On Paper With Lots Of QR Codes
QR codes are used just about everywhere now, for checking into venues, ordering food, or just plain old advertising. But what about data storage? It’s hardly efficient, but if you want to store your files in a ridiculous paper format—there’s a way to do that, too!
QR-Backup was developed by [za3k], and is currently available as a command-line Linux tool only. It takes a file or files, and turns them into a “paper backup”—a black-and white PDF file full of QR codes that’s ready to print. That’s legitimately the whole deal—you run the code, generate the PDF, then print the file. That piece of paper is now your backup. Naturally, qr-backup works in reverse, too. You can use a scanner or webcam to recover your files from the printed page.
Currently, it achieves a storage density of 3KB/page, and [za3k] says backups of text in the single-digit megabyte range are “practical.” You can alternatively print smaller, denser codes for up to 130 KB/page.
Is it something you’ll ever likely need? No. Is it super neat and kind of funny? Yes, very much so.
We’ve seen some other neat uses for QR codes before, too—like this printer that turns digital menus into paper ones. If you’ve got your own nifty uses for these attractive squares, let us know!
Self balancing wheeled robot with auto-righting arms lofted high
A Self Righting Balancing Robot Configured The Easy Way
Norwegian electronics hacker [Hans Jørgen] aka [time expander] on YouTube, has a clear interest in robotics, and for his latest effort, decided that it was time to build a custom controller platform. Since [Hans] had a pile of Dynamixel servo motors lying around to test it with, a good first project for the platform was a simple self-balancing wheeled robot. (Video, embedded below)
We say ‘simple’ but that isn’t really the case, as there is a fair bit going on to get this to work. The first problem, is sensing, which was quickly solved with the excellent BMO055 IMU chip. Next, what to do when it falls over? Simply adding some servo-controlled arms, allowed the robot to flip itself back upright. Control is covered with a ESP32-WROOM-32D module from our friends at Espressif, which enables remote firmware uploading over the air (OTA update) as well as parameter tuning. In order to implement the latter, [Hans] chose to use bonjour/mDNS which is an implementation of zero-configuration networking. This gets the ESP32 onto the WiFi, but it isn’t immediately obvious how to connect to it, without a little digging around. To simply connection, [Hans] implemented a dynamic QR code via the connected OLED. This is just one of the those tiny 0.96″ displays that you see touted all over our corners of the internet.
Simply by scanning the QR code with any compatible device to hand brings up a simple configuration web page, allowing one to tweak the PID controller parameters, and get that balancing robot into check. Great stuff!
The PCB was designed in Eagle, firmware for the ESP32 is available, 3D models for the plastic are designed with fusion 360, and [Hans] is even currently working on some preliminary Alexa integration. What a fun project!
All the above, albeit an early cut (look out for bugs!) is available on the project GitHub for your viewing pleasure.
We’re no stranger to self-balancing 3D-printed bots, whilst you’re here, why not checkout A problematic Self-Balancing Sonic the Hedgehog? If wheeled bots aren’t your cup-of-tea, there’s a not-at-all freaky one-legged bouncing bot that may be of interest.
Continue reading “A Self Righting Balancing Robot Configured The Easy Way” →
This beaded QR code tells a story when scanned.
Beaded QR Code Bracelets Weave A Storytelling Interface
For centuries, people have been using patterns to communicate information in an eye-catching way. QR codes are no different, although they require a barcode scanner to decode rather than a knowledge of Navajo Native American history.
November is National Native American Heritage Month, and as part of their celebration, [ngaskins] and their students are making seed bead bracelets with QR codes. When scanned, each QR triggers a story written by the student in the form of an audio file, a video clip, or an animation. [ngaskins] says that this project was inspired by eyeDazzler, a beadwork tapestry made with software that generates Navajo weaving patterns.
The students started by designing their bracelets on graph paper, software, or a virtual loom before getting the seed beads and the tweezers out, and decided whether they would use a static or dynamic QR code. Aside from the aesthetics of beadwork, the bead loom is good for teaching math and computational ideas because the beads are laid out in rows and columns. It’s also a good tool for teaching lines of symmetry.
QR codes can hold quite a bit of information. In fact, there’s enough room in a version 40 QR for an executable version of Snake.
