Clever PCBs Straighten Out The Supercon SAO Badge
When we decided that Simple Add-Ons (SAOs) would be the focus of Supercon 2024, it was clear the badge would need to feature more than just one or two of the requisite connectors. We finally settled on six ports, but figuring out the geometry of getting all those ports on the badge in such a way that the SAOs wouldn’t hit each other was a bit tricky. In early concept drawings the badge was just a big rectangle with the ports along the top, but it was too ugly.
In the end we went with a somewhat organic design — an electronic “flower” with the radially arranged SAOs forming the petals, but this meant that that none of the SAOs were in the traditional vertical orientation. Luckily, [Adrian Studer] designed a couple of PCBs that not only resolve this issue, but add a seventh SAO port for good measure.
In the project repository you’ll find two PCB designs. The first, “SAO Up” is essentially a little arm that turns the SAO port 90 degrees. This doesn’t exactly get them vertical, in fact, whether or not the new orientation is actually an improvement for the top two SAOs is perhaps debatable. But it definitely helps on the lower SAOs, which are essentially upside down in their original configuration.
The real star of the show is “SAO Bridge”, a wavy board that connects across the two midline SAO ports on the Supercon badge and turns it into a set of three (nearly) horizontal connectors across the front. The center port is particularly helpful in that it gives you a place to put unusually wide SAOs.
As a reminder the Supercon SAO badge, and the winners of the 2024 SAO Contest, will be making the trip across the pond for Hackaday Europe in just a few months. That means you’ve still got plenty of time to have a few of these CERN-OHL-P licensed boards made up.
Render of the shell pictured standing on the pavement, with shell parts printed in white and button parts printed in orange
Packing For Supercon? Here’s A Printable Case For Your Badge
Hackaday Supercon 2023 is a week away, and if you’re still thinking about the equipment you need to take with you, here’s something you’ll want to print – a case for the Supercon 2023 badge that you will find inside of your goodie bag. This year’s Supercon badge is a gorgeous analog playground board we call Vectorscope, powered by an RP2040, MicroPython, and a ton of love for all of the creativity that we’ve seen you bunch express through the wonders of analog electronics. There’s a round LCD screen, SMD buttons galore, as well as some pokey through-hole headers, and if you’ve carried a badge around, you know that all of these can be a bit touchy! You’re in luck, though – just in time, [T.B. Trzepacz] brings us a 3D-printed shell.
Over on Hackaday Discord, we’ve been watching this shell go through multiple iterations throughout the past few days – the initial design pics appeared almost as soon as we published the PCB files for the badge! Yesterday, [T.B. Trzepacz] dropped by the Design Lab where we’ve been putting finishing touches on the badges, and armed with the real-world PCBs, made the final tweaks to the design – then gave us the go-ahead to spread the word.
This shell is practical but elegant and does a mighty fine job protecting both the badge and the wearer. Nothing is hidden away, from the buttons to the expansion headers, and the lanyard holes keep it wearable. At this time, grab the Basic 2 files – these should work for SLA and FDM printers alike, and they’re tolerant enough even for FDM printers below average. Pick your favourite color scheme, or go for one of the transparent SLA resins, and when you arrive at the Supercon, you’ll have a case you can rely on.
Want to give this case your own spin? Perhaps a Pip-Boy aesthetic or a Vectrex console vibe? Should you want to modify anything, the Fusion360 sources are right there, open-source as they ought to be.
Ask Hackaday: Split Rail Op Amp Power Supply
Water cooler talk at the office usually centers around movies, sports, or life events. Not at Hackaday. We have the oddest conversations and, this week, we are asking for your help. It is no secret that we have a special badge each year for Supercon. Have you ever wondered where those badges come from? Sometimes we do too. We can’t tell you what the badge is going to be for Supercon 2023, but here’s a chance for you to contribute to its design.
What I can tell you is that at least part of the badge is analog. Part, too, is digital. So we were discussing a seemingly simple question: How do we best generate a bipolar power source for the op amps on a badge? Like all design requests, this one is unreasonable. We want:
  • Ideally, we’d like a circuit to give us +/- 9 V to +/- 12 V at moderately low current, say in the tens of milliamps. Actual values TBD.
  • Low noise: analog circuitry, remember?
  • Lightweight: it is going on a badge
  • Battery operated: the badge thing again
  • Cheap: we only have a couple bucks in the budget for power
  • Available in quantity: we’ll need ~600 of these
Continue reading “Ask Hackaday: Split Rail Op Amp Power Supply”
Watch Linux Boot On Your Hackaday Superconference Badge
Last year’s Hackaday Superconference badge was an electronic tour de force, packing an ECP5 FPGA shoehorned into a Game Boy-like form factor and shipping with a RISC-V core installed that together gave an almost infinite badge hacking potential. It did not however run Linux, and that’s something [Greg Davill] has addressed, as he’s not only running Linux on his badge, but also a framebuffer that allows him to use the badge screen as the Linux terminal screen. Finally you can watch Linux boot on your Superconference badge itself, rather than over its serial port.
He’s achieved this by changing essentially everything: from the new VexRiscv CPU core, to new video drivers and a VGA terminal courtesy of Frank Buss, now part of the LiteVideo project. It’s not quite a fully fledged Linux powerhouse yet, but you can find it in a GitHub repository should you have a mind to try it yourself. Paging back through his Twitter feed reveals the effort he’s put into this work over the last few months, and shows that it’s been no easy task.
For those keeping score at home, this is an open hardware design, running an open CPU core, with community-designed open-source peripherals, compiled by an open-source toolchain, running an open-source operating system. And it’s simply a fantastic demo for the badge, showing off how flexible the entire system is. One of the best parts of writing for Hackaday is that our community is capable of a huge breadth of amazing pieces of work, and this is an exemplar of that energy. We can’t wait to see what Greg and any other readers tempted to try it will come up with.
If you’d like to refresh your memory over the 2019 Supercon badge, here’s our write-up at the time.
2019: As The Hardware World Turns
Well, this is it. The end of the decade. In a few days the 2010s will be behind us, and a lot of very smug people will start making jokes on social media about how we’re back in the “Roaring 20s” again. Only this time around there’s a lot more plastic, and drastically less bathtub gin. It’s still unclear as to how much jazz will be involved.
Around this time we always say the same thing, but once again it bears repeating: it’s been a fantastic year for Hackaday. Of course, we had our usual honor of featuring literally thousands of incredible creations from the hacking and making community. But beyond that, we also bore witness to some fascinating tech trends, moments that could legitimately be called historic, and a fair number of blunders which won’t soon be forgotten. In fact, this year we’ve covered a wider breadth of topics than ever before, and judging by the record setting numbers we’ve seen in response, it seems you’ve been just as excited to read it as we were to write it.
To close out the year, let’s take a look at a few of the most popular and interesting stories of 2019. It’s been a wild ride, and we can’t wait to do it all over again in 2020.
Continue reading “2019: As The Hardware World Turns”
Behind The Scenes Of The 2019 Superconference Badge
If you count yourself among the several hundred of our closest friends that have joined us at Supplyframe HQ for the 2019 Hackaday Superconference, then by now you’ll have your hands on one of this year’s incredible FPGA badges. It should come as no surprise that an incredible amount of time and effort went into developing and manufacturing this exceptionally unique piece of hardware; the slick gadget in your hands today took nearly an entire year to develop, and work continued on it until very literally the last possible moment.
Badge designer Jeroen Domburg (aka Sprite_TM), Hackaday staff, and a team of dedicated volunteers were still putting the final touches on these ambitious devices less than 24 hours before they were distributed to the first wave of Superconference attendees. Naturally, that’s not exactly how things were supposed to go. But when you’ve got a group of people that want to push the envelope and build something truly incredible, convincing them to actually stop working can be a challenge in itself.
In fact, development of the badge is still ongoing. Fixes and improvements are being made to the software even as you read this, and if you haven’t already, you should upgrade your badge to make sure you’ve got the latest and greatest from our international team of wizards. We all know that conference badges have an unfortunate habit of languishing on the shelf and collecting dust, but the 2019 Superconference badge was built to challenge you for longer than just one weekend. Consider yourself warned: for every Supercon badge that gets tossed in a drawer come Monday, Sprite_TM will shed a single tear.
After the break, come along as we turn back the clock and take a look at the last minute dash to get 500+ badges programmed and ready to go before the doors opened for the 2019 Hackaday Superconference.
Continue reading “Behind The Scenes Of The 2019 Superconference Badge”
Apple 1 Emulator Is A Perfect Fit For Supercon Badge
Supercon badge hackers had to be ready to present their show-and-tell by 6 pm Sunday evening. This ruthless unmoving deadline meant every badge hack on stage represents an accomplishment in time management, and some luck, in addition to their own technical merits. But that deadline also meant a few fantastic projects lost their race against the clock. We were rooting for [Jac Goudsmit] to build an Apple I emulator as his badge expansion, but he wasn’t quite done when our badge hack ceremony began. After Supercon he went home, finished the project, and documented everything in a detailed writeup.
Our 2018 Supercon badge is built on a retro-computing theme, and the default firmware came with a BASIC interpreter as well as a Z80 emulator running CP/M. So an Apple 1 emulator should feel right home with its contemporaries. Mechanically speaking, all the parts were a tight fit on the badge expansion board given out to every attendee at Supercon. So tightly that [Jac] had to file down the two main chips in order to fit them side by side. The breadboard-like pattern of connected holes on the expansion board, intended to help ease in beginners for their badge hack soldering, proved to be an inconvenience in tightly packed arrangements such as this.
With all the work [Jac] had invested, it was heartbreaking to know he was only five minutes of soldering and 30 minutes of coding away when time ran out. Time pressure was part of the challenge faced by every Supercon badge hacker, and while we’re sad [Jac] missed the deadline for stage time we’re happy to see him finish and write it all up. We hope every badge hacker would write up their stories of frantic weekend projects. Those who do so on hackaday.io are encouraged to tag their project with “Supercon” and get them added to our list of badge hacks for everyone to admire.
